Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
83 registered members (555, 4WD, Astro14, 77GrandPrix, 55hambone, 97tbird, 13 invisible), 1,505 guests, and 24 spiders.
Topics307,432
Posts5,310,899
Members71,847
How to rebuilt a starter #5446862 06/05/20 12:11 PM
L
LazyDog Offline OP
L
Hola,
I am looking for a you tube video that shows how to rebuilt and lubricate a starter properly.. Way to many video options but not sure which is done correctly.
Thanks,
Re: How to rebuilt a starter [Re: LazyDog] #5446872 06/05/20 12:25 PM
J
JMJNet Offline
J
Depends on what kind of starter? There are a lot of types.
For example:
If you have the Denso starter used in old Camry (the cross section of solenoid looks like a pentagon), it is very easy to rebuild just by replacing the contacts on the solenoid and it is usually good enough.
If you have GM starter for the diesel truck, it is a lot more involved than just replacing the contacts or the solenoid.
You just have search on Youtube on which one is suitable for you and discern which one is a better rebuilt instruction out of so many.
JMHO.
  • 2017 Toyota Sienna
Re: How to rebuilt a starter [Re: LazyDog] #5446978 06/05/20 02:35 PM
L
LazyDog Offline OP
L
I have a Bosch starter just trying to find a good video on how to properly rebuilt them, killing time does all.
Re: How to rebuilt a starter [Re: LazyDog] #5447000 06/05/20 03:06 PM
R
ragtoplvr Offline
R
Most Bosch solenoid caps are crimped on. You will need to be able to buy a new solenoid since opening it and renewing the contacts requires tools you will not have.. Next is brushes. Permanent magnet starters the entire brush assy. is replaced. you will need to find that part. Wound field starters, the brushes are usually spot welded. . Next is the drive. The equipment to open, replace springs, clean and reassemble a crimped drive is expensive, so you will need to buy a new drive. Unless you have the ability to buy wholesale. those parts will cost more than a reman starter.
Some starters have a failure point, like NipponDenso contacts, but you said Bosch Old delco starters are easy to renew, they were easy to disassemble, cap and brushes screw on, drives usually very robust and can be reused.
Sadly, those days are gone.
Rod
Re: How to rebuilt a starter [Re: LazyDog] #5447704 06/06/20 01:08 PM
W
willbur Offline
W
You are in luck. YouTube “110 Bosch Starter” Very good video. I just did my Bosch using that video and ragtoplvr from here. Be sure to block brush springs if you plan on reusing them
