Forums Migration
Please read this thread
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
101 registered members (77Se7en, 2015_PSD, ABN_CBT_ENGR, Anthony, 4WD, alex_at, 10 invisible), 1,958 guests, and 27 spiders.
Topics307,771
Posts5,317,483
Members71,916
Can a car have too much battery? #5443481 05/31/20 07:13 PM
W
wings&wheels Offline OP
W
I would think no, but I remind myself that I am a hobbyist. One w/ 30+ years of owning and maintaining odd cars, but still an amateur....
A question for the experts who understand charging systems.
I helped a friend restore a mid 50's car with a 12v positive ground system that originally had two small 6v batteries wired in series. The car has a rebuilt original generator, 30 amps output I believe. My friend decided that he wanted more reserve, planning on two larger (group 24) 12v batteries, obviously wired in parallel. This is a very for cry from what the car had originally.
My question is can battery capacity ever be too much for the available charging power to the point where it could impact generator life, maybe affect the external regulator? I can't see it as in normal operation, the generator would recharge the batteries from starting and supply the vehicle as normal, but if the batteries are severely discharged, could the draw of charging two much larger batteries damage the generator? I would think that the generator has a maximum capable output and that is it, but maybe it could be damaged by having to run at max output to 'fill up" the greater capacity battery suite. Not much out there on this...
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Can a car have too much battery? [Re: wings&wheels] #5443493 05/31/20 07:32 PM
E
eljefino Offline
E
Why would the battery be discharged?
The generator makes all the power the car needs to run, either now, or paying off a deficit.
The textbook reason for a bigger battery would be starting in the cold, if the car is cantankerous for whatever reason and doesn't catch the first time.
A generator runs all its power through its brushes, which are a wear item. Running more would wear them out faster. But, again, why are we running more, unless some is being "stolen" or "lost" from the electrical system or battery in some way.
So if someone leaves their headlights on and gets a jump (or a push start), the bigger battery runs more of a deficit. Think of it as a higher credit limit. Since these cars could be push started, why bother with a huge battery?
Re: Can a car have too much battery? [Re: wings&wheels] #5443495 05/31/20 07:34 PM
ABN_CBT_ENGR Online Content
Online Content
Assuming everything properly functioning, in a single word, no
I doubt you will find much on this because a generator can only create energy based on the excitement of the field and the size of the windings- It cant "over produce" itself and the discharge state of the battery have no bearing on that capacity.
Re: Can a car have too much battery? [Re: wings&wheels] #5443497 05/31/20 07:38 PM
W
W
Thanks both. That is my thinking.
If the batteries were severely discharged, the generator would charge and supply the vehicle at its maximum until the batteries were at their normal state. Maybe it would run at that higher output longer (than with the small originals), but would operate normally.
'05 Lotus Elise S/C
'74 Triumph TR6
'74 BMW 2002
'99 Porsche 996
Piper Pa28-236
Re: Can a car have too much battery? [Re: wings&wheels] #5443507 05/31/20 07:54 PM
E
eljefino Offline
E
The external regulators back then were a vibrating relay thingie, so if the battery were "thirsty" the generator would be at 100% and the regulator wouldn't be doing much. Only concern would be welding the contacts closed, but I don't know enough about failure modes of the primitive things to know if that was any more likely.
Re: Can a car have too much battery? [Re: wings&wheels] #5443542 05/31/20 08:52 PM
M
mk378 Online Content
Online Content
M
Some of those systems had a current regulator relay as well, so a severely discharged or shorted battery wouldn't overload the generator.
Re: Can a car have too much battery? [Re: wings&wheels] #5443564 05/31/20 09:22 PM
Dinoburner Offline
Yes the older generator charging systems can be over stressed when under full load continuously. Under normal load the regulators were a wear item as I remember them which is why so many older vehicle owners upgrade to alternators.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Can a car have too much battery? [Re: wings&wheels] #5443577 05/31/20 09:43 PM
spackard Offline
I had a '61 Buick with a generator. I wasn't very impressed with the size of the power wire connecting the generator output to the battery.
