Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
20 registered members (alcyon, Bjornviken, farrarfan1, EdwardC, FnORD, ChristianBerg, 3 invisible), 721 guests, and 29 spiders.
Topics307,584
Posts5,313,570
Members71,876
2014 5.7 Charger UOA #5446982 06/05/20 02:42 PM
B
Bob D Offline OP
B
I just received a Wix UOA report for the sample I took from my 2014 Dodge Charger Pursuit 5.7 with 116K miles on it. I bought it from NCSHP with 102K miles, and put the oil sampled in it at 105.7. I used Redline 5W20 and changed it at 115.7 and sampled. This is my first experience with sampling oil, so just thought I would post to see if I should be concerned. No "hemi tick" or any problems at all, just wanted to know if it is doing OK.
I don't know what I am doing with computers, so not sure about entering the report in "code", but will be glad to do so if someone can explain, preferable via a message, so as not to clutter this post.
Thanks in advance...
Attached PDF document
Re: 2014 5.7 Charger UOA [Re: Bob D] #5446987 06/05/20 02:48 PM
newtoncd8 Offline
I would remove the VIN, your address and repost.
12 Jeep GC, 04 Lexus RX330, 77 MG-B
Re: 2014 5.7 Charger UOA [Re: Bob D] #5447003 06/05/20 03:10 PM
dave1251 Offline
It looks pretty good. Don't pay attention to the slightly higher than normal viscosity Red Line does this but you may want to do a few UOAs to establish a trend.
don't use.
Re: 2014 5.7 Charger UOA [Re: Bob D] #5449442 06/09/20 03:53 AM
G
Gasbuggy Offline
G
These engines eat lifters/cams. I would cut the interval down 2-3k and keep sending samples to try and stay ahead of the wear.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: 2014 5.7 Charger UOA [Re: Gasbuggy] #5449444 06/09/20 04:13 AM
4WD Offline
Run Redline 2k-3k ?
Re: 2014 5.7 Charger UOA [Re: Bob D] #5449495 06/09/20 07:12 AM
B
buster Offline
B
I think Red Line is a great high end choice. With Redline the detergency and dispersibility of the oil influences the results of the UOA. Additionally with Red Line you'll often see high Pb initially due to the oil reacting with the oxides on the surface. You need several oil changes with Red Line to really establish a trend.
Report looks good. You won't see a viscosity drop with Red Line. It will only go up over time.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: 2014 5.7 Charger UOA [Re: Gasbuggy] #5450126 06/09/20 10:13 PM
G
Gasbuggy Offline
G
Originally Posted by 4WD
Run Redline 2k-3k ?
Cut his 10k interval by 2k-3k.
