Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
91 registered members (97tbird, 555, 928, 2015_PSD, 55Test, addyguy, 12 invisible), 1,467 guests, and 31 spiders.
Topics307,432
Posts5,310,888
Members71,847
Strange Phenomenon with a strong tail wind at idle #5442775 05/30/20 08:43 PM
Cmobile Offline OP
While waiting in a vehicle line idling for about 45 minutes (for the city dump) car started running hot, 230 degrees, AC working poorly, barely cooling the air. I turned off ac. Slowly cooled back to normal 210.
New cooling system, always runs 210 no matter what. AC can freeze a side of beef (Except today)
While waiting in line there was a tail wind about 30-35 mph. Ambient temps were 90 degrees, but my mirror indicated ambient temps at 116 degrees. Odd, as it is usually within 3 degrees even idling.
As soon as I turned left into the dump (still in line) I had to roll up the windows as the dust/smell from the front loader moving garbage was awful. So I turned the AC back on and it worked perfect again, cold AC, normal temps.
So do you think the tail wind was negating the airflow from the cooling fan causing these issues? Sounds like it to me. The wind was blowing directly behind me, and as soon as I turned perpendicular to the wind, vehicle was working like usual.
2005 Hyundai Santa Fe
2003 Chevy Suburban
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5442794 05/30/20 09:22 PM
O
oldhp Offline
O
Yep, You weren't moving so the fans were doing all the work, but a tail wind was evidently packing or distorting air movement in the engine compartment. My thoughts anyway.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5442797 05/30/20 09:29 PM
dishdude Online Content
Online Content
On a day like today, you're really pushing the limits of the cooling system. A lack of airflow will really push them!
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5442804 05/30/20 09:39 PM
Nick1994 Offline
Must have been early this morning, as it was almost 110 today.
Check to make sure the electric fans are blowing good and hard, maybe they're weak.
2015 Hyundai Genesis 5.0L 62k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5442810 05/30/20 09:51 PM
Cmobile Offline OP
I was in my Suburban, 5.3l, no e-fan, just mechanical. Was in Prescott.
New AC delco OEM clutch fan, new bigger radiator. I thought my cooling system was good, just posted to see if it was a phenomenon, or an issue I needed to look at with my cooling system.
2003 Chevy Suburban
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5442863 05/31/20 01:06 AM
A
Anduril Offline
A
My XTerra would do this when I first bought it. Poor A/C performance at idle and would run hot with the A/C on and not moving. Issue was a bad fan clutch.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Strange Phenomenon with a strong tail wind at idle [Re: Anduril] #5442866 05/31/20 01:11 AM
Online Content
I think you're right.
Re: Strange Phenomenon with a strong tail wind at idle [Re: dishdude] #5442916 05/31/20 06:44 AM
MolaKule Offline
Global Moderator
Global Moderator
Me too!
I had a Burb with a bad fan clutch. I went to the local GM dealer and bought a replacement. After installation the Burb would show high idling temps on a hot Kansas day.
Pulled the fan and found the clutch had leaked its coupling fluid. GM dealer replaced with one that did not leak its fluid.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5442966 05/31/20 08:12 AM
E
eljefino Online Content
Online Content
E
If your fan clutch were good you'd have hear the roar pulling out of the dump. Sounding like a school bus. If it didn't lock up then, when would it?
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5443027 05/31/20 09:11 AM
A
ARCOgraphite Offline
A
Bad clutch fan. - or too low idle.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Strange Phenomenon with a strong tail wind at idle [Re: Cmobile] #5443111 05/31/20 11:04 AM
Cmobile Offline OP
I'll check the OEM clutch for leaks. Been on about 6 months. I can hear the fan roar when it's hot above 1800 rpm or so. But not so much at idle. If I put in Nutral and rev to 1500-2000 rpms, it roars pretty loud.
I do notice at idle, ac not as cold than when moving, but has always been able to keep up with heat load...except when idling with a tail wind.
Scanner says idle 660-700 RPM. Always fluctuating.
Lonf term fuel trim at idle a bit high at +13.
When I was perpendicular to the wind, ac was cold and engine temps normal.
Wind blowing 35mph to the North, Engine fan blowing air to the South. Does this create static pressure?
Fan air blowing over the radiator has a harder time exiting the engine compartment due to the wind blowing the opposite direction. Only time this happened was during this unique situation.
Like the train going 60mph East, wind blowing 60mph East, which way does the smoke go...
Save for the electric train part...
2003 Chevy Suburban
