QUICKSILVER M/C OIL
by Smoky14 - 07/02/20 10:28 AM
Nissan 15208-31U0A
by HDoilDude - 07/02/20 09:14 AM
New plugs better low end torque?
by Lewis - 07/02/20 08:37 AM
How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
shleeh, Diesegas, bigmike323, SolsticeSHO, Bazza32
71830 Registered Users
77 registered members (Barkleymut, 2015_PSD, Al, Astro14, 1978elcamino, bdcardinal, 4 invisible), 1,898 guests, and 45 spiders.
Topics307,319
Posts5,308,976
Members71,830
Shell Rotella Gas Truck 0W-20 UOA Honda Civic #5446084 06/04/20 11:50 AM
Davejam Offline OP
Results are in for Shell Rotella Gas Truck 0W-20 in a 2013 Honda Civic (1.8L, non-turbo)
From this earlier post I was looking for High Ca/High Moly oil:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5250127/1
I arrived at Shell Rotella Gas/Truck. It was also on rebate.
Results are about in-line with prior results on Idemitsu Eco Moly.
TBN was quite a bit lower, but that did not affect wear metals. Probably couldn't go much longer, but I wouldn't want to go more than 8-8.5K mi anyway between oil changes.
I was spiking the Eco moly with a little ZDDP, so z/p were elevated intentionally. May do that on this current interval.
I used the Shell Rotella again, so will have another data point to report in another 6 months.
Any comments? This is a decently controlled experiment, so let me know if there are other suggestions.
Fortunately or unfortunately this engine is pretty robust so may be difficult for anything to look significantly better/worse.
[Linked Image]
[Linked Image]
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: Davejam] #5446139 06/04/20 01:42 PM
dave1251 Offline
You can go to 10K easy which is the factory recommended OCI IRC. There is a lot of life left in that oil. It's in the 20 grade range with no signs of oxidation. It's a boring UOA.
don't use.
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: Davejam] #5446144 06/04/20 01:51 PM
dogememe Offline
Did your Honda Civic grow a 6ft bed since you used truck oil?
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: Davejam] #5446154 06/04/20 01:59 PM
M
MacManus99 Offline
M
Boring is good as far as UOA's go.
My FR-S sprouted a fold out tow mirrors, a stack, and goofy dished mud tires when I switched to RGT.
2016 Chevrolet 2500 - 6.0L
2013 Scion FR-S - 2.0L
2012 Ford Escape - 3.0L
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: Davejam] #5446194 06/04/20 03:11 PM
J
js1956 Offline
J
That's some serious Mo in that oil. Lot of test results I've seen Mo was usually in 70 - 130 range.
2015 VW Golf Mk7 2dr HB Man 1.8 TSI S
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: js1956] #5446231 06/04/20 04:07 PM
Davejam Offline OP
Yeah, i went and searched some other VOA/UOA and it should be about 160-170.
I didn't actually change the oil filter, but i wouldn't think that would affect it that much. Guess next oil change will tell.
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: Davejam] #5446232 06/04/20 04:09 PM
J
JerryBob Offline
J
Some of that moly could be residual from the Idemitsu. This thread indicates that Rotella has less moly than shown in the UOA.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5052361/rotella-gas-truck
Re: Shell Rotella Gas Truck 0W-20 UOA Honda Civic [Re: Davejam] #5446400 06/04/20 08:15 PM
M
maverickfhs Offline
M
Any only oil changes on R18 motor gives me a big smile laugh
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
