Forums Migration
Please read this thread
GM 1.4T Hengst vs UFI housing
by hardcore302 - 07/09/20 10:56 PM
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
gas cans, nato style
by BeerCan - 07/09/20 06:24 PM
07 Mustang Fuel Pressure Sensor error
by Barkleymut - 07/09/20 06:21 PM
2007 Hyundai veracruz 0w40?
by Envoyguy - 07/09/20 06:19 PM
How bad is it?
by Averroes - 07/09/20 05:29 PM
various vintage oil filters cut apart
by dogememe - 07/09/20 05:26 PM
LCD burn in? Seriously?
by Klutch9 - 07/09/20 04:12 PM
WTB - 1050 video card
by stockrex - 07/09/20 02:28 PM
how good is royal purple gear oil and syncromax?
by apollo18 - 07/09/20 02:22 PM
Wire Brushes
by Gebo - 07/09/20 01:59 PM
MOBIL 1 0w20 vs AMAZON BASICS 5w20
by IBelieveinlube - 07/09/20 01:51 PM
907Lynette, mckaskie, mkid, kuldeep, BillDros
71900 Registered Users
67 registered members (ArrestMeRedZ, 4WD, ammolab, aquariuscsm, 77GrandPrix, apollo18, 7 invisible), 1,491 guests, and 49 spiders.
Topics307,666
Posts5,315,312
Members71,900
Sturmey Archer 3 Speed-Shifting? #5442946 05/31/20 07:45 AM
E
ET16 Offline OP
E
I'm fixing up an older Vista bike with one of these hubs. Adjusting it has been a little tricky. In general, the hub is temperamental about shifting when you're peddling. It shifts fine, if you shift while coating, which is why I'm posting: are these things meant to be shifted while coasting, or is the condition I've described a symptom that something is still not right?
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5442949 05/31/20 07:50 AM
cjcride Offline
Coast or pedal backwards
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5442950 05/31/20 07:51 AM
R
R_W_M Offline
R
Those 3 speed hubs are fiddly to adjust. They are designed to shift while coasting.. It sounds like yours is working fine.
2005 Ford Five Hundred 108 K Mi.
2009 Subaru Forester 23 K mi.
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5442951 05/31/20 07:53 AM
cjcride Offline
To set the shifter gearing right.
I would put the shifter in 3. Then gradually take the slack of the shifter cable till the small shifter chain just begins to move at that point back off the adjuster slightly and set the lock nut.
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5442954 05/31/20 07:56 AM
V
Variant_S Offline
V
Yes to shifting while coasting. When I had one I'd adjust to get second gear about in the middle of the travel of the shifter. First and third then usually were OK.
Re: Sturmey Archer 3 Speed-Shifting? [Re: Variant_S] #5442959 05/31/20 08:02 AM
cjcride Offline
I believe that is the way Sturmey Archer would advise. Yet the 3rd gear way always seemed easier for me
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5442979 05/31/20 08:29 AM
A
andyd Offline
A
I had Raleighs with the SA 3spd. Constantly fiddling with that stupid adjustment. grin2
Thick oil is better grin2
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5443047 05/31/20 09:36 AM
E
ET16 Offline OP
E
Yes, very fiddly! I think I may have it now.
Thanks for the replies.
I love the sound these hubs make. The clickety-clack is signature for them.
Re: Sturmey Archer 3 Speed-Shifting? [Re: andyd] #5443229 05/31/20 02:22 PM
CR94 Offline
Shifting can be done when coasting with pedals stopped, but when coasting with pedals turning forward lightly is even better. Shifting to a higher gear is always ok when everything is stopped. Shifting lower is ok when stopped if and only if it will go freely; just don't try to force it.
There are several easy ways to do that cable adjustment, all of which yield the same result.
1. With the shifter in the lowest "gear," adjust it so the shift chain can still be pulled slightly farther out of the hub without undue force.
2. With the shifter in the highest "gear," adjust it so there is only slight slack in the shift cable.
3. Placing the shifter about midway between the highest and middle "gears," should yield a neutral position (pedals turn forward freely with wheel stationary).
4. Notch on shift rod should align with end of the axle in the middle "gear." (May not work if parts have been replaced...)
2011 Toyota Prius now at 111K
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5443618 05/31/20 11:20 PM
Silk Offline
I used to have a twist grip change on one of my bikes as a kid...but the lever was pretty good anyway.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Sturmey Archer 3 Speed-Shifting? [Re: ET16] #5444378 06/02/20 04:50 AM
L
Lubener Offline
L
Sturmey- Archer sure brings back child hood memories. I haven't seen or heard of those in many years.
The "thinking" man's friend.
