Northern hot cold pressure washer - clogged
by Donald - 07/03/20 10:48 AM
Porsche Transaxle Fluid Label
by wings&wheels - 07/03/20 08:52 AM
Ford 7.3 Godzilla Engine
by Snagglefoot - 07/03/20 08:43 AM
Growing Blackberries and Mulberries
by krismoriah72 - 07/03/20 07:50 AM
Yo! Starsky,
by RichR - 07/03/20 02:03 AM
Chinese air filters?
by Dogred08 - 07/03/20 01:18 AM
2006 Jetta TDI 5-speed with 324K miles in Florida
by atikovi - 07/02/20 10:51 PM
Rain X
by hardcore302 - 07/02/20 10:06 PM
K&N as for Trax MAF?
by hardcore302 - 07/02/20 09:46 PM
Auto Zone Delo 400 XLE 10w-30 1/2 off and rebate
by blupupher - 07/02/20 09:45 PM
RAM about to pass Silverado sales
by gfh77665 - 07/02/20 07:49 PM
Puffer Fish and Skate
by buster - 07/02/20 06:25 PM
XM Radio
by Passport1 - 07/02/20 05:20 PM
Popup Camper Wheel Well is torn up
by handyman - 07/02/20 03:59 PM
400rwkw, daveCarTruck, Jth383, pfreeride, awc
71838 Registered Users
74 registered members (928, aquariuscsm, andyd, 14Accent, 4WD, 7 invisible), 2,116 guests, and 36 spiders.
Topics307,362
Posts5,309,844
Members71,838
Toro SR Won't Stop Running #5442748 05/30/20 08:05 PM
J
jkasch Online Content OP
OP Online Content
J
I've had a Briggs powered model 20055 since new in '06. It's been perfect until today when it wouldn't stop when I released the bail. Pushing the lever on the motor that the bail cable pushes forward didn't help. I finally had to pull the plug wire to kill the motor. Lots of YouTube videos on mowers that won't stay running but I couldn't find one that addresses not stopping.
Thanks for suggesting any things to check/adjust.
Re: Toro SR Won't Stop Running [Re: jkasch] #5442793 05/30/20 09:21 PM
Q
qjohn Offline
Q
Could be the 'stop switch'. Something like this:
Stop Switch
Double check your application, of course.
Re: Toro SR Won't Stop Running [Re: jkasch] #5442808 05/30/20 09:46 PM
Snagglefoot Offline
Yes remove the cover and trace the cable from the bail to the stop switch. Not sure about Briggs but on Hondas there is a ground wire from the coil to the ground switch. If there is one you can pull the ground wire off the coil, and use a voltmeter set to resistance in ohms. One contact on the ground wire and one on the block. It should say zero resistance with the bail released, and open circuit with the bail pulled into the running position. ( just tie it with a string if working alone.) Might be some crud on the switch.
If you want the job done right......do it yourself.
Re: Toro SR Won't Stop Running [Re: jkasch] #5442812 05/30/20 10:00 PM
V
Va Runner Offline
V
I have the same mower model purchased Fall 2005. Fantastic reliability and quality mulcher.
Here is the parts manual page where the stop switch is identified....part # 692310
Hope this helps you out.
https://www.toro.com/en/parts/partdetails?id=29199#
https://www.amazon.com/Briggs-Stratton-692310-Switch-Replacement/dp/B005F6OQ6I#customerReviews
https://www.amazon.com/gp/customer-...dp_d_rvw_ttl?ie=UTF8&ASIN=B005F6OQ6I
Re: Toro SR Won't Stop Running [Re: jkasch] #5442817 05/30/20 10:32 PM
J
OP Online Content
J
Thanks to all. Yep, its the stop switch. It looks as if the plastic that the wire clips under broke off so the wire is not attached.
Re: Toro SR Won't Stop Running [Re: jkasch] #5442861 05/31/20 12:54 AM
W
WyrTwister Offline
W
Sounds like a cheap repair . Congrats !
Best of luck to you . :-)
Wyr
God bless
Re: Toro SR Won't Stop Running [Re: WyrTwister] #5443035 05/31/20 09:18 AM
J
OP Online Content
J
Thanks!
Re: Toro SR Won't Stop Running [Re: jkasch] #5443900 06/01/20 12:28 PM
J
OP Online Content
J
I spent $1.99 for the switch stop and got a new primer bulb for $3.99. Starts on first pull and stops like new. Thanks again for the replies. grin2
