2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
93 registered members (2015_PSD, bdcardinal, aquariuscsm, ArrestMeRedZ, 555, 94astro, 7 invisible), 2,085 guests, and 36 spiders.
Topics307,410
Posts5,310,580
Members71,843
Securing rubber hose to metal tubing? #5445331 06/03/20 01:15 PM
J
joshuawesl Offline OP
J
I'd like to add a transmission cooler to my newest vehicle purchase. I have one of those Hayden coolers and some rubber hose. I'm thinking I can cut the aluminum return line that leads back to the transmission and install the cooler here. I'm concerned with the rubber hose slipping off of the metal tubing though. Would hose clamps be enough? The tubing isn't flared or barbed. I figured I could take some sandpaper and scuff it really good, clean it with brake cleaner, and put two small hose clamps on each connection? Or should I try something different?
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445335 06/03/20 01:21 PM
Z
Zaedock Offline
Z
Hose clamps should be fine. What vehicle is this going on (engine too)?
Edit - Looks like it's the 4.7L Durango?
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445372 06/03/20 01:52 PM
ls1mike Offline
Buy a cheap flare tool. They are cheap and it is easy. When I install an aux cooler like that I always flare them. Takes 5 minutes then you don't have to worry.
My first motor home had an aux cooler, previous owner did not flare the lines and I had one blow of. Luckily it happened at startup.
A cheapo one like this works fine.
[Linked Image]
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Securing rubber hose to metal tubing? [Re: ls1mike] #5445376 06/03/20 01:56 PM
N
nwjones18 Offline
N
[Linked Image]
This is what I was going to say. I had a radiator installed and for whatever reason they hadn't flared the cooler return line and it leaked, even with multiple mega tight clamps on it until I took the time to flare it then reinstall the hose. No more issues after that.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445377 06/03/20 01:56 PM
R
Rhymingmechanic Offline
R
A cleaner way to do it (vs. cutting lines) would be to find a barbed fitting for your radiator outlet.
Then remove the return line from the radiator, install the fitting, and clamp one hose to the fitting and the other to the return line.
Most coolers I've installed had fittings in the kit.
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445405 06/03/20 02:28 PM
R
R
Here's a kit to do what I'm talking about. Click on the customer image.
https://www.etrailer.com/Accessories-and-Parts/Derale/D13030.html
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445448 06/03/20 03:29 PM
Chris142 Offline
We glue the hose on with Gasket cinch and add 2 hose clamps. Once it dries that hose will have to be cut off to be removed,.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445479 06/03/20 03:52 PM
E
eljefino Offline
E
Flare, baby flare!
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445495 06/03/20 04:06 PM
bdcardinal Online Content
Online Content
I totally missed the initial point if this and though you wanted to secure hose to a cage. There is a company called NotcHead that makes really cool little clamp fitting things for that purpose. https://www.youtube.com/watch?v=Vkub5Ls8qF0
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445600 06/03/20 06:04 PM
M
Mainia Offline
M
Use 2 of these and you will not have a problem. Spray them with Fluid Film after, so they don't rust is you are in the salt belt.
https://www.amazon.com/DYWISHKEY-Mu...ose+clamps&qid=1591225236&sr=8-9
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Securing rubber hose to metal tubing? [Re: Chris142] #5445682 06/03/20 07:44 PM
CT8 Offline
This.
2015 F150 2.7
2018 F350 6.2
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5445836 06/04/20 04:46 AM
L
Lubener Offline
L
Metal tubing has to be flared to keep it leak free and from coming loose. Bubble flare is best as a single or double flare such as a brake line can cut into the hose when you tighten the clamp.
The "thinking" man's friend.
Re: Securing rubber hose to metal tubing? [Re: Rhymingmechanic] #5445884 06/04/20 07:08 AM
J
J
Wow. That is cool! I think that's the route I'll go. No cutting, just adapt and install. Thanks so much for the idea!
Re: Securing rubber hose to metal tubing? [Re: ls1mike] #5445910 06/04/20 07:44 AM
B
BEETLE Offline
B
Rent "Flare Tool" at auto parts such as AutoZone or Oreily's for free as long you return it in a day or 2
84 Isuzu P/up - Fram PH3950 - QS HM 10w-40
08 Ford Escape - Napa 31348 - Motorcraft 5w-20
98 Ninja 250 - Wix oil filter - RotellaT6 - 5w-40
Re: Securing rubber hose to metal tubing? [Re: joshuawesl] #5446065 06/04/20 11:20 AM
R
R
I was surprised to see the one with two fittings, but it makes sense. The coolers I have installed had a fitting for the radiator and then I just clamped the other end to the factory line. The flare on those lines probably wasn't ideal for a hose connection.
The good thing about this installation is you can easily revert to stock if you need to.
