Forums Migration
Please read this thread
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
86 registered members (Alaskanmont, 2004tdigls, A310, 2strokeNorthstar, 4WD, 53' Stude, 8 invisible), 1,995 guests, and 26 spiders.
Topics307,769
Posts5,317,433
Members71,914
Page 1 of 3 1 2 3
List Impossible Sparkplug Replacement #5446131 06/04/20 01:31 PM
B
borgward Offline OP
B
There needs to be a list of cars requiring Engine disassembly or engine removal to replace sparkplugs. First one I encountered was the Pinto re badged as a mustang with V8. You had to unbolt a motor mount and jack up the engine to replace them on one side. Late 70's or early 80's.
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446140 06/04/20 01:43 PM
T
TmanP Offline
T
That would be a pretty long list... many transverse V6 would fall under that category, for sure. Off hand, two I remember - GM 3800s are very tight, so many people unbolt a motor mount and tip the engine forward. Tthe Sienna's 2GR-FE back plugs are completely hidden; the intake manifold usually comes off to replace them.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446150 06/04/20 01:57 PM
I
Imp4 Offline
I
My Toyota 3.0 1MZ-FE required removal of the intake manifold to get to the back plugs. Made for a long weekend for a shade tree mechanic.
Re: List Impossible Sparkplug Replacement [Re: TmanP] #5446153 06/04/20 01:58 PM
T
Tman220 Offline
T
I've found W-bodies with the 3800 to be pretty easy actually. It's pretty much any GM car with the 2.8, 3.1, 3100, 3400 60 degree v6's that usually require a special tool to tip the engine forward. Unless the 3800 you are speaking of was in a minivan? Those are never easy.
My personal contribution would be my 94 camaro with the Lt1. When it had stock exhaust manifolds (they are above the plugs), AIR injection plumbing, they were pretty tough to get to. My first plug change it was obvious that the #8 plug (passenger side rear) had never been changed, due to the other 7 being a obviously newer AC Delco's. removing the starter and getting it from below the car was pretty much a requirement.
In contrast, now that the emission equipment is gone, has long tube headers, its about a 30-45 minute job.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 170k
2004 Civic LX M5 190k
2007 Camry 2.4 250k
2016 Victory Vegas
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446155 06/04/20 01:59 PM
Chris142 Offline
70's chevy monza with a 305.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446156 06/04/20 02:06 PM
simple_gifts Offline
Buick Rendezvous; after a tuneup and misfire diagnosis, mechanic instructed my friend to "never bring it back"
2004 Prius; 134K; ATM
2007 Yaris 114K M1 ESP 5W-30
2006 B2300;137K;ALM
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446157 06/04/20 02:06 PM
M
MacManus99 Offline
M
Just did my the plugs in my wifes Escape V6. Once the upper intake plenum is removed, the back plugs are easy to get to. Removing the intake plenum becomes much easier after you do it once or twice, non issue really. Just remember to replace the plenum and EGR gaskets. And try not to break the assortment of 10 year old, 160k miles heat cycled plastic clips. WWF
2016 Chevrolet 2500 - 6.0L
2013 Scion FR-S - 2.0L
2012 Ford Escape - 3.0L
Re: List Impossible Sparkplug Replacement [Re: Tman220] #5446164 06/04/20 02:13 PM
satyr64 Offline
I agree with my 94 Camaro LT1 . I changed the wires and distributor at the same time as the plugs. The next time at approx. 60 k the hesitation started and needed new distributor The car was sold instead.
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446167 06/04/20 02:27 PM
B
blufeb95 Online Content
Online Content
B
3L Ford/Mazda Duratec, gotta remove that intake plenum to get to the rear plugs.
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446175 06/04/20 02:41 PM
ScottyB Offline
if i remember right, if you used some certain aftermarket headers on a Ford 302 with GT40 heads, you couldn't remove the plugs, at all, without dropping the headers. now that would suck!
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446176 06/04/20 02:41 PM
K
kschachn Online Content
Online Content
K
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446216 06/04/20 03:44 PM
another Todd Offline
I could never replace the spark plus on any diesel I have ever owned...I could never find them! grin
2019 Jeep Cherokee Trailhawk V6
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446248 06/04/20 04:37 PM
V
VQLT Offline
V
#6 cylinder on the early model (WD21) Nissan Pathfinders
Re: List Impossible Sparkplug Replacement [Re: another Todd] #5446252 06/04/20 04:40 PM
I
Imp4 Offline
I
Too busy looking for the muffler bearings?!?
Re: List Impossible Sparkplug Replacement [Re: borgward] #5446253 06/04/20 04:41 PM
cb_13 Offline
Chevy Astro van
Page 1 of 3 1 2 3
