Originally Posted by Dave Sherman
Years ago I heard a theory that in a positive ground system, the spark would have to jump from the negative center electrode in the spark plug to the outer electrode, which is hotter by virtue of being closer to the fire and shielding the center electrode somewhat. I realized that doesn't make much sense, because if that was a real problem, the ignition coil secondary could be wired so the negative side is the common side, and the positive side would go off to the distributor, which would make the spark jump from the outer electrode to the center. I'm pretty sure that theory was debunked anyway.
Another good question is why the British held on to positive ground long after the Yanks went to negative ground, and when the Brits finally went to negative ground, they had to keep the battery cable colors the same colors. My MG has a big warning label under the hood that it is wired "negative earth" since Midgets had been positive ground for so long, but my stock battery cables have black for positive and red for negative. It's fun going to Autozone for a battery test and having to convince them that the colors really are backward.
Besides, electrons jump from negative to positive and are negatively charged...
