Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
69 registered members (bdcardinal, BoiseRob, Blkstanger, blufeb95, Arrechera, Alfred_B, 8 invisible), 1,733 guests, and 30 spiders.
Topics307,415
Posts5,310,661
Members71,843
Shopping for New Generator #5443882 06/01/20 12:02 PM
doolah02 Offline OP
Anyone familiar with Ford and Westinghouse generators?
Re: Shopping for New Generator [Re: doolah02] #5443908 06/01/20 12:36 PM
4
440Magnum Offline
4
Be aware, Westinghouse hasn't been an actual consumer grade company for a LOOOONG time. The name is just licensed for application to cheap chinese junk. The only remnants of the Westinghouse corporation that are really related to the original are Westinghouse Nuclear (nuclear reactors) and Teco-Westinghouse (industrial motors, wind turbines, switchgear, etc.)
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Shopping for New Generator [Re: doolah02] #5443912 06/01/20 12:45 PM
Donald Offline
Have you done all the needed homework for a generator. Figuring out your load? How will you connect it? Fuel; gas or propane?
If its for hurricane season then you can plan ahead and get several 5 gallon containers of gas. If its for unknown power failures, keeping enough gas around all the time is a PIA.
For you in FL, do you want to run the A/C? Well pump, refrig, freezer? A digital clamp on ammeter can help calculate the load.
2015 Ford F-250 w/Powerstroke
Re: Shopping for New Generator [Re: 440Magnum] #5443954 06/01/20 01:49 PM
doolah02 Offline OP
Wow!
Re: Shopping for New Generator [Re: doolah02] #5443955 06/01/20 01:50 PM
J
JimPghPA Offline
J
OP, if you have electric water heating be aware that if you rewire a switch into the water-heater to run a 240 VAC water-heater on 120 VAC it will only use 1/4 the amount of watts. This is because at 1/2 voltage it will draw 1/2 the current. And 1/2 times 1/2 = 1/4 of course with only 1/4 as much heat going into the water it will take 4 times longer to heat up a cold tank of water. But this could be a very significant reduction in the amount of power you require from your generator, which might even allow you to get by with a smaller generator, and or apply a much lighter load to your generator so it is not worked as hard in the hot Florida heat.
The real down side it that if multiple people want to take a shower, they may have to wait a while between showers for the slower recover time of the water-heater when ran in this mode, but it is a lot easier on a generator.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Shopping for New Generator [Re: Donald] #5443956 06/01/20 01:52 PM
doolah02 Offline OP
No AC or pump, just lights Tvs refrigerator and freezer. And a couple of fans.
Re: Shopping for New Generator [Re: JimPghPA] #5443959 06/01/20 01:56 PM
doolah02 Offline OP
My water heater is 120 volts. I think I can get by with a 5000 watt generator.
Re: Shopping for New Generator [Re: doolah02] #5443989 06/01/20 02:28 PM
J
JTK Offline
J
Ideally you want more wattage than you need, but the problem then is with fuel consumption, which can get pretty high.
You have to consider things like will you have fuel on hand? Will you be able to get it?
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Shopping for New Generator [Re: JTK] #5443997 06/01/20 02:35 PM
doolah02 Offline OP
I'm in South Florida so fuel is no issue, might have to wait in line awhile but I can get it. My previous generator was
an old 10 hp Generac 5000 which ran everything good.
Re: Shopping for New Generator [Re: doolah02] #5444029 06/01/20 03:14 PM
Donald Offline
What happened to that generator? Most people do not run generators enough to wear them out.
Northern Tools has many generators on its website.
Re: Shopping for New Generator [Re: Donald] #5444034 06/01/20 03:18 PM
doolah02 Offline OP
I bought it in 1997. Has an extremely loud muffler and very difficult to replace hoses.
I gave it to my nephew.
Re: Shopping for New Generator [Re: doolah02] #5444057 06/01/20 03:46 PM
A
andyd Offline
A
Check out the Predator line at Harbor Freight. I had an old Coleman 5kw powered by a noisy/thirsty/hard to start Tecumseh HM100. I bought a 6.5 kw Predator and it will allow me to get along just fine come hurricane season. grin2
Thick oil is better grin2
Re: Shopping for New Generator [Re: doolah02] #5444063 06/01/20 03:54 PM
J
JTK Offline
J
A new one will only be marginally quieter unless you buy a $1500 and up Honda, Yamaha, etc.
I've got a ~3300 watt inverter style generator that came "free" with a new travel trailer my inlaws bought a few years ago. They keep it at my house so I can service it. It's a "powerhouse PH3300i". It's pretty loud for a totally enclosed, sound insulated unit and a pain to maintain because of being totally enclosed. It vibrates a lot as well. This is what you get in the under maybe $800 crowd.
Re: Shopping for New Generator [Re: JimPghPA] #5444067 06/01/20 03:57 PM
ABN_CBT_ENGR Offline
You better go back for a refresher course on Ohm's law and basic electricity
Re: Shopping for New Generator [Re: andyd] #5444076 06/01/20 04:17 PM
doolah02 Offline OP
Do you have an idea who makes Predator engines?
