Forums Migration
Please read this thread
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
45 registered members (Bailes1992, alcyon, A_Spruce, avi1777, Autodiculous, Ag76, 6 invisible), 1,235 guests, and 29 spiders.
Topics307,780
Posts5,317,685
Members71,917
Chevy Positraction 1057721 #5445808 06/04/20 12:42 AM
R
rorty Offline OP
R
Are either or both of these following products equivalent to the above? : AC Delco Axle Lubricant SAE 80W-90 GL-5 10405-1 89021669 and GM Vehicle.Care Axle Lubricant SAE 80W-90 APL GL-5 89021669. If so, are these two products the same as one another? I own a 1987 Morgan Plus 8 with an unobtanium Salisbury LSD rear axle, so I cannot make a mistake in using a successor to 1057721. I want to use the correct product, one of these two or something else, with ACDelco Limited Slip Axle Lubricant Additive 10-4003 88900330. Any knowledgeable guidance would be appreciated!
Re: Chevy Positraction 1057721 [Re: rorty] #5445880 06/04/20 07:01 AM
B
benjy Offline
B
give redline a call, live tech + some of the best lubes at the higher price range.
Re: Chevy Positraction 1057721 [Re: rorty] #5445898 06/04/20 07:26 AM
Snagglefoot Offline
Also check with Yukon Gear
www.Yukongear.com
If you want the job done right......do it yourself.
Re: Chevy Positraction 1057721 [Re: rorty] #5445928 06/04/20 08:15 AM
Snagglefoot Offline
Here are some screen shots, firstly going back to what GM was using in 1987 in their diffs in trucks and two subsequent supersedes. Enjoy.
6274DBAC-1587-4658-A16F-3BD36E3B6CE1.png7B75B757-3697-41F1-8DEA-148752DCFA72.pngE262E503-6E23-43A3-AC7D-A4A9722FCBEF.pngBDAC8741-93B9-4B80-AAE4-922E43A1E773.png
Re: Chevy Positraction 1057721 [Re: rorty] #5446120 06/04/20 01:19 PM
R
Randy_R Offline
R
GM has the additive. Ford has their’s and I’m sure Mopar has one too. Also, check with any parts store. All should work just fine. Be sure you get the right viscosity for your application and you probably want conventional as opposed to synthetic. Couple years ago I did my 67 Chevelle 12-bolt with Valvoline 80W-90 conventional with the GM additive. Prior to that I used Kendall LS lube no additive required. Recently I saw Castrol LS lube at O’Reilly’s. Brad PennGrade also makes GL-5 LS fluid. My 04 Silverado came with synthetic so I replaced it with Mobil 1 LS.
2018 Mazda CX-5 10000 miles Zepro moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 70,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 Wix 51061
