Forums Migration
Please read this thread
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
Oil Life Monitor
by rrretiree7 - 07/06/20 06:57 PM
94 F 150 Engine control module replaced
by Electromotive - 07/06/20 06:43 PM
OIL UDDER Q+A
by OIL_UDDER - 07/06/20 05:46 PM
Devil's Lake State Park near Baraboo, WI
by wwillson - 07/06/20 05:43 PM
New vehicle bug bit me again
by JTK - 07/06/20 04:56 PM
BakonBittz, ssoH, Sumpter_al, Jeffham87, chknkatsu
71867 Registered Users
26 registered members (19elantragt, blufeb95, alcyon, alchargo, 2 invisible), 834 guests, and 34 spiders.
Topics307,527
Posts5,312,598
Members71,867
Graphic Evidence Why You Need A Fuel Shut Off!! #5445073 06/03/20 08:07 AM
Driz Offline OP
This has been around a while but it bears repeating. Yes it’s more about winter storage but I’d extrapolate it to things not run on a regular basis.
https://youtu.be/UvS_D4_lF5U
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445078 06/03/20 08:19 AM
H
hatt Offline
H
Looks like it reinforces what people have been saying for years. Ethanol is doom to small engines that aren't used regular.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445079 06/03/20 08:21 AM
Donald Offline
E85 was never a good idea.
If it was not for the farmer lobby we would be back to E0 gasoline.
I only run E0 with blue Stabil in my OPE year round, every tank. (4 cycle). The 2 cycle gets premix.
2015 Ford F-250 w/Powerstroke
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445086 06/03/20 08:29 AM
Z
Zaedock Offline
Z
I love this guys videos.
As a small engine enthusiast, I appreciate the time and effort he puts in to tests.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445091 06/03/20 08:43 AM
supton Offline
So, fuel stablizer isn't worth using?
I've never watched Project Farm before; thanks for the link. Seemed, if not conclusive, then at least good data.
I'm not sure where I'd get E0 for my lawn mower, but since they're freebie projects so far, I'm not too worried. Somehow they've managed E10 for a number of years. I did buy a 25 year old ATV that had been sitting for 4 years with old gas in it; I did wind up replacing the fuel lines and the fuel pump, and both items had dusty white garbage in them. Didn't mess with the carb (yet) since it's been running good enough.
IMO E10 might have a place. I remember having to put dry gas into a vehicle or two as a kid. Maybe modern sealed fuel systems mitigate that need altogether, but I know I haven't used dry gas in years. Perhaps it doesn't belong in things that sit for long periods of time, but for other items maybe it's just fine.
IIRC straight cut gasoline is something like 60 octane. I have no idea how they can bump the octane of gasoline using only components available in crude oil, but ethanol does offer an octane bump. Dunno if it's overall worth it--growing corn to make ethanol uses a lot of ground water and has these water issues, but I'm not going to go out of my way to buy E0 when E10 hasn't caused me problems (yet).
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445099 06/03/20 08:52 AM
doitmyself Offline
The video demonstrates that Lucas brand fuel stabilizer does not work well for storing one inch of gasoline in a mason jar for one year sitting in a cabinet.
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Donald] #5445119 06/03/20 09:12 AM
B
BMWTurboDzl Offline
B
False. Ethanol is a substitute for MTBE which was phased out because of its toxicity.
435i
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445123 06/03/20 09:16 AM
K
kschachn Offline
K
EtOH is a conjunct additive with MBTE. It's primary usage was to reduce the dependence on crude oil, and came into more widespread use as MBTE use was curtailed and as the supply increased.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445192 06/03/20 10:28 AM
J
JohnG Offline
J
Quote
This is true enough, but it does not make Donald's statement false. There is really no need for an oxygenate in fuel.
The corn lobby keeps it alive, as well as the ENORMOUS investment made into the infrastructure to bring it to market. It does not ship well in pipelines. It is almost entirely moved to market by truck or train. Trucking it pretty much eliminates any air quality improvements that may be had.
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445211 06/03/20 10:47 AM
Davejam Offline
Cool video. I think you guys got the wrong conclusion.
E85 - which is never recommended for small engines will cause corrosion regardless of stabilizer.
E10 - stabilizer seemed to improve performance.
E0 - best, does not really need stabilizer.
I wonder how that Lucas fuel stabilizer compares to Stabil.
Stabil seems to be a more popular product and the one i personally use.
I typically use E10 fuel in small engines. Wish all had fuel cutoffs, but i guess you can just run it dry.
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445284 06/03/20 12:12 PM
M
mk378 Offline
M
MTBE isn't that toxic, but it readily mixes with water and just a few parts per million imparts an awful smell and taste. That revealed that gasoline in groundwater happens very commonly.
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: JohnG] #5445382 06/03/20 02:00 PM
B
BMWTurboDzl Offline
B
Originally Posted by JohnG
Quote
There really is a need because some areas of the country develop horrible air pollution without it. You obviously wouldn't experience it living in Daytona, but cities such as Houston, Atlanta, LA, Charlotte, etc would be in bad shape.
435i
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: Driz] #5445419 06/03/20 02:52 PM
dlundblad Offline
Somewhat OT, but say an engine was used regularly, but switched from E10 to E0 the last few tanks.
Would that create any long term issues?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: doitmyself] #5445458 06/03/20 03:34 PM
B
BISCUT Offline
B
Seems to me it showed a little more than just Lucas brand stabilizer (and to be specific it was more than just a stabilizer, no?). While not a controlled lab study it was a pretty decent general experiment.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(48k)
2017 Sub OB M1 5-30 EP FRAM Ultra(78k)
Re: Graphic Evidence Why You Need A Fuel Shut Off!! [Re: dlundblad] #5445873 06/04/20 06:50 AM
J
jeepman3071 Offline
J
Hard to say, if the engine is stored for any period of time with ethanol in the carburetor there is potential for corrosion. A lot of it depends on storage environment, and something stored inside will be better off than something left out in the rain.
In my area I only have access to E10 fuels, besides race fuel which I'm not spending the money on. I have had good luck in my machines over the last several years running a double dose of Marine Stabil in my fuel cans, and running equipment out of fuel (carb bowls dry) if I know it will be stored for more than a few days. My small engine customers that have been doing this haven't had any issues as well. A simple fuel shut-off valve in the fuel line can make this possible.
For the record I've never heard of the Lucas stabilizer used in the video.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