I think it was 6 feet of 10ga or 12ga; seemed small by today's standards.
I put a parallel 10ga conductor in, to lower resistance.
Re: Can a car have too much battery? [Re: wings&wheels] #5443582 05/31/20 09:52 PM
W
W
Thanks all.
We'll take a look at the generator circuit, I like the idea of a parallel wire.
'05 Lotus Elise S/C
'74 Triumph TR6
'74 BMW 2002
'99 Porsche 996
Piper Pa28-236
Re: Can a car have too much battery? [Re: wings&wheels] #5443623 05/31/20 11:43 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
It could be overkill in a way... if the car is low use, and the battery has intrinsic self discharge, and now the generator has to make up for more battery charging of larger capacity batteries, for longer times... yes, it can add wear and tear.
Whether that’s an issue here is a question only the owner can say.
Two large parallel batteries can source more fault current. So my greater concern would be the weak links in older wiring which could start on fire in case of a short in the right spot...
Re: Can a car have too much battery? [Re: spackard] #5443664 06/01/20 06:07 AM
supton Offline
In 1961 that generator was what, 30A? 40A? Maybe not even that much.
I wonder if that wire size was selected as part of the system, chosen deliberately for its loss. Kinda like how they used to use resisitive wiring for the coil, so as to drop 12V down to 6V for the points, when 12V systems came along. Wild guess on my part though--I probably would have thought to make the wire thicker too, given half the chance.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Can a car have too much battery? [Re: wings&wheels] #5443686 06/01/20 07:17 AM
F
fsdork Offline
F
In the example of a discharged battery bank with greater than designed capacity, my (purely speculative) concern would be toward the duty cycle of the alternator at full load. Was the alternator engineered to avoid overheating and associated issues with bushings/bearings/shafts/etc. while generating its maximum output for an extended period of time?
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: Can a car have too much battery? [Re: wings&wheels] #5443696 06/01/20 07:45 AM
Online Content
Let me define this a bit further as there is a lot of incorrect and misleading information posted to clear it up.
Assuming a properly built generator ( alternator) with regulator etc. and rated for the specific application. ( that qualifier has to be there)
There is no such thing as a generator overloading (defined as the generator internally overproduces)- what happens is the regulator senses low voltage and usually speeds up the prime mover ( exceeding the RPM of the generator causing field issues or magnet issues). This can and often does happen in a Pgen set unless proper controls are in place. It would be more correct to say its being "over driven". ( this is excluding shorts and failed components telling the generator isn't meeting demand because that's not a true overload in the sense)
On a car however, this isn't going to happen without taching out the engine ( if that happens the battery isn't going to be the big issue)
So on a 6-12 VDC system where a functioning regulator senses voltage lower than the cut off- the generator will rotate and excited and charge at the rate until properly relieved. It wont hurt or overstress anything because that's that the generator is designed to do.
The regulator will adjust charge rate based on load requirement as the demand fluctuates
So if there was a chronic dead battery and the road trip was from Texas to the planet Jupiter, there may eventually be service factor issue or component fatigue but not significantly different than normal system entropy.
Hope that helps
Re: Can a car have too much battery? [Re: wings&wheels] #5443699 06/01/20 07:47 AM
R
ragtoplvr Offline
R
A generator DOES NOT have a current limit. Cycling on the over current relay contacts in the regulator will burn them out quickly. You can easily burn up the armature, this is something that these days s very expensive if you can still get them.
The old time voltage limit is too low for modern batteries, the regulator needs adjusted to 14.2 at a minimum, 14.5 if you do not drive much. You must know how, do not just go in there and move/bend contacts. You bend spring seat to increase/decrease tension as needed. Many new regulators are VERY poor quality. Make sure the reverse current relay is working, otherwise you can flame the generator, and maybe even burn up the car.
Do not put in large amp hour batteries.
Rod
Re: Can a car have too much battery? [Re: ragtoplvr] #5443701 06/01/20 07:51 AM
Online Content
Rod
We used to bump them to 120VAC on alternators and make mini camping generators out of them long before inverters hit the scene ( works good for a while)
