Forums Migration
Please read this thread
pool deck paint
by CincyDavid - 07/13/20 06:32 AM
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
stepburns, JOLLY300, WheelHorseman, stiguy300, Mark_C
71921 Registered Users
49 registered members (AndyB, avi1777, Anthony, AlienBug, 94astro, 7 invisible), 1,096 guests, and 27 spiders.
Topics307,782
Posts5,317,748
Members71,921
Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... #5442634 05/30/20 04:42 PM
wemay Offline OP
We finally have a euro oil that isn't "better" because of greater HT/HS (both are roughly 2.6). Making this, I believe, a fair comparison for discussion.
We've all read where EP is a fantastic oil because of composition (~70+% PAO) and stellar long drain intervals yet it has fewer approvals, and what many here consider, less stringent specs than the ESP X2 oil which is also highly regarded.
Both are long drain oils and POA based. Would you consider them to be on equal footing?
Regardless of what we drive, if possible to remove from equation.
19 Passat Wolfsburg 2.0 TSi: Castrol 508 0W-20
13 Santa Fe Sport 2.0T: GTX Magnatec 5W-30
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442643 05/30/20 05:04 PM
7
77Se7en Offline
7
Depends on what we-all drive.
Your VW sees the ESP as a better fit. My GDI sees the low Calcium preference in Mobil-1 EP.
Our new Soul 2.0 MPI may benefit from either ESP, Rotella T6 Multi Vehicle or a similar Delo XSP in 5w30. No turbo or old-school GDI for the 2020 Kia Soul 2.0's
Spiritual Intuitive / Whisperer-Medium (Involuntary & Non-Profit)
Valvoline ME, Mobil-1 EP & Pennzoil Ultra Platinum 5w30s
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: 77Se7en] #5442645 05/30/20 05:10 PM
wemay Offline OP
Our new Soul 2.0 MPI may benefit from either ESP, Rotella T6 Multi Vehicle or a similar Delo in 5w30. No turbo or old-school GDI for the 2020 Kia Soul 2.0's.
Hi Tripple. I edited after you posted, sorry.
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442646 05/30/20 05:12 PM
7
77Se7en Offline
7
Great minds think alike.....lol
I edited after you posted.
I added the Delo label...... XSP
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442652 05/30/20 05:21 PM
sloinker Offline
For the price of either of these oils it makes sense to me to spend slightly more for Ravenol or Red Line. Not dissin' the M1 but if you get on a sale from Jegs or Blauparts the prices are close and the test specs are equivalent or better last I checked.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: sloinker] #5442664 05/30/20 05:31 PM
4WD Offline
And what will that do besides make you feel smart ?
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442667 05/30/20 05:33 PM
B
buster Offline
B
The ESP 0w20 is PAO, GTL and POE.
The M1 EP is PAO/AN.
From what I've seen with the ESP line, viscosity retention is very good. Some of the best Subaru WRX UOA's are from ESP 5w30.
The ESP 0w20 does meet the Porsche C20 spec, so it's definitely high quality.
https://online.lubrizol.com/relperftool/pc.html#
In a DI engine I think it's a great choice. However, for really long drains I'm not so sure.
Here is a VOA of this oil from 2018
VI 175
Moly 77
Boron 317
Mg 11
Ca 1,748
Oxidation 39.3 (ester)
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442726 05/30/20 07:23 PM
G
Gokhan Offline
G
The main difference between the two is the ZDDP content. ACEA C5 requires a 700 ppm phosphorus minimum, whereas the non-Euro Mobil 1 0W-XX varieties (excluding high-mileage and racing) are for some reason (to decrease the coefficient of friction and improve the fuel economy?) skimpy on ZDPP with 650 ppm phosphorus. M1 ESP x2 0W-20 probably has 800 ppm phosphorus, which would be 23% higher than the non-Euro M1 0W-XX oils'.
The other difference is the VII content. M1 ESP x2 0W-20 has a lower VII content, which is typical of ACEA C5 0W-20 oils, which are more focused on reducing wear than improving the fuel economy. They also tend to have a thicker base oil but M1 ESP x2 0W-20 doesn't have a particularly thick base oil for a 0W-20.
However, M1 EP 0W-20 has a PAO base oil and probably more antioxidant, which should allow longer OCI's than M1 ESP x2 0W-20.
The final difference is in the lubricity base stock. Non-Euro M1 varieties use Group V alkylated naphthalene (AN) as the lubricity base stock, whereas Euro (ESP and FS) varieties use Group V polyol ester (POE). While POE cleans better than AN, which may perhaps be useful for the European passenger-car diesel engines, it increases the engine wear as it competes with the AW/EP/FM additives, but for the 5–7% POE content used in the Euro M1 oils, the effect is small.
Given the price and availability, I think to go with M1 EP 0W-20 is no-brainer.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442728 05/30/20 07:23 PM
demarpaint Offline
Given the choice I'd run the ESP. I made the switch over to ESP over a year ago in two of my vehicles. From what I've read and heard "imo" it is a better product.
God Bless Our Troops
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: sloinker] #5442733 05/30/20 07:37 PM
J
Jackson_Slugger Offline
J
Not slightly more, several times more. I like Ravenol but it's overkill and I've never failed to be underwhelmed by Redline UOA's, not that I put much stock in them. But paying more for higher metal wear doesn't seem to make much sense...
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: Gokhan] #5442734 05/30/20 07:37 PM
B
buster Offline
B
Good information, thank you. thumbsup
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: Gokhan] #5442743 05/30/20 07:56 PM
wemay Offline OP
Thank you Gokhan...and buster. The explanation was easy to understand and makes sense. Today my "service" light went off (not the oil one but the inspection). So I took it in and realized it's just a way to get you into the dealership. Anyway, in the service bay, there was a gentleman who brought his own oil. It was M1 EP 0w20 for his GTi....they used it without hesitation. I didn't bring it up in conversation but the Tech did mouth..."great oil". That's what got me thinking.
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5442745 05/30/20 07:58 PM
B
buster Offline
B
Here is a UOA in a Toyota 3.5 ran for almost 10k miles with 2.7% fuel. The ESP line maintains its viscosity very well.
https://www.oil-club.ru/forum/topic...y-35-v6-2gr-fks-posle-15500-km/#comments
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: buster] #5442778 05/30/20 08:44 PM
wemay Offline OP
Excellent retention for sure. I've seen equally impressive UOA between them.
Re: Mobil1 EP 0W-20 and Mobil1 ESP X2 0W-20 for example... [Re: wemay] #5447313 06/05/20 10:56 PM
wemay Offline OP
