Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
99 registered members (08z06, 72te27, 555, 4WD, antonmnster, 10 invisible), 1,937 guests, and 31 spiders.
Topics307,462
Posts5,311,582
Members71,850
Which oil is the better quality #5443799 06/01/20 09:57 AM
G
galaxy333 Offline OP
G
To be used in a Ford Edge Type: 2.0 TDCi 1998ccm 180HP 132KW (Diesel) 4x4 2017
Castrol MAGNATEC Stop-Start 5W-30 A5 Fully Synthetic Car Engine Oil
ACEA A1/B1, A5/B5
API SN/CF
ILSAC GF4
Meets Ford WSS-M2C913-A/ WSS-M2C913-B/ WSS-M2C913-C/ WSS-M2C913-D
or this:
Mobil Super 3000 X1 Formula FE meets or exceeds the requirements of:
ACEA A5/B5 X
API SL X
Ford WSS-M2C913-C X
Ford WSS-M2C913-D
STJLR.03.5003
Re: Which oil is the better quality [Re: galaxy333] #5443806 06/01/20 10:03 AM
ABN_CBT_ENGR Offline
Define quality please
Re: Which oil is the better quality [Re: galaxy333] #5443807 06/01/20 10:04 AM
T
tundraotto Offline
T
The Castrol - look at the higher levels of approvals.
- just make sure the approvals match your car manufacturer requirements.
Re: Which oil is the better quality [Re: galaxy333] #5443820 06/01/20 10:29 AM
J
JMJNet Offline
J
I notice, you are in UK.
So, oil availability may be different.
What type of minimum standard is required for the vehicle?
If both oils met the standard spec for the car, then pick one of them.
In the grand scheme of things, I don't think a particular oil will reduce the lifetime of the car.
There are a lot more other factors besides oil that will determine that.
  • 2017 Toyota Sienna
Re: Which oil is the better quality [Re: galaxy333] #5443871 06/01/20 11:37 AM
G
G
They both match the Ford specs, I just wondered if one was a better synthetic than the other, I have both in stock just was wondering if there was a difference worth using one over the other,
Re: Which oil is the better quality [Re: galaxy333] #5444025 06/01/20 03:08 PM
A
andyd Offline
A
which one costs the least?
Thick oil is better grin2
Re: Which oil is the better quality [Re: galaxy333] #5444070 06/01/20 04:03 PM
R
Rollins Offline
R
Doesn't this engine require FORD M2C950-A?
Re: Which oil is the better quality [Re: ABN_CBT_ENGR] #5444074 06/01/20 04:14 PM
L
Lolvoguy Offline
L
+1
depends on the application
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Which oil is the better quality [Re: galaxy333] #5444702 06/02/20 02:50 PM
J
Jetronic Offline
J
Both are low viscosity for a diesel engine, I'd go with the one that is likely to have the highest HTHS viscosity between the two. Low viscosity oils tend to be less protective for cylinder walls in diesel engines, due to the high BMEP I guess. Thats what a lot of research papers show anyway.
But if you don't intend to run the engine as long as possible, one will be as good as another...
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: Which oil is the better quality [Re: galaxy333] #5444736 06/02/20 03:31 PM
L
LubricatusObsess Offline
L
How to find HTHS vis these days? A number of Mfg's seem to be hiding their spec sheets now?
