Forums Migration
Please read this thread
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
88 registered members (A310, 2strokeNorthstar, 4WD, 53' Stude, Audios, Averroes, 8 invisible), 1,994 guests, and 24 spiders.
Topics307,769
Posts5,317,433
Members71,914
pressure washer care #5446392 06/04/20 08:06 PM
R
raaizin Offline OP
R
I have a Ryobi electric pressure washer. What is proper care for storing, I have been adding the pressure washer pump protector when not in use for extended time. Is this necessary, is there something I could do with something I may have around house instead of purchasing this product
Re: pressure washer care [Re: raaizin] #5446397 06/04/20 08:12 PM
spasm3 Online Happy
Online Happy
With a short piece of garden hose and a funnel, you could add rv anti-freeze until it comes out the other port of the pump.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: pressure washer care [Re: spasm3] #5446402 06/04/20 08:16 PM
R
raaizin Offline OP
R
would that lubricate the pump?
Re: pressure washer care [Re: raaizin] #5446403 06/04/20 08:18 PM
spasm3 Online Happy
Online Happy
Its in the instructions for my pressure washer, yours may vary.
Re: pressure washer care [Re: raaizin] #5446590 06/05/20 05:04 AM
dlundblad Online Happy
Online Happy
^Dad has the 13 hp hot water unit from Northern Tool. The instructions say the same thing minus step 2 since the heater needs winterized. Pour it in with the engine running until solid pink comes out. No pump saver IIRC.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: pressure washer care [Re: raaizin] #5446617 06/05/20 06:01 AM
J
joekingcorvette Offline
J
I have the regular gas pressure washer and they make an aerosol can of pump lube. All you do is unhook the water hose inlet and outlet and give it a short blast until it comes out the other side. I have also used the funnel trick as listed by a previous poster and it costs less money but is more difficult to do.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: pressure washer care [Re: raaizin] #5446692 06/05/20 08:05 AM
Driz Offline
PUT A FUEL SHUT OFF ON IT, if not equipped. Make a habit of shutting the fuel off to shut it down, ALWAYS. Your carburetor will thank you down the road.
Aside from that get a QD for the pressure wand hose. So much easier dealing with the 25’ anaconda. It also lets you drain the hose so you can store it in a cold shed and use it in winter.
Re: pressure washer care [Re: Driz] #5446695 06/05/20 08:10 AM
R
raaizin Offline OP
R
Re: pressure washer care [Re: raaizin] #5446726 06/05/20 08:43 AM
H
hatt Offline
H
I've never done anything to store my pressure washer. Over 20 years old. It's not cold here though.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: pressure washer care [Re: hatt] #5449999 06/09/20 07:32 PM
A
antonmnster Offline
A
Please, there's no need to rub it in!
2007 BMW 335i n54 218,000 miles, lubricated by whatever is on sale
Re: pressure washer care [Re: raaizin] #5458167 06/19/20 11:37 PM
R
ruSSrt Offline
R
Do you store it outside in the shed or in the garage?
If in the garage once you done, tilt it on the side and have water pour out. Done...... Till next summer.
If not in heated area, same steps but leave it on the side longer so more water drains out. Done.
2001 Ram 2500 Cummins
2005 VW Passat TDI
2011 Jeep Liberty 3.7L
