Another Civic Down
by ctechbob - 07/06/20 01:25 AM
Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
36 registered members (bbhero, bob22, Bazza32, BlakeB, blufeb95, BLND1, 2 invisible), 937 guests, and 25 spiders.
Topics307,468
Posts5,311,708
Members71,852
Page 1 of 3 1 2 3
320K mileage - recommendations? #5442489 05/30/20 12:36 PM
J
joshuawesl Offline OP
J
I just bought a 2003 Dodge Durango with a 4.7 V8... For $650. It runs decent, AC works, 4WD works, etc. The bad part is this thing has 320,000 on the clock. Unsure of it's past, but as I am maniacal about maintaining my vehicles (and even this beater), I want to make sure it is lubricated properly.
The manual calls for 5W30 or 10W30.
I found a 10W30 STP bottle under the seat, and theres an STP oil filter on the engine. I can imagine that's what the PO had been using.
Right now my plan is to change it with SuperTech High Mileage 10W30, add a quart of Lucas, and use a Fram Ultra Guard filter. I've read a lot of good things about Fram UG's here, and I use them on my other vehicles with good success. The filter media is what really caught my attention with them.
I considered going with 10W30 Pennzoil Platinum Syn, and doing 5,000 mile OCI's. Just afraid to pour syn in an engine with this many miles. It's already burning a little oil as it is, and drips a couple drops overnight according to the peice of cardboard I left underneath it last night.
What do the experts here recommend?
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442490 05/30/20 12:37 PM
A
aquariuscsm Offline
A
I'd forget the Lucas (or any additives for that matter) and just use a good name brand 10w30 conventional. Maybe a conventional 10w30 high mileage oil.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: 320K mileage - recommendations? [Re: aquariuscsm] #5442496 05/30/20 12:42 PM
J
J
Like the SuperTech 10W30 HM that I mentioned in the OP?
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442498 05/30/20 12:43 PM
JohnnyJohnson Offline
What was the guy running in it to get 320,000 on it? If I knew I wouldn't change a thing unless it was $50 a gallon.
2004 Corolla 140587
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 320K mileage - recommendations? [Re: JohnnyJohnson] #5442501 05/30/20 12:46 PM
J
J
I found a half empty STP 10W30 bottle under the seat. I can only imagine that.
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442505 05/30/20 12:48 PM
Chris142 Offline
No lucas. Sounds like it has been ran on Warren oils a lot. Good stuff. Keep using that.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442513 05/30/20 12:56 PM
G
gman2304 Offline
G
Minus the Lucas....great plan!
Re: 320K mileage - recommendations? [Re: gman2304] #5442519 05/30/20 01:04 PM
J
J
No Lucas it is.
SuperTech 10W30 High Mileage and the Fram Ultra Guard.
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442522 05/30/20 01:06 PM
R
ripcord Offline
R
The oil pressure gauge on that rig is fake. As long as the engine is over 7 psi, the needle will sit in the same spot all the time, every time. If this were my rig I would put a mechanical pressure gauge on it and see what the hot idle and cruising oil pressure was. I'd make my oil choices based on that.
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442546 05/30/20 01:39 PM
CT8 Offline
When you change the oil don't add anything and see what happens if it starts burning oil add some of the motor honey to thicken up the oil. Why the Fram XG filter? High mile oil is a good thing. Keep us informed.
2015 F150 2.7
2018 F350 6.2
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442572 05/30/20 02:18 PM
B
BAJA_05 Offline
B
Super Tech High Mileage 10 or 5W30 sounds like a good plan paired with the Fram. Another vote for -- NO Lucas. Get acouple bottles of Chevron Techron Complete Fuel System Cleaner while your there and apply -- per instructions on bottle. Good stuff!! wink
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (48K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442597 05/30/20 03:28 PM
M
mpack88 Offline
M
All Lucas does is make the oil thicker and dilute the additive pack. If you think you need a thicker oil then buy a thicker oil. Maybe 10w40 or a 15w40 HDEO
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442602 05/30/20 03:43 PM
B
bbhero Online Content
Online Content
B
No Lucas it is.
Then why ask the question of what other people think if you already have your mind totally made up with what you want to do ???
Nothing wrong with what you want to do in my opinion... It's your vehicle. Do what you want to...
Though I'd say in the winter I'd not recommend using any oil additive that thinkens the oil... Cold temp performance would be dropped if you do that.
Now in late spring going into summer... go for it. I have run straight 30 grade Warren Oil HD in my lady's 98 Camry.
Nissan Altima 3.5 Coupe
Royal Purple 10w30 Carquest red 84356
"Treat your family like your friends and treat your friends like your family."
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442622 05/30/20 04:16 PM
G
gfh77665 Offline
G
Avoiding the Lucas is a good decision. If you want to inject some life back into the engine, use Restore compression repair, or Rislone compression repair. These are proven products that actually repair wear in the cylinder walls, increasing compression to near new levels. A engine with 300K+ on it is an ideal candidate.
https://rislone.com/product/compression-repair-with-ring-seal/
www.restoreusa.com
Re: 320K mileage - recommendations? [Re: joshuawesl] #5442668 05/30/20 05:35 PM
A
ajchien Offline
A
I’d change all the fluids as well as the air filter and spark plugs. Check out the brakes. Basically, get to know your new vehicle.
2003 Honda CRV EX 290,000+ miles
2003 Honda Element EX 330,000+ miles
2018 Ford Transit XLT 27,000+ miles
Page 1 of 3 1 2 3
