Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
29 registered members (blufeb95, 19elantragt, BLND1, avi1777, BlakeB, bbhero, 2 invisible), 999 guests, and 23 spiders.
Topics307,781
Posts5,317,710
Members71,917
First Oil Change Recommendation #5445754 06/03/20 09:20 PM
G
gtpimp Offline OP
G
I have a Kawasaki FX801V with 15hrs on my Ferris mower. I was thinking about a Fram XG filter with Rotella T6 15w40 oil. Good idea? Is the filter overkill? Does T6 still have high zinc content? Thanks!
Re: First Oil Change Recommendation [Re: gtpimp] #5445781 06/03/20 10:28 PM
M
MParr Offline
M
I don’t see why not. Be aware some aftermarket oil filters may not work. Some will not seal well against the mounting flange. I found that out with my Toro equipped with a rebadged Loncin engine. On it, only OE filters (Toro/Exmark ), Fram 4967 family and STP S4967 will mate properly. Your oil pick should work. Kawasaki allow up 20W50.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: First Oil Change Recommendation [Re: gtpimp] #5445905 06/04/20 07:39 AM
T
thastinger Offline
T
My IS700 Ferris has the B&S commercial turf engine. For an oil filter I run a motorcraft FL400 filter, its a little bit of a tight fit but there is enough room for it on my configuration. For oil, I run mobil 1 euro 0-40 in it.
I don't know if the fl400 will fit the kawasaki motor though
Re: First Oil Change Recommendation [Re: gtpimp] #5445948 06/04/20 08:45 AM
CT8 Offline
I add the usual comment of what about the hydrostat oils?
2015 F150 2.7
2018 F350 6.2
Re: First Oil Change Recommendation [Re: gtpimp] #5445999 06/04/20 10:10 AM
G
Gebo Offline
G
I would use the Kawasaki OEM filter. They also make a Kawasaki oil just for your engine. Amsoil makes an oil just for small engines and they have
their own hydrostat transmission oils.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: First Oil Change Recommendation [Re: gtpimp] #5446047 06/04/20 10:46 AM
dwendt44 Offline
the XG3614 and the T6 are a great combination. THey will serve you well.
There is a longer filter but usually not enough room on Zero turns for it.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: First Oil Change Recommendation [Re: gtpimp] #5446067 06/04/20 11:23 AM
G
gtpimp Offline OP
G
The OEM filter currently on the mower is Kawasaki 49065-7010 which crosses to XG4967. Do you guys think it’s safe to make the switch to synthetic at 15hrs?
Re: First Oil Change Recommendation [Re: Gebo] #5446078 06/04/20 11:34 AM
dave123 Offline
I run both them oils and extremely happy with results
Re: First Oil Change Recommendation [Re: gtpimp] #5446517 06/04/20 11:31 PM
dwendt44 Offline
Quote
Sure. If that is what you want to do.
I'm a little more long term thinking in my case. I went to a semi-synthetic for the first change.
Full synthetic after that.
My 2¢
Re: First Oil Change Recommendation [Re: CT8] #5446601 06/05/20 05:22 AM
dlundblad Offline
With 15 hours, the HST is a non issue. A filter change and top off at the first 50 or whatever the manual says wouldn’t be a bad idea though.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: First Oil Change Recommendation [Re: gtpimp] #5446604 06/05/20 05:27 AM
dlundblad Offline
5w40 is a good choice. I like your thinking. I’m starting to use 0w40 in everything gas because I use it more than any other oil.
If you can find a substitute Ultra, it’ll work. It’s an overkill, but that’s it. No issues with the several Extra Guards I’m running on my ‘Bota GT’s. Less than $4 and changed yearly.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: First Oil Change Recommendation [Re: dwendt44] #5446608 06/05/20 05:44 AM
G
gtpimp Offline OP
G
My 2¢
I picked up the XG3614, compared it to the XG4967 and it looks nearly identical but longer. They were out of T6 15w40 but they had some 5w40, doesn't the 15w40 offer slightly more protection? Thanks.
Re: First Oil Change Recommendation [Re: gtpimp] #5448440 06/07/20 03:45 PM
N
Normac Offline
N
I’ve used Fram 3614’s and Harvest King (Rural King) 15w40 and have 512 hours on my Big Dog Z-turn with a Kawasaki FR-651V engine.
Starts right up, no smoke, and no oil consumption. The mower itself and hydros will wear out long before that engine.
Being an air cooled engine in the summer, even the conventional 15w40 will be fine. No need to over think this.
True victory does not come from defeating an enemy, true victory comes from giving love and changing an enemies heart.
Re: First Oil Change Recommendation [Re: Normac] #5448621 06/07/20 08:33 PM
P
polly Offline
P
Is it okay to use 0w40 Mobil 1 synthetic oil in my Kubota lawn mower. Please and thank you
Re: First Oil Change Recommendation [Re: polly] #5448624 06/07/20 08:35 PM
U
UncleDave Offline
U
D722 based?
Yes.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
