Forums Migration
Please read this thread
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
Oil Life Monitor
by rrretiree7 - 07/06/20 06:57 PM
94 F 150 Engine control module replaced
by Electromotive - 07/06/20 06:43 PM
OIL UDDER Q+A
by OIL_UDDER - 07/06/20 05:46 PM
Devil's Lake State Park near Baraboo, WI
by wwillson - 07/06/20 05:43 PM
New vehicle bug bit me again
by JTK - 07/06/20 04:56 PM
BakonBittz, ssoH, Sumpter_al, Jeffham87, chknkatsu
71867 Registered Users
23 registered members (19elantragt, edyvw, CrazyJeeper, blufeb95, ChristianBerg, 2 invisible), 875 guests, and 32 spiders.
Topics307,527
Posts5,312,597
Members71,867
Eezox vs Prolix? #5445266 06/03/20 11:49 AM
G
Gebo Offline OP
G
I have a question for you. I have Eezox and like it. I use it.
Somehow, I found this product called "Prolix." I called the company and was told they were the original Eezox.
Is the bull manure? I talked with this guy for a long time and I actually believe him.
Am I full of bull manure for believing him?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Eezox vs Prolix? [Re: Gebo] #5445293 06/03/20 12:21 PM
ABN_CBT_ENGR Offline
Cant say but I have used Eezox and its as good as any and I have no preference.
But EZ is a petroleum product (ester and trich per the SDS) and this other stuff says biodegradable, green, citrus and all that.
Hard to see those two having a common origin but someone who is a chemical engineer or chemist really should address that comparison.
Re: Eezox vs Prolix? [Re: Gebo] #5445297 06/03/20 12:26 PM
G
Gebo Offline OP
G
Hmmm...interesting...
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Eezox vs Prolix? [Re: Gebo] #5446017 06/04/20 10:28 AM
T
Triple_Se7en Offline
T
I don't use the new plant based CLP / gun oils anymore.Many get gummy, depending on where it's used - in what temperatures - where it's stored and for how long.
Do gun oil chemists and inventors move around from company to company - from recipe to recipe?...... yep, like fleas sometimes.
Stay Safe - Stay Healthy
Do a 2nd thought, before walking down the wrong path
Keep Your Korean TGDI / GDI engines clean-4k OCI
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Eezox vs Prolix? [Re: Gebo] #5446062 06/04/20 11:15 AM
G
Gebo Offline OP
G
I don't have experience in this area. I have an assortment of "all" the gun cleaners. LOL.
You can't believe most of what the internet says, YouTube says, etc.
I just started getting into guns and I want to take care of them the best I can.
Choosing a gun "cleaner-protectant" is harder than choosing an oil for our cars. crzy
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Eezox vs Prolix? [Re: Gebo] #5446087 06/04/20 11:55 AM
Here's some advice
Anything that cleans oil/grease ( basically carbon products) will clean a gun adequately( provided it doesn't react with a metal). I have used Dawn and purple stuff for degreasing prior to refinishing.
Mineral spirits, brake clean and 2 thousand others all work well on cleaning. Just a matter of how much you clean and want to spend.
Any oil will lubricate and protect adequately provided it doesn't emulsify with water easily or change with temperatures creating jamming up to and including 3 in 1or baby oil. I use straight 30.
Only surfaces that rub significantly might benefit with a grease over oil ( guns are textbook loose tolerance and boundary requirement)
Your "best" cleaner/protectant is to wipe down after handling and store in a low humidity area and do a functional clean after each use.
( guns don't really have to be fully cleaned after each use to function properly in most cases but that usage will blow or rub off the thin oil coat inviting corrosion)
Don't store where gravity may pull oil onto the furniture
Re: Eezox vs Prolix? [Re: Triple_Se7en] #5447393 06/06/20 04:41 AM
ChrisD46 Offline
+1 ... Plant based CLP's are ok for cleaning but not for lube and long term storage ! I have some Ballastol I transfer to a small , clear spray bottle and after sitting for three months the liquid contained chunks ... I had to shake it up real good to get the chunks to turn back into a liquid again . No thanks as a lube - now the go to's are : Lucas Extreme Duty , Weapon Shield , Slick 2000 EW and FP10 for lube .
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Eezox vs Prolix? [Re: Gebo] #5447504 06/06/20 08:37 AM
CT8 Offline
Syn atf or motor oil. Gear lube for the first few hundred rounds on the slides of higher end 1911s. Wipe out to clean the guns. Wipe out will remove some finishes on the furniture.
2015 F150 2.7
2018 F350 6.2
Re: Eezox vs Prolix? [Re: Gebo] #5447507 06/06/20 08:40 AM
CT8 Offline
No it is not. Don't be led by marketing claims.
2015 F150 2.7
2018 F350 6.2
