Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
50 registered members (ArrestMeRedZ, Alaskanmont, alex16, Alex38, bbhero, 3 invisible), 849 guests, and 24 spiders.
Topics307,436
Posts5,311,032
Members71,848
Need help with CV Joint grease, very limited choices #5445946 06/04/20 08:41 AM
L
leoblack9 Offline OP
L
Hello, I'm from Southeast Asia region and from where I'm from the choices for CV join grease are extremely limited. So far what I've found that only Mag1 Moly grease and Spaanjard MPG 1646 is available locally.
Other locally available is the ones that come from replacement boot kits and I don't want to buy random grease from replacement boots. Are any of these two choices viable for use as outer CV joint grease?
I'm repacking my original axles, suzuki alto k10b model.
Thanks for your input.
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5445951 06/04/20 08:51 AM
Chris142 Online Content
Online Content
Mag-1 is made by Warren here in the USA. Their oils are very good.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Need help with CV Joint grease, very limited choices [Re: Chris142] #5445953 06/04/20 08:58 AM
L
L
thanks for the quick response, my question is that since the product doesn't specifically mention its compatible with cv joints (but does have molybdenum disulphide and EP additives) is it a viable choice? Or should i look elsewhere?
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5445965 06/04/20 09:28 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Im only really familiar with old MB axles, which used a heavy oil (maybe a 00 grease?) in them.
Here in the USA, the parts stores sell CV joint grease:
https://www.crcindustries.com/products/constant-velocity-cv-joint-grease-4-wt-oz-SL3174.html
Product data sheet is here:
http://api.crcindustries.com/auto-services/get-pds/SL3174
Interesting thing there is it says ISO 110 viscosity. Thats like a "light" 90W gear oil (but likely different adds) with MoS2.
There are some mixed points in an old thread here:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/864649/cv-joint-grease-anything-special
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5445969 06/04/20 09:36 AM
K
kschachn Offline
K
One should always be careful to understand what the specific manufacturer recommends or specifies for any application.
Having said that, for my BMW it can use Liqui Moly LM2003 which may be available in the Philippines somehow.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Need help with CV Joint grease, very limited choices [Re: kschachn] #5445977 06/04/20 09:47 AM
L
L
Thanks, I've seen that thread before and one of the posts influenced me into picking grease with MoS2. I'm afraid CRC's cv joint grease is nowhere to be found locally
Oh believe me I try to adhere to oem as much as I can. I've had my axles repacked last year with a very expensive dealer job, $100 for a set of oem boots, clips and a NTG 2218-M grease. The passenger side outer CV joint clips failed months after and it threw grease all over the place. I'm only replacing this one.
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5446008 06/04/20 10:20 AM
N
nthach Offline
N
Be careful - the Japanese OEMs like to use a tripod type inner CV joint and if that's the case a non-moly lithium or polyurea semi-fluid grease is used. You don't want moly for a roller or needle bearing but the Repezza type joints with ball bearings seem to do OK with stiffer moly greases.
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5446016 06/04/20 10:26 AM
G
Gebo Offline
G
Have you checked the prices of rebuilt Suzuki axles? Not some aftermarket junk but Suzuki rebuilt. Do they sell rebuilt axles?
Might be better and easier than doing all the repacking and rebooting shrug
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Need help with CV Joint grease, very limited choices [Re: Gebo] #5446040 06/04/20 10:41 AM
L
L
Don't worry, my inner CV joints are all repacked well and are sporting the oem factory grease (NTG 2218-M). Its the outer passenger CV joint i'm going to repack. Lithium moly grease is what a lot of forum posts have pointed me to and I'm only asking this to reconfirm.
Nonexistent, its either you buy junkyard/surplus or go replacement axles which are of questionable quality. This country is toyota land, where every brick and mortar store have toyota parts in them, but almost none of the other brands.
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5446118 06/04/20 01:17 PM
Ded Mazai Offline
You are correct, the greases you have found are not intended for use in CV joints. I would look further.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Need help with CV Joint grease, very limited choices [Re: nthach] #5446481 06/04/20 10:17 PM
N
nobb Offline
N
I have also noticed on my Toyota they use a different grease for the inboard and outboard joint. But don't all CV's use needle bearings on the inner joint? I have never ever heard of a lubrication related failure on a CV joint provided that the boot is intact.
Re: Need help with CV Joint grease, very limited choices [Re: nobb] #5446568 06/05/20 03:36 AM
L
L
That's unfortunate. The only CV joint grease that's accessible in my area are those that are bought with replacement CV joints. I'm gonna have to look around more then.
My suzuki, like toyota's have Tripod inner CV joints and Rzeppa outer joints. Inner joints have those fine needle bearings and I've read all around the web that Moly grease should be avoided at all cost on this type of bearings due to moly causing the fine bearings to slip (flat spotting) But, just like you, I have never found a post that has this happen to anyone.. yet.
Re: Need help with CV Joint grease, very limited choices [Re: leoblack9] #5447281 06/05/20 09:51 PM
N
nobb Offline
N
The rumor of moly not being good on bearings is somewhat of a myth IMO because you'll get alot of modern greases with the GC-LB rating which specifically means it is good for a bearing application. There is the belief that moly is good for shearing loads and not rolling. I've had to rebuild the CV joints on my 4Runner several times due to boots that never seem to last, but I've been using standard moly CV grease on the inner and outer joints with no issue even after 100,000 kms. The grease might seem a bit thick at first, but after a few thousand kms of shear forces, the grease becomes nice and liquid and fills every bit of the joint nicely.
Re: Need help with CV Joint grease, very limited choices [Re: nobb] #5447427 06/06/20 06:51 AM
T
Trav Offline
T
Inner joint failure with the boot still intact is common especially with tripods. I have one car that tears the tripod joints up pretty regular when provoked (I keep a stash of OE joints) using OE grease.
After talking with Molakule and Schaeffers I am using the 219 SynForce Green NLGI 1 in them and the results look very promising. Although it contains organic moly Schaeffers said there is no issue using it in needle bearings unlike MoS2. This is one heck of a good grease.
https://www.schaefferoil.com/documents/302-219-td.pdf
Re: Need help with CV Joint grease, very limited choices [Re: Trav] #5447627 06/06/20 11:38 AM
N
nobb Offline
N
I've inspected the inner and outer joints on every rebuild and there has been no signs of wear using just the cheap CV grease that comes with the rebuild kits. It could also be that this is a 4x4 so it's operated 99% of the time in RWD mode and 4x4 is used only on rare occasions, so the joints mostly see no load. So in my case, grease is not much of a concern. Trying to get these crappy neoprene boots to last more than 30,000 kms however is another story.
