Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
96 registered members (Bazza32, Avery4, 77GrandPrix, 4WD, Arob, 72te27, 7 invisible), 1,731 guests, and 18 spiders.
Topics307,463
Posts5,311,657
Members71,852
Page 1 of 3 1 2 3
Unless it is a misprint? #5444274 06/01/20 10:25 PM
3
340_Magnum Offline OP
3
The new Pennzoil Platinum API SP 5w-30 is actually a 5w-20. Its 100C viscosity is only 8.6. I wish I would have known that before doing an oil change and putting 6 quarts in my Colorado 3.6 V6 today.
Re: Unless it is a misprint? [Re: 340_Magnum] #5444276 06/01/20 10:27 PM
dblshock Offline
I'd request to be refunded.
05 Lexus GX470 175k
E0 91 640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: Unless it is a misprint? [Re: 340_Magnum] #5444282 06/01/20 10:31 PM
G
GMguy84 Online Content
Online Content
G
Ouch !!! SP off to a bad start
Dave
01 Silverado 1500HD Shell RGT 5W30/XG3675
01 Suburban 1500 Mobil 1 Truck/SUV 5W30/XG3675
02 Suburban 1500 Delo 400XLE 10W30/Protec166
82 Trans Am (KITT) M1 10W40HM/XG5
Re: Unless it is a misprint? [Re: 340_Magnum] #5444285 06/01/20 10:32 PM
O
OilUzer Offline
O
It's summer, why not use 10W40?
You may get a thinner 10W40 then you will have a real W30 based on your logic.
Re: Unless it is a misprint? [Re: 340_Magnum] #5444286 06/01/20 10:34 PM
T
Triple_Se7en Online Content
Online Content
T
Can you give us a link where you read that?
Stay Safe - Stay Healthy
Think things out - b/4 jumping on the wrong daily path.
Keep Your TGDI / GDI engines clean....4k OCI.
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Unless it is a misprint? [Re: GMguy84] #5444288 06/01/20 10:34 PM
3
3
I'm dumping it tomorrow and going back to a real 5w-30 like Mobil 1 or Kendall SN Plus which are 11.0 100C viscosities
Re: Unless it is a misprint? [Re: Triple_Se7en] #5444291 06/01/20 10:35 PM
3
3
Yes sir. Right on Pennzoil's own website.
Re: Unless it is a misprint? [Re: 340_Magnum] #5444292 06/01/20 10:36 PM
T
Online Content
T
What # do they list the cst @ 100 for the 5w20?
Re: Unless it is a misprint? [Re: Triple_Se7en] #5444295 06/01/20 10:38 PM
3
3
8.6 also for the 5w-20
Re: Unless it is a misprint? [Re: Triple_Se7en] #5444298 06/01/20 10:41 PM
T
Online Content
T
I just looked at the website. The 5w20 is listed also as 8.6. So it's definitely a misprint on the 5w30. All the sets of numbers for both the 5w20 and 5w30 are listed the same.
They will fix the website soon. Someone will report it quickly.
Re: Unless it is a misprint? [Re: 340_Magnum] #5444301 06/01/20 10:43 PM
csandste Online Content
Online Content
Even though I run 5w30 in a car calling for 5w20, doubt if I'd be dropping that if it's SP.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Unless it is a misprint? [Re: csandste] #5444314 06/01/20 11:00 PM
3
3
Thanks for the replies, guys. I feel better now knowing that it almost absolutely has to be a misprint.
Re: Unless it is a misprint? [Re: 340_Magnum] #5444315 06/01/20 11:04 PM
B
blufeb95 Online Content
Online Content
B
Misprints on the spec sheet are classic Pennzoil
Re: Unless it is a misprint? [Re: 340_Magnum] #5444333 06/02/20 12:04 AM
G
gfh77665 Offline
G
I would not dump it over a minor viscosity issue. Platinum is an awesome oil, and one time use of a slightly thinner oil won't hurt anything.
If you have to dump it, clean the drain pan good, catch it, rebottle, and save it for the winter.
Re: Unless it is a misprint? [Re: 340_Magnum] #5444343 06/02/20 01:09 AM
G
Gokhan Offline
G
It is an error in the data sheet. I put it in my calculator, and it resulted in a negative VII content.
>> Automated calculator for the A_Harman index, VII content, and base-oil viscosity <<
That said, for a given HTHS, you want the lowest KV100 for best wear protection because it will have the thickest base oil (HTFS = BO DV150 in my calculator) and least VII, which will make it the closest to a monograde.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Page 1 of 3 1 2 3
