Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
21 registered members (dervdave, Duke, farrarfan1, bernardch, bbhero, Falcon_LS, 4 invisible), 745 guests, and 21 spiders.
Topics307,436
Posts5,311,047
Members71,848
best vendor for 2013 vw passat 2.5 replacement battery #5446009 06/04/20 10:20 AM
J
jstert Offline OP
J
my battery is original but tests fine according to trusted vw dealership as of yesterday when passat got its 90k service. still i’m thinking of a preemptive replacement because of its age and it sits for 4-6 weeks regularly (impossible to trickle charge at my apartment) when i’m (was) flying abroad and to sw.
i’m a total newbie on car batteries despite reading the good information here, so i am just asking about which vendor is best to trust for a decent battery, correct installation and an easy nationwide guaranty? i (used to) drive my passat alot around east of the mississippi and i plan to relocate so having the latter is important to me.
vw dealership and batteries+ offer top of the line, recommended battery for $200, or aaa for $160. it seems that wm is leaving the car care business and i’m not a costco member. i rather not deal with military px anymore for car care because when bases lockdown i’m then s.o.o.l. in an emergency.
thanks for your advice!
2013 vw passat s
2014 toyota yaris l
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5446024 06/04/20 10:30 AM
W
wings&wheels Offline
W
Did some research on batteries for limited use cars and I am now converting the fun fleet to Advance Auto Platinum AGM's as I replace them. First ones were done in 16 and still going strong, test as new.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5446027 06/04/20 10:33 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If the car sits so much, Id look at an AGM and a maintenance charger for when you have the chance. Deka makes a good one AGM, battery minder makes a good charger, as does NOCO and CTEK. I had great experiences with them even on old euro cars with weaker alternators and lower voltage regulation.
AGM has lower self-discharge. The car has some parasitics, and the battery loses some charge internally. AGM can tolerate both better.
Id want a battery with the most reserve capacity (RC) and total capacity in Ampere-Hours (Ah).
Id top it up with AC power from home when you have a chance, as an alternator never fully charges the battery.
If youre that concerned, you could carry an additional battery and jumper cables (since it is disconnected, it will lose charge less), or a jump pack (which is more money for less capacity). You might just not return your old one, if in good condition and not leaking anywhere (clean it with baking soda-water and then pledge). Keep it topped up when at home and then keep it in your trunk when parking the car.
You could also look at a battery disconnect switch. This will remove the battery parasitic draws...But could also remove ECU, transmission and other control system memory data...
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5446031 06/04/20 10:33 AM
G
Gebo Offline
G
If it checked fine yesterday, I wouldn't be concerned. I'd check it again it 6 months. I have a battery checker i paid about $25 for and I use it every 6 months on my batteries.
I no longer get stranded. BUT, if it is a 7-8 year old battery, you would not be making a bad decision to replace it.
I only buy my batteries from the dealer.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5446050 06/04/20 10:54 AM
supton Offline
I thought it was in Canada that Walmart was leaving TLE? I've not heard of them leaving in the USA, maybe I missed that memo.
If it was me I'd probably just go to Walmart. Then again, if you have 7 years out of the OEM battery, there's something said there (if it's the same manufacturer). Just buy another one and forget about it for 7 more years.
Didn't VW used to ship cars with solar cells that went in the windshield to top off the battery? I wonder if you could get something like that, shouldn't need that much light to keep the battery from discharging too much.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5446138 06/04/20 01:37 PM
R
ryster Offline
R
I replaced the 4.5yr old OEM battery in my Chevy with an Autocraft battery from Advance Auto Parts.
My parents both needed new batteries recently (one Ford, one Toyota) and we did it at home with Champion batteries from Pep Boys.
All of the new batteries were manufactured by Johnson Controls. They have been just fine.
I always try to balance price, warranty, and ease of getting a replacement under warranty if needed.
2015 Chevrolet Equinox LT AWD
3.6L V6
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5447472 06/06/20 07:51 AM
DuckRyder Offline
I’d replace it when it goes bad... I don’t understand the whole replace because it might fail scheme...
VW replacement batteries are not that expensive, the ones I’ve seen recently are johnson controls... compare specs then weight then warranty.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: best vendor for 2013 vw passat 2.5 replacement battery [Re: jstert] #5447538 06/06/20 09:23 AM
J
jstert Offline OP
J
thanks all!
2013 vw passat s
2014 toyota yaris l
