Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
29 registered members (d00df00d, Ausfahrt, doolah02, blufeb95, CPA1989, 4 invisible), 560 guests, and 49 spiders.
Topics307,747
Posts5,316,941
Members71,910
Battery 2013 4Runner 4WD #5443236 05/31/20 02:29 PM
G
Gebo Offline OP
G
I am trying to find the oem battery for a 2013 4Runner. Everywhere I look they say "discontinued."
What is the OEM group?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Battery 2013 4Runner 4WD [Re: Gebo] #5443252 05/31/20 02:44 PM
W
WhyMe Offline
W
looks like its a 24F . its availble all over the place. go to costco and get one . i think it was less the $100
Re: Battery 2013 4Runner 4WD [Re: Gebo] #5443304 05/31/20 03:50 PM
T
TmanP Offline
T
Should be a 24F, which is a very common and pretty cheap size. We have a 2010 Sienna and a 2012 Camry each running 24F - an Everstart Maxx and a SuperStart, respectively. Any reasonable option should be good for 4+ years, probably more (I replaced the Camry's OEM battery this winter out of an abundance of caution, but it still started fine after 8 years).
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Battery 2013 4Runner 4WD [Re: Gebo] #5443357 05/31/20 04:36 PM
Chris142 Offline
The OEM was made by Panasonic. You will not find one in the aftermarket.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Battery 2013 4Runner 4WD [Re: Gebo] #5443379 05/31/20 05:02 PM
J
JMJNet Offline
J
Wally's battery around here are East Penn made NOT JC.
The barcode start with EP.
  • 2017 Toyota Sienna
Re: Battery 2013 4Runner 4WD [Re: Gebo] #5443396 05/31/20 05:21 PM
G
Gebo Offline OP
G
Yep, 24F verified. He has a Honda battery dated 6/17. 3 year free replacement. After charging from 8-3 pm only 10.7 volts and 87 CCA.
Thank goodness, this is the Honda dealership he used to work at.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
