Forums Migration
Please read this thread
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
97 registered members (ABN_CBT_ENGR, 4WD, Anthony, 2003f7, AndyB, 2015_PSD, 9 invisible), 1,730 guests, and 33 spiders.
Topics307,542
Posts5,312,757
Members71,870
Oil pickup cleaning without removing pan? #5446823 06/05/20 11:14 AM
J
joshuawesl Offline OP
J
I have a suspicion that my 4.7 Dodge engine may have some gunk/sludge/debris/whatever in the oil pickup tube. It may not, but I'm taking no chances. The pan is a pain to remove, especially without a lift and working in the gravel driveway. So ideally I'd like to attack this with the pan ON.
I'm going to borrow an inspection camera and have a peek at what's inside the oil pan this weekend. If all looks okay, then that's that. If not though... I need a plan to clean what I can.
I've thought of a few different ideas, I'll let the experienced wrenchers weigh in on what might be best for me. Yes, I know pulling the pan is best - but that just isn't an option right now. This is pan on.
Idea 1 - Insert a small toothbrush into the drain plug hole and attempt to scrub whatever is on the screen off.
Idea 2 - Insert the little red spray straw end of a can of brake cleaner into the drain plug hole, and spray the screen with it.
Idea 3 - Drain the oil, pour a gallon of kerosene in the oil fill, and let it sit overnight / a couple days. Drain, flush with cheap oil, refill.
Idea 4 - Drain the oil, pour a gallon of kerosene in the oil fill, disable the ignition, and crank the engine in 2 or 3 second bursts. Let sit overnight, drain, flush, refill.
I'll go ahead and mention here, that I am in the process of doing a Seafoam flush. I was about a quart low on oil, so I dumped an entire can of Seafoam down the oil fill. Started up, let it run about a minute, and shut back off. Haven't started since then.
Thoughts?
Re: Oil pickup cleaning without removing pan? [Re: joshuawesl] #5446853 06/05/20 11:58 AM
B
BMWTurboDzl Offline
B
I like #3 if no #1 isn't feasible.
435i
Re: Oil pickup cleaning without removing pan? [Re: joshuawesl] #5446855 06/05/20 11:59 AM
CT8 Online Content
Online Content
I am not sure about sea foam but I would try a gunk like product or run an oil change with Red line oil. The expensive Redline oil
2015 F150 2.7
2018 F350 6.2
Re: Oil pickup cleaning without removing pan? [Re: joshuawesl] #5446857 06/05/20 12:01 PM
K
Kira Offline
K
1) Do you know what the pan has in the way of baffling? You mightn't be able to reach the pick-up with a tooth brush.
2) This has crossed my mind before except with using lacquer thinner or acetone for the soak.
Actually, people progress with flushing cleaners for cooling systems so why not this application? Starting with Purple Power, then kero, then lacquer thinner.
The dollar store product, "The Works", might be good for the soak. You've nothing to lose.
Once I posted my thought somewhere and someone advised not to RUN the engine on lacquer thinner.
Re: Oil pickup cleaning without removing pan? [Re: Kira] #5446879 06/05/20 12:33 PM
cknight49090 Offline
If you already have sea foam in it and it wasn't past due for an oil change I would run it 500 miles and then change it.I don't anything else you do will do much more.I would of used berrymans or diesel, kerosene, but seeing as how you have put 10.00 worth of sea foam I would run it for 500.This should of been my first question what makes you think the pick up is clogged?
Re: Oil pickup cleaning without removing pan? [Re: joshuawesl] #5447004 06/05/20 03:11 PM
Z
Zaedock Offline
Z
A toothbrush poking in the drain hole is bad karma. One slip, and you're pulling the pan to get the tooth brush out.
Stick to a liquid diet.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Oil pickup cleaning without removing pan? [Re: joshuawesl] #5447012 06/05/20 03:19 PM
L
Lubener Offline
L
What makes you suspect a clogged pickup? It would take a lot of neglect to sludge one up. If you are really sure, I like option 5. Take the pan off and do it right. I know a few who did the engine flush only to dislodge so much sludge, plugging an oil passage to a bearing and a locked up engine resulted.
The "thinking" man's friend.
Re: Oil pickup cleaning without removing pan? [Re: Zaedock] #5447072 06/05/20 04:54 PM
CR94 Offline
Originally Posted by Zaedock
A toothbrush poking in the drain hole is bad karma. One slip, and you're pulling the pan to get the tooth brush out. ...
Also, even if you're able to reach the pickup from the drain opening with a toothbrush, the angle of the bristles will be wrong.
2011 Toyota Prius now at 111K
Re: Oil pickup cleaning without removing pan? [Re: joshuawesl] #5447105 06/05/20 05:25 PM
B
bulwnkl Offline
B
Auto-RX
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Oil pickup cleaning without removing pan? [Re: cknight49090] #5447292 06/05/20 10:16 PM
R
Rhymingmechanic Offline
R
X2
Unless I knew for sure a new-to-me vehicle had problems, I would just do an oil change and run it for a reasonable OCI. That way you can see how much it burns or leaks, and what the oil looks like after a full run. I might also cut open the filter afterward.
