Forums Migration
Please read this thread
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
77 registered members (19elantragt, 4WD, 2004tdigls, bbhero, AlienBug, ArrestMeRedZ, 8 invisible), 1,588 guests, and 21 spiders.
Topics307,580
Posts5,313,498
Members71,876
Shock Fluid #5444572 06/02/20 11:21 AM
splinter Offline OP
Seems Öhlins typically specifies '2.5' viscosity.
I call 'em "dampers" but to each his own.
There are other thicknesses from which to choose as well.
[Linked Image from i.imgur.com]
[img]https://i.imgur.com/NeElWkq.mp4[/img]
Happy motoring.
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: Shock Fluid [Re: splinter] #5444589 06/02/20 11:52 AM
W
wings&wheels Offline
W
I'm envious on so many levels grin thumbsup
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Shock Fluid [Re: splinter] #5444595 06/02/20 12:02 PM
slacktide_bitog Offline
That's a nice setup smile
I didn't know shocks required an oil change crzy
Re: Shock Fluid [Re: splinter] #5444604 06/02/20 12:22 PM
CT8 Offline
They really are dampers as they dampen the oscillations of the springs
2015 F150 2.7
2018 F350 6.2
Re: Shock Fluid [Re: splinter] #5444671 06/02/20 02:12 PM
K
Kira Offline
K
I NEVER thought I'd ever see a "shock shop".
I'm OK with "dampers".
Is the graph of rebound speeds?
Re: Shock Fluid [Re: splinter] #5444766 06/02/20 04:24 PM
M
MacManus99 Offline
M
Are those Tractive built Xida's in the last photo? I've had the pleasure of autocrossing a vehicle equipped with them. Crazy how they can turn a fast sweeper with a number of dips and rises into a fast sweeper that doesn't require a second thought.
2016 Chevrolet 2500 - 6.0L
2013 Scion FR-S - 2.0L
2012 Ford Escape - 3.0L
Re: Shock Fluid [Re: splinter] #5444836 06/02/20 06:18 PM
sloinker Offline
Most race teams have shock dyno's in house nowadays. Those same drawers of metering and repair parts utilized for the different shock/damper manufacturer. Nothing like going onto good ol' boy Bubba's World of Outlaw's hauler and seeing some dude rebuilding/remetering and dynoing some shocks. It's not as if there aren't already a couple dozen sets ready to go in drawers. I prefer this stuff because it's a pretty blue color.
https://www.redlineoil.com/extralight-25wt-suspension-fluid
Re: Shock Fluid [Re: slacktide_bitog] #5445491 06/03/20 04:01 PM
Srt20 Offline
We freshen our off road toys shocks/dampers often. Change valve stacks around a little bit if needed, but they are toys, not competitive racers. We usually use Amsoil, works good and a guy down the road has in stock.
Re: Shock Fluid [Re: splinter] #5445514 06/03/20 04:26 PM
N
nthach Offline
N
Those are like a suspension fork or shock on a pushbike or motorbike - rebuildable and you can tweak it unlike a sealed shock.
I've seen a bike mechanic friend rebuild a $1000+ Fox mountain bike fork and a long time ago I saw a KYB or Showa motorcycle fork pulled apart, cleaned and checked for straightness against a dial gauge on a slab of marble. After that, fresh oil and new seals before it was put back together and repressurized to spec.
On pushbikes, SRAM and Fox want you send it into them or QBP(the biggest bicycle parts wholesaler in the US) for service. Cleanliness matters on these.
Re: Shock Fluid [Re: splinter] #5449041 06/08/20 01:14 PM
splinter Offline OP
Phase Two:
images credit splinter
-repost as desired
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Re: Shock Fluid [Re: splinter] #5449454 06/09/20 05:35 AM
A
Amkeer Offline
A
Nice! In need of rebuilding my Fox shocks on the Tacoma. It should be a nice learning curve.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
