Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
38 registered members (Ausfahrt, A_A_G, 53' Stude, 2009Edge, bismic1, 5 invisible), 693 guests, and 23 spiders.
Topics307,747
Posts5,316,948
Members71,910
3M tape removal #5442409 05/30/20 10:31 AM
L
loneryder Offline OP
L
I need to remove an aftermarket light from a hard bag on my Harley. It was installed with the red double-sided 3M tape that the factories use. Any suggestions on how to safely remove it without harming the finish would be appreciated. Need to replace the burned out led signal fixture.
Re: 3M tape removal [Re: loneryder] #5442422 05/30/20 10:43 AM
carviewsonic Offline
I used an eraser wheel with cordless drill to remove glue left behind from 3M film. Used the slowest drill speed I could so that I wouldn't burn the paint. Don't know if this would work on double sided tape though.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: 3M tape removal [Re: loneryder] #5442460 05/30/20 11:32 AM
samven Offline
It is a job and a half. I used a razor blade to carefully split the foam so I could remove the window shades on my truck. Then just used my fingers to roll off as much of the residue as I could and then a heat gun and Goo Gone on a cloth. But mine was on clear coat paint and not a plastic bag. You might try WD40 on an inconspicuous spot to be sure it wont dull the finish of the bag and then try light heat and WD40 to remove the adhesive.
Re: 3M tape removal [Re: loneryder] #5442461 05/30/20 11:32 AM
DuckRyder Offline
I would try fishing line.
I’ve used dental floss on lower grade tape but 3m tape is strong, floss might not do it.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 3M tape removal [Re: loneryder] #5442494 05/30/20 12:41 PM
J
joshuawesl Offline
J
3M adhesive remover. It comes in a spray can. Most autoparts stores have it. Spray it on, let it soak a moment, and a plastic putty knife will slice it right off.
Re: 3M tape removal [Re: loneryder] #5442554 05/30/20 01:59 PM
CT8 Offline
See if you can call 3m for advice.
2015 F150 2.7
2018 F350 6.2
Re: 3M tape removal [Re: loneryder] #5442578 05/30/20 02:26 PM
spackard Offline
Probably fishing line to cut through it.
Best chemical for adhesive removal is heptane.
Heptane is available in Bestine, a rubber cement remover available at art supply stores.
Also sold as Bienfang UnStick.
Re: 3M tape removal [Re: loneryder] #5442595 05/30/20 03:21 PM
blupupher Offline
Just be careful of adhesive removers, some can cause damage to plastic and paint as well as adhesive.
'18 Santa Fe: PP 10w-30/OEM
'18 Soul: Delo 400 10w-30/ST
'12 xB: M1 EP 0w-20/CQ Blue
'10 Santa Fe: Pento HP 5W-30/TG
'04 F150: Delo 400 10w-30/ST
'02 F150: PP 0w-20/M1
'94 GL1500: Honda 10w-40/OEM
Re: 3M tape removal [Re: blupupher] #5442665 05/30/20 05:31 PM
spasm3 Offline
Yes test in a non conspicuous area first. I am thinking xylene, but again, it depends on your paint. I don't know what they paint bikes with. IF its lacquer, xylene and other chemicals will probably damage it.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: 3M tape removal [Re: loneryder] #5442742 05/30/20 07:55 PM
cjcride Offline
Park it in the sun for a while. Then use a hair dryer and a plastic putty knife.
A heat gun might cause damage.
Re: 3M tape removal [Re: loneryder] #5443193 05/31/20 01:17 PM
L
L
Some great ideas! Thanks all. It's fiberglass with clear coat paint like an auto.
Re: 3M tape removal [Re: loneryder] #5443297 05/31/20 03:44 PM
Tom NJ Offline
Odorless candle & lamp oil. I have yet to find a tape/sticker residue that it does not dissolve.
Re: 3M tape removal [Re: Tom NJ] #5443484 05/31/20 07:17 PM
blupupher Offline
Isn't that basically kerosene?
Re: 3M tape removal [Re: loneryder] #5444311 06/01/20 10:55 PM
A
A_Spruce Offline
A
Zippo lighter fluid will remove most adhesives without marring surfaces.
'03 Suburban
Re: 3M tape removal [Re: loneryder] #5444341 06/02/20 12:56 AM
V
vavavroom Offline
V
Waxed dental floss. Use a sawing motion.
