Forums Migration
Please read this thread
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
99 registered members (77Se7en, 4WD, 53' Stude, 1foxracing, 2015_PSD, 28oz, 8 invisible), 1,590 guests, and 30 spiders.
Topics307,631
Posts5,314,598
Members71,894
Keep OE carb vs replacement #5443067 05/31/20 10:00 AM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
My echo ES-210 runs great and starts rapidly. It is all original, bought in 2006. Recently the primer bulb cracked, so it spits a bit of gas when priming.
On amazon, a kit that includes a spark plug, filter, three (?) primer bulbs, and a new carb was available. I didn’t look that hard, but didn’t see any standalone bulbs fwiw.
So the question becomes if I’m better off just replacing the bulb, or replacing the carb. It’s an ain’t broke, don’t fix it situation, and I have no idea if the carb is set right.
Since it runs well, is there any good reason to replace the carb?
This thing got pretty heavy use until I bought a backpack blower two years ago. I’m going to use it for the vac function now, so I anticipate it will get heavy use again. We have a lot of holly and maple trees that drop a lot.
Re: Keep OE carb vs replacement [Re: JHZR2] #5443071 05/31/20 10:12 AM
Cujet Online Content
Online Content
The primer bulbs are replacement items. Replace it without worry.
The replacement carbs can be superb, but if you have no issues, why bother.
Re: Keep OE carb vs replacement [Re: JHZR2] #5443095 05/31/20 10:52 AM
DeafBrad Offline
Don't replace your carb with a knock off if it works fine. In 3 pieces of equipment I have the replace carbs didn't work the same as oem. Several pieces of equipment were given to me... one had governor spring hookup issues, another ran very poorly, and my trimmer doesn't run full rpm which results in poor performance.
The bulb should be replaceable. My local auto parts store has ope parts and they have bulbs. Maybe your parts store has parts and it will fit?
2011 Think City Electric Car
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: Keep OE carb vs replacement [Re: JHZR2] #5443124 05/31/20 11:38 AM
T
Trav Offline
T
Just the bulb, don't mess with what is working well otherwise.
Re: Keep OE carb vs replacement [Re: JHZR2] #5443143 05/31/20 12:06 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Hmmm, well the bulb and return hose (which was cracked) didn’t fix the issue.
Primer bulb doesn’t fill with gas. Blower starts easy and runs, but will cut out on occasion. I use it now as a vac, and so some of that is due to sticks I think. I don’t think it runs as strong as it used to, but its been a few years. I can easily vac up a full bag of mulched leaves with this, in its current state.
But I know something isn’t quite right.
Primer bulb still won’t fill with new bulb and new hoses/filters all around.
When running, if I pump the primer bulb, it will fill up about 90%. Then it off and it will pump out when I press the bulb. It’s maybe 25% full, max.
Not sure if this is another clue, but the old AF was pretty soaked in oil (it’s a dry media type):
[Linked Image]
It’s generally pretty filthy, and is currently seeping gas. That may be my error?
[Linked Image]
Re: Keep OE carb vs replacement [Re: JHZR2] #5443145 05/31/20 12:11 PM
ls1mike Offline
I would just do the bulb. I have not had good luck with the aftermarket carbs on of my lawn equipment.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Keep OE carb vs replacement [Re: JHZR2] #5443152 05/31/20 12:15 PM
ls1mike Offline
I don't understand why the primer bulb isn't filling.
Soaked filter maybe you have some else going on. It is a 2 stroke correct?
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Keep OE carb vs replacement [Re: JHZR2] #5443158 05/31/20 12:21 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
And now gas is literally flowing out of the tank vent. That may be because it’s a $16 kit...
[Linked Image]
The lines are corrected properly....
Re: Keep OE carb vs replacement [Re: ls1mike] #5443161 05/31/20 12:24 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Yes. IME all two stroke stuff is a bit oily in time.
But this one is vastly more.
Re: Keep OE carb vs replacement [Re: JHZR2] #5443164 05/31/20 12:28 PM
spasm3 Offline
Have you checked/replaced the fuel filter on the end of the fuel line, in the tank?
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Keep OE carb vs replacement [Re: spasm3] #5443202 05/31/20 01:43 PM
ls1mike Offline
I was going there next. smile
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Keep OE carb vs replacement [Re: JHZR2] #5443204 05/31/20 01:44 PM
R
ripcord Offline
R
The size of the air bubble in the bulb isn't really that important. What's important is that you see fuel moving through both the intake and return lines. If you see fuel going back into the tank, then it's getting a prime. Also, those tank vents do fail sometimes so I would replace it if its leaking a lot. Maybe try putting the old one back on if the one that's leaking came with the parts you bought?
As for the loss of power, first thing I would do is to check the spark arrestor and make sure it's not carbon-ed up. You can clean the carbon off the screen easily with a propane torch. Second, at 12 years old it's likely that the diaphragms in the carb are stiff with age and exposure to ethanol. I would put a kit in it at least. Third, if you find that there continues to be an excessive amount of gas saturating the air filter, fuel spitback can be caused by a worn piston that allows too much combustion pressure to escape into the crankcase at the bottom of the stroke.
Re: Keep OE carb vs replacement [Re: ls1mike] #5443222 05/31/20 02:10 PM
spasm3 Offline
I'm thinking, if the filter is plugged/partially plugged, and he pumps the primer bulb, the pressure builds in the tank, and fuel goes out the vent.
Re: Keep OE carb vs replacement [Re: ripcord] #5443628 05/31/20 11:57 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Yes, that was the very first thing I did.
The issue was that the “air bubble” was more like 90% of the primer. Some fuel was spitting through the return line, but it was mainly air.
Good call on spark arrestor. Ive never messed with one on any of my equipment.
The oil in the filter has been like that for a long time. I dont know that it’s new, but I will track it Now that I have a new clean filter in there.
Do you know if they sell just the primer diaphragm? Am I better off installing this no name $16 amazon kit, or getting one OE to install into my existing carb? I know the settings on the current carb are right...
Re: Keep OE carb vs replacement [Re: spasm3] #5443631 05/31/20 11:59 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I think the issue was the vent line was too long. Ive never known it to be a problem, but it was long enough to have the in-tank end sitting in fuel... and then the tank would pressurize just from sunlight I guess, and get the flow started...
