2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
89 registered members (2015_PSD, bdcardinal, aquariuscsm, ArrestMeRedZ, 555, 94astro, 5 invisible), 2,088 guests, and 37 spiders.
Topics307,410
Posts5,310,580
Members71,843
Windows Movie Maker #5444696 06/02/20 02:46 PM
J
Jetronic Online Content OP
OP Online Content
J
I'm trying to master a movie dvd containing several hundred pictures, 5 small clips and 1 big 90 minute clip from my sisters funeral. I converted the streamed video using Any Video Converter to get a format that movie maker recognises and those videos can be played without errors.
But when movie maker is finished compiling the screen goes black shortly after starting to play the long clip. I tried different bitrates and cutting the video in smaller pieces but without succes. The pictures before and after the video are all visible.
Is there a duration limit or file size limit in movie maker? 32 bit windows 7 home premium I'm using.
Any suggestions are welcome, I also want to put some music that my sister chose for her funeral on the pictures, but didn't yet see how to do that. If anyone has experience with another free and simple video creator software I'm all ears.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: Windows Movie Maker [Re: Jetronic] #5444784 06/02/20 04:57 PM
J
jhs914 Offline
J
What video format are you converting your file to? I save all my Movie Maker files as MPEG-4.
As to adding music, with the version of Windows Movie Maker (Ver. 2012) I have it is easy to add music. Click the Home button on the top line menu and you will see a musical note and "add music" next to "add videos and photos." Click that and select the music you want to add and where to place it in your video. You can also fade the music in and out to create a smooth transition. i am running Windows 10 but Movie Maker was not supported in Win 10 so I had to download an older version. I had to change a Sys or Config file to make it work but don't remember the details.
Re: Windows Movie Maker [Re: jhs914] #5444873 06/02/20 07:31 PM
Z
ZeeOSix Offline
Z
There is a Movie Creator App for Windows 10 that can be downloaded. There is also a Video Editor App in Windows 10.
Re: Windows Movie Maker [Re: Jetronic] #5447517 06/06/20 08:57 AM
J
OP Online Content
J
Thanks for the suggestions so far. I did download the leatest working version of movie maker before setting off on this.
My father suggested to split the dvd in 2, put the large troublesome video on it's own disc. It's not my preferred solution as it messes with the timeline.
