Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
101 registered members (antonmnster, 4WD, 72te27, Audioquest, 2010Civic, Astro14, 8 invisible), 1,768 guests, and 24 spiders.
Topics307,463
Posts5,311,638
Members71,852
Page 1 of 3 1 2 3
Re-using good coolant? #5444142 06/01/20 06:21 PM
J
Jarpin Offline OP
J
I'm about to perform a timing belt change on my Toyota with the red coolant. I drained the radiator and half the engine block. It tests good with the bulb dropper colored balls thingy, so I bottled it back up. Seems like a waste to just toss it. Anyone else reuse after a timing belt change or other job requiring the radiator to be emptied?
Thanks.
Re: Re-using good coolant? [Re: Jarpin] #5444145 06/01/20 06:28 PM
R
ripcord Offline
R
The tester with the floating balls just indicates the specific gravity of the coolant which infers the percentage of antifreeze to water in the solution. It doesn't really tell you about the condition of the coolant or it's ability to to prevent corrosion. The best answer to your question is to ask how long it's been in there? If it's been a few years, I would put new coolant in it.
Re: Re-using good coolant? [Re: Jarpin] #5444147 06/01/20 06:31 PM
E
E150GT Offline
E
If you care enough about the car to change the timing belt you should buy new coolant.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 253k 5w30
2016 Mazda6 Touring 6MT - 81k 5w30
2006 Buick Lucerne CXL 3.8 50k 5w30
Re: Re-using good coolant? [Re: Jarpin] #5444148 06/01/20 06:33 PM
skyactiv Offline
I'm a UPS semi mechanic and we do it all the time.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Re-using good coolant? [Re: Jarpin] #5444150 06/01/20 06:35 PM
E
eljefino Offline
E
I say reuse it, but only because a seal might leak on the new water pump or whatever.
After a week of success, change it.
Re: Re-using good coolant? [Re: Jarpin] #5444171 06/01/20 07:04 PM
slacktide_bitog Offline
no-no
Replace the coolant. Zerex Asian, or Pentofrost A1 or A4
A1 is the red concentrate. A4 is the pink 50/50 version.
Pentofrost is sold at any parts store except Autozone. Zerex Asian is sold at Napa and Walmart smile
For the timing belt, I hope you got the Aisin kit (or went to the dealer, NOT eBay!)
Re: Re-using good coolant? [Re: skyactiv] #5444190 06/01/20 07:33 PM
CT8 Online Content
Online Content
How many gallons go into a semis cooling system VS a gallon in the car?
2015 F150 2.7
2018 F350 6.2
Re: Re-using good coolant? [Re: Jarpin] #5444197 06/01/20 07:39 PM
M
meadows Offline
M
Which is the newer? Red or pink?
Re: Re-using good coolant? [Re: Jarpin] #5444212 06/01/20 08:05 PM
K
kschachn Offline
K
Toyota pink is newer than the red, and is stated by Toyota to be backwards compatible. However they are still selling the red the last time I checked. My local dealer sells it for about $18 a gallon which isn't too bad for a concentrate.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Re-using good coolant? [Re: Jarpin] #5444216 06/01/20 08:23 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If it was a few months old, I’d say to consider it, maybe after filtering it.
If it’s over a year, just replace. The addditives deplete, so it’s good to replace them.
Re: Re-using good coolant? [Re: Jarpin] #5444219 06/01/20 08:28 PM
M
meadows Offline
M
Pretty sure I got a gallon of red in garage if you are close enough.
Re: Re-using good coolant? [Re: slacktide_bitog] #5444297 06/01/20 10:40 PM
J
Jarpin Offline OP
J
It's a Continental Contitech Pro series kit. OEM supplier parts:
MITSUBOSHI belt, KOYO idler pulleys, AISIN Water pump + gasket, and NTN hydraulic tensioner pin.
I'm pretty confident about the quality of it.
Re: Re-using good coolant? [Re: Jarpin] #5444310 06/01/20 10:55 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
So no continental parts in it?!?
Seems like you did good with the kit.
Re: Re-using good coolant? [Re: Jarpin] #5444366 06/02/20 04:28 AM
L
Lubener Offline
L
Thanks.
The "anti- freezing" qualities in coolant (or concentration) is not what wears out which is what that tester is indicating.. I would put new coolant with distilled water in to maintain the system from corrosion as long as you have it drained.
The "thinking" man's friend.
Re: Re-using good coolant? [Re: Jarpin] #5444411 06/02/20 06:41 AM
G
Gebo Offline
G
I've never reused coolant. I do a complete change when doing a timing belt and only use the Toyota Red in my cars that call for Red. It's around $9/gal mixed 50:50 with distilled water and it was made for your engine.
My newer Toyotas use the Pink.
That ball thingy tells you virtually nothing. A pH strip will give you proper info.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Page 1 of 3 1 2 3
