Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
85 registered members (2010Civic, 53' Stude, 4WD, 97tbird, 87sammy, Alfred_B, 7 invisible), 2,059 guests, and 26 spiders.
Topics307,451
Posts5,311,412
Members71,850
AC Flashing Light #5445558 06/03/20 05:13 PM
A
artbuc Offline OP
A
Re: 99 Toyota Avalon
Is it possible that a slightly low charge would cause this? Everything I can find says it is associated with the magnetic clutch, eg relay, speed sensor, amplifier or ground.
My AC was working fine and light started flashing. I turned AC off for a few minutes then turned it back on and it worked fine again. I think my charge may be a little low based on bubbles in sight glass. I will hookup gages tomorrow to get a better feel.
I replaced the condenser (road trash punctured it) many years ago and weighed in a factory charge. Has been working perfectly since then.
Thanks.
Re: AC Flashing Light [Re: artbuc] #5445566 06/03/20 05:20 PM
M
motts Offline
M
Have you gone through a deep puddle lately? That happens with my 02 Camry
Re: AC Flashing Light [Re: artbuc] #5445574 06/03/20 05:26 PM
M
mk378 Online Content
Online Content
M
This happens when the clutch is commanded to be engaged, but the compressor rpm measures slower than expected (including zero) versus the engine rpm. The A/C amplifier assumes the belt and/or clutch is slipping and is about to burn up. So it will lock out the A/C.
As you have read, there are a lot of parts involved. First step is to see if the clutch does engage and spin normally (for a second) before the light starts blinking. That would indicate a problem with the measurement. If the clutch doesn't even try to engage, or it engages and slips, something more fundamental is wrong.
Low charge will not cause it. Low charge makes the compressor easier to turn than normal.
Re: AC Flashing Light [Re: artbuc] #5445584 06/03/20 05:41 PM
M
michaelluscher Offline
M
If you haven't already, grab a new Denso relay for the underhood fuse box
Should be about $10 or so
This is common on Camrys, they intermittently fail
That's assuming all is well in the rest of the system
'20 XT4 Premium Luxury 2.0T, breaking in all the toys
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: AC Flashing Light [Re: artbuc] #5445588 06/03/20 05:53 PM
Chris142 Offline
It has a revolution counter as part of the magnetic clutch. It knows how fast the clutch should be spinning vs engine rpm. If it's spinning too slow or not at all it will blink that light. May be the relay as already suggested or something else.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: AC Flashing Light [Re: artbuc] #5445592 06/03/20 05:57 PM
F
FlyNavyP3 Offline
F
This happened on my ES330. New A.C. relay fixed the issue. $12 at Napa.
Luke
Re: AC Flashing Light [Re: artbuc] #5445598 06/03/20 06:03 PM
O
oldhp Offline
O
Doesn't the high pressure switch not let the compressor kick on if low on freon? I always thought it did.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: AC Flashing Light [Re: oldhp] #5445601 06/03/20 06:06 PM
Chris142 Offline
The Low pressure switch if it has one.
Re: AC Flashing Light [Re: motts] #5445641 06/03/20 06:53 PM
A
artbuc Offline OP
A
We were driving through a major frog strangler downpour. Maybe as simple as a slipping accessory belt?
Thanks to all for confirming low charge is not an issue.
Re: AC Flashing Light [Re: artbuc] #5445658 06/03/20 07:18 PM
T
t1snwrbrdr12 Online Content
Online Content
T
Slipping belt did this to my 11 sienna.
