Forums Migration
Please read this thread
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
112 registered members (28oz, 2015_PSD, 4WD, 2004tdigls, 77GrandPrix, 53' Stude, 14 invisible), 1,957 guests, and 45 spiders.
Topics307,640
Posts5,314,798
Members71,897
Thinking of Buying Compressor #5442623 05/30/20 04:16 PM
M
Mr_Luke Offline OP
M
The new mgr of a local tire place can't seem to put the same PSI in each of my tires and I'm thinking of getting my own 12VDC portable compressor so I can inflate my tires to my desired PSI. I don't know if I want to go back to adding quarters to air machines that may or may not work.
Should I get my own compressor?
Got any suggestions for a good one for <$50.
Thanks.
2012 Toyota Prius C / 110k
Castrol Edge 0w20 FS
Federated PG4476F
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442627 05/30/20 04:23 PM
W
Wolf359 Offline
W
Well I have a few suggestions. I usually use the Ryobi 18v tire inflator. Handy to just leave in the trunk. It's just $25. I had the older version that just had an analog gauge which was $20. If you want to just automatically set the pressure, there's one for $50, but it usually goes on sale for about $35 all the time. If you don't have a battery/charger, you can get this 1/2 inch impact wrench to remove lug nuts and use the battery/charger it comes with. It's good for 300 foot pounds. They sell a battery/charger with the auto inflator, but that's $125 with just a 2 amp hour battery and this impact wrench comes with a 4 amp hour battery and is only $109 although it's been on sale in the past for $99.
https://www.homedepot.com/p/RYOBI-1...-Digital-Gauge-Tool-Only-P737D/307627867
https://www.homedepot.com/p/RYOBI-1...flator-Deflator-Tool-Only-P747/308746324
https://www.homedepot.com/p/RYOBI-1...-18-Volt-Charger-and-Bag-P1833/302648209
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442629 05/30/20 04:30 PM
W
wymi516 Offline
W
2016 KIA Forte SX 1.6L T-GDI Daughter
2013 Chevy Impala LT 3.6L GDI Mine
2014 Chrysler 200S 3.6L PFI Wife
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442642 05/30/20 05:03 PM
JohnnyJohnson Online Content
Online Content
Just sayin it takes a real pile of quarters to buy even a small compressor. I just use the small pancake compressor for my nail guns.
2004 Corolla 140708
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442648 05/30/20 05:15 PM
samven Offline
If you are not in an apartment get a small 120v model, they work better, last longer and are generally cheaper. If you need portability and plan on using it fairly regularly get one of the rechargeable 18-20 volt inflaters. The 12 v models that plug into a cigar lighter are painfully slow and get very hot. It would take 15-20 min just to add 3 or 4 lbs to 4 tires. The larger 12v models work very well but they need to be attached directly to the battery because of the current they draw which means you need to have the engine running while you use them and a car that you can get to the battery (some hide it under seats and in trunks). I have all 3 types and the 12v is rarely used, I keep it in the truck for topping boat trailer or adding air to tires for heavy loads. What I use the most is the home 120v compressor and a 7 gal portable tank. I pump the tank up to 120 psi and it sits for months sometimes, when I need air I grab it, run out to the car, add air and put it away, Then refill it when I get a chance. Its real convenient at those last min times before work or going out and realize a tire is a bit low. No mess, no noise, no connections (except the tire) and fast.
Re: Thinking of Buying Compressor [Re: samven] #5442659 05/30/20 05:30 PM
M
Mr_Luke Offline OP
M
Thanks for all the replies.
The rechargeable one sounds like a good idea.
Federated PG4476F
Re: Thinking of Buying Compressor [Re: Wolf359] #5442663 05/30/20 05:31 PM
M
Mr_Luke Offline OP
M
That Ryobi 18v for $25 seems like a good idea. Thanks.
Federated PG4476F
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442675 05/30/20 05:43 PM
W
Wolf359 Offline
W
It's probably the best bang for the buck if you already have a Ryobi battery. Usually when I need air, you only get the notice after you drive for a couple minutes so if you have an air tank at home, it doesn't do you any good. I just keep it in the car so whenever I stop, I can just air up the tire instead of waiting to get back home. It's relatively fast too, been using it for the last few years. There's a few places that still do free air, but they usually have a line so it's not worth the wait.
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442683 05/30/20 06:02 PM
M
Mr_Luke Offline OP
M
Oh, wait, it's $83 with the battery and charger.
So much for that.
Maybe the air pumps that take quarters would be better after all.
Or find a tire shop that doesn't mind checking my PSI once in a while.
Federated PG4476F
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442697 05/30/20 06:36 PM
E
eljefino Offline
E
You're overthinking this. The 12 volt cigarette lighter cheapies pay for themselves quickly. And you can do soccer balls and bicycles too.
https://www.walmart.com/ip/Slime-12-Volt-Digital-Tire-Inflator-With-LED-Light-40051/697096672
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442705 05/30/20 06:51 PM
slacktide_bitog Offline
I like the Cyclone air compressor from Pep Boys. It is $35 on eBay. Note that it is being sold by Pep Boys, so it is legit smile
Re: Thinking of Buying Compressor [Re: slacktide_bitog] #5442725 05/30/20 07:22 PM
Saabist Offline
Harbor Freight also sells what looks like the same compressor with a few detail changes. I have one and it works well. The only issue I've had is the power cord goes in underneath, so typically the wires are at an acute angle when the pump is in use. Between that and vibration the insulation started cracking where the wiring enters the pump body. I "fixed" this with some black RTV.
https://www.harborfreight.com/12v-100-psi-high-volume-air-inflator-69284.html
Re: Thinking of Buying Compressor [Re: eljefino] #5442737 05/30/20 07:49 PM
L
Lolvoguy Online Shocked
Online Shocked
L
+1
Wonderfully quick when the engine is running (alternator charging the battery).
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442738 05/30/20 07:51 PM
H
HangFire Offline
H
That HF looks a lot like my Viair 88P, which is what put an end to my serial cheap inflator purchases and subsequent destruction.
Check the duty cycle of whatever you buy. Small inflators can take 20 min to air up a flat tire... and have a user inforced 5 minute duty cycle.
Various musings: http://hangfire.net
Re: Thinking of Buying Compressor [Re: Mr_Luke] #5442741 05/30/20 07:53 PM
R
Rand Online Content
Online Content
R
viair 88p is great. I keep one in the jeep.
