- Joined
- Sep 23, 2017
- Messages
- 433
hey guys so i hooked up my noco genius g3500 and it shows my truck battery is only at 50% which is understanble since i mostly drive stop and go.
i believe this noco genius g3500 does automatic step charging and the max is 3.5a
i also have a motor master eliminator battery charger from canadina tire which can do 6a on a normal smart charge mode but also "12A charge mode for large capacity or deeply discharged batteries features an innovative 30A intermittent boost for up to 50% faster charging (compared to a standard 15A charge rate)"
so out of the 3 different charge rates, which is the best for the battery? i assume the slow charger or or is better to use the 12a charge mode on the motomaster which is for large capacity or deeply dischagred battery cuz maybe the higher amps will break down any sulfation that may be present?
thx
thx
