Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
28 registered members (CPA1989, Ausfahrt, blufeb95, carviewsonic, celicaxx, 5 invisible), 569 guests, and 27 spiders.
Topics307,747
Posts5,316,936
Members71,910
New junk tool #5442865 05/31/20 01:07 AM
P10crew Offline OP
I’m betting there is 1 for sure possibly 3 that know what this component part is.
CLine... Trav...??????
I’m getting towards the end of a 2 month $1700- $2000
Tool build project and thought we would share the build here because I know for sure there are some handy fabricators in here that may have wanted one.
Take your guess and more pics to come as I get to the final pics.
[Linked Image]
[Linked Image]
Re: New junk tool [Re: P10crew] #5442892 05/31/20 05:11 AM
ABN_CBT_ENGR Offline
That's a home built turbo-encabulator
Re: New junk tool [Re: P10crew] #5442908 05/31/20 06:20 AM
L
LazyDog Offline
L
Your right, I have no clue. I am familiar w/ Daytona brand, Grainger sells some stuff with that brand name LOL
Re: New junk tool [Re: P10crew] #5442935 05/31/20 07:28 AM
T
Trav Offline
T
Beautiful skilled workmanship there my friend. Deburring machine.
Re: New junk tool [Re: P10crew] #5442972 05/31/20 08:23 AM
spasm3 Offline
Its a corn and callus remover! grin2
I am guessing its to clean steel stock of rust before welding.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: New junk tool [Re: P10crew] #5443025 05/31/20 09:11 AM
P10crew Offline OP
Lol it’s the turn table friction drive motor for a home made jet spray parts washer.
Corn and callus remover....... good one!
Re: New junk tool [Re: P10crew] #5443040 05/31/20 09:26 AM
P10crew Offline OP
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: New junk tool [Re: P10crew] #5443043 05/31/20 09:27 AM
P10crew Offline OP
Got a couple week ends of work left but coming along good so far.
Re: New junk tool [Re: P10crew] #5443044 05/31/20 09:27 AM
U
UncleDave Offline
U
sweet - cabinet blaster.
Makes old junk look like new junk.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: New junk tool [Re: P10crew] #5443050 05/31/20 09:39 AM
Just curious, what made you pick a friction drive?
I either do a bevel gear ( for direct drive units) on the bottom or a posi drive belt.
Like that skimmer set up
you gonna put a water heater on it?
Re: New junk tool [Re: P10crew] #5443064 05/31/20 09:57 AM
P10crew Offline OP
I didn’t think I would have this much 10 GA sheet into it but up to this point I have (1) 5x10 and (1) 4x8. With quite a bit of rem’s left. Anxious to see it work.
(2) 4500 watt titanium heating elements.
1.5 hp high head USA Gorman- Rupp stainless pump.
(24) # 30 Suttner hardened stainless vjet nozzles.
200 in. lb 6 rpm Dayton turn table drive motor (corn remover)
150 in. lb 6 rpm Dayton oil skimmer drive motor.
I haven’t punched any holes in the JIC box yet because I’m thinking seriously about using an ink bird PID temperature controller and an Ink bird timer control vs the old mechanical controls.
Re: New junk tool [Re: P10crew] #5443068 05/31/20 10:06 AM
P10crew Offline OP
ABN the reason I used friction drive is it’s a good way to protect the drive motor in case of a part jamming and stalling the table. Bevel gear or cog belt are common too.
Edit: my old hotsy had a giant corn planter chain drive.
Re: New junk tool [Re: P10crew] #5443083 05/31/20 10:40 AM
K
Kira Offline
K
You put a rusty thing in it then....set it and forget it? You come back later and it's done? Very cool.
What kind of things do you derust with it?
Re: New junk tool [Re: P10crew] #5443091 05/31/20 10:48 AM
spasm3 Offline
Wire wheel fooled me, i would never have guessed any type of friction drive. Ingenious idea.
Re: New junk tool [Re: P10crew] #5443114 05/31/20 11:06 AM
P10crew Offline OP
Spaz... the friction drive on these has been around for awhile. Not sure when they started that.
Kira it’s a parts washer . You can get a better idea of what they do and how they work if you look up bend pak RS 750D they have some video’s too.
When you’re moving 70 gpm of 180 degree detergent over a part grime and oil don’t stand a chance.
