FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
63 registered members (Alaskanmont, Astro_Guy, Audios, 2010Civic, BigGeo, 2002 Maxima SE, 3 invisible), 1,275 guests, and 43 spiders.
Topics307,398
Posts5,310,384
Members71,843
Page 1 of 5 1 2 5
How Often Do You Check Your Oil? #5445991 06/04/20 10:04 AM
G
Gebo Offline OP
G
How often do you check your oil? I know it will be different if you have a car that uses oil versus one that doesn't.
Since I do mostly 3K OCI's, I don't check the oil in those cars. The one I do 5K, I check it every couple of months.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: How Often Do You Check Your Oil? [Re: Gebo] #5445992 06/04/20 10:05 AM
T
tbm5690 Online Content
Online Content
T
Every couple of months for me.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport/Tech
2007 Honda Shadow Spirit VT1100C
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446005 06/04/20 10:16 AM
supton Offline
Once a month or so on the ones that don't use oil. The one that does I do once a week or every other. It needs oil about once a month, give or take.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446011 06/04/20 10:21 AM
M
MaximaGuy Offline
M
On newer vehicles NEVER and older ones every 3k
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446015 06/04/20 10:26 AM
B
Blkstanger Offline
B
I pop the hood on my vehicles once a week for a little going over. My work truck gets a Pretrip everyday.
99 Jeep WJ 4.7 205,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 81,000mi. Castrol Edge 5w30 Fram Ultra.
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446020 06/04/20 10:28 AM
caprice_2nv Offline
Every couple weeks. My 76 350 Olds, 83 Chevy 305, and 05 4.8 Silverado all use about a qt every 2-3k miles. I usually check it like 5 times before I actually have to add half a qt.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446022 06/04/20 10:30 AM
P
PowerSurge Offline
P
Every fill up. Old habit from teenage years even though I never need to add.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
America First
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446029 06/04/20 10:33 AM
K
khittner Offline
K
On my oil-burning '02 Camry (295K miles) every 500 miles (it uses 1qt. every 1000-1200 miles), and the same on my '95 Dakota (238K miles), depending on whether it's been hauling at highway speeds. My other two non-oil-burners get checked once or twice between 5K changes.
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446030 06/04/20 10:33 AM
JustN89 Offline
Once or twice during an OCI (6+ months). Really just depends on my vehicle, though. My ZJ had a leak at the adapter, so I checked the oil level once a month. My current cars now, no leaks/no burning, so I only check once or twice between intervals.
You know what they say, cross threads are tighter than locktite!
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446045 06/04/20 10:44 AM
M
Miller88 Offline
M
My truck uses oil, sometimes quite a bit of it, so I usually check that every time I drive. I stopped putting TCW3 in the gas (ran out, forget to buy more) so it's back up to about 1 quart every 200 when towing (yes, there is a cloud of blue smoke trailing me). My Jeep I check every time I use it, usually once a month.
The Subaru has a low oil level light so I don't check it as often. With the exception it used 1/2 quart over 6K miles on M1 AFE 0w30, it's never used any oil. So I don't worry too bad.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446046 06/04/20 10:45 AM
T
TmanP Offline
T
Usually every month or two, and most often when cleaning windows/prepping car for a longer trip. If it's a long road trip I might check it at a gas station, but none of our vehicles needs makeup oil.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446060 06/04/20 11:13 AM
B
BAJA_05 Offline
B
Probably once a month or when the mood strikes me for all cars/truck.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (48K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446068 06/04/20 11:23 AM
R
ryster Offline
R
Usually once a month check of the oil during a random fuel fill-up. It is easiest at the gas station because they have paper towels right there and the ground is level.
2015 Chevrolet Equinox LT AWD
3.6L V6
Re: How Often Do You Check Your Oil? [Re: Gebo] #5446071 06/04/20 11:28 AM
B
borgward Offline
B
Usually only before 6000 mile oil change. 2013 Fiesta 50,000 + miles. Never seems to go down on the stick. I do check before a long trip. Might even change oil before 6000 mile schedule if the trip will put me much past 6000 miles OCI.
Re: How Often Do You Check Your Oil? [Re: ryster] #5446073 06/04/20 11:29 AM
supton Offline
I either do it on the weekend, like first thing Saturday morning, or at lunch time, while at work (just take a lazy stroll out to the parking lot). The oil has all drained down and all I have to do is pull the dipstick.
Page 1 of 5 1 2 5
