Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
87 registered members (53' Stude, 4WD, 97tbird, 87sammy, andy2001, Alfred_B, 6 invisible), 2,046 guests, and 26 spiders.
Topics307,451
Posts5,311,410
Members71,850
Page 1 of 3 1 2 3
Conventional Oil Benefits #5442293 05/30/20 07:38 AM
B
Bogdon Offline OP
B
Re: Conventional Oil Benefits [Re: Bogdon] #5442298 05/30/20 07:48 AM
B
bullwinkle Offline
B
Since my family has had MANY dealings with that dealership in the past, I would take anything they say with a large grain of salt! Most "conventional" motor oils are blends anyway, and very few of them are GM Dexos rated nor approved.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Conventional Oil Benefits [Re: Bogdon] #5442314 05/30/20 08:06 AM
ABN_CBT_ENGR Offline
From a purely technical engineering standpoint, the article is fatally biased against synthetics in general despite having several accurate assessments contained within.
What truths it contains is negated by the truths it leaves out overall.
First is the term "conventional" oil-in 2020 that almost always means a dino oil base with "synthetic additives"
Given grade III qualifications and SCOTUS rulings, he doesn't clearly define where a "conventional" oil ends and a "synthetic" begins so his comparisons are invalid on that point alone.
He then goes off the rails about engine longevity and gear wear.
Its clearly somewhere between a sales pitch and a personal dislike of synthetics disguised as a legitimate technical article by pretending to present both sides equally and for that reason should be dismissed as junk.
Re: Conventional Oil Benefits [Re: Bogdon] #5442315 05/30/20 08:16 AM
M
MrHorspwer Offline
M
This is a goldmine of great quotes!
Quote
There is a common myth that exists about synthetic oils that say that putting a synthetic oil in an older engine can cause the oil valves to crack and cause oil to leak.
Oh my! Please think of the oil valves!
Quote
While synthetic oil generally protects better over a longer time, it flows more smoothly than conventional mineral oils – and for an older engine, this can mean a greater chance of grinding gears.
I knew it! Synthetic engine oil causes transmission problems and grinding gears!
Re: Conventional Oil Benefits [Re: Bogdon] #5442316 05/30/20 08:16 AM
B
buster Offline
B
Quote
is the damage you won’t be doing to your wallet. In many cases, synthetic oils can cost up to twice as much as conventional oils per quart, even within the same brand. For some drivers, this added cost simply isn’t worth the added performance power – especially in vehicles that don’t require synthetic oil.
I'm sorry but it irks me when people gripe about the cost of oil. Oil is NOT expensive, even boutique brands. Even if you bought one of the most expensive brands and got 6 months out of it, it's still inexpensive. Cars are expensive. Engines are expensive. Oil is not.
No offense to the OP, but this article is garbage. This article is equivalent to a poorly formulated Group I oil with a Noack of 20%.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Conventional Oil Benefits [Re: MrHorspwer] #5442322 05/30/20 08:24 AM
Quote
Quote
Don't forget
"older and more experienced engines"
"slower flow of a conventional oil promises better lubrication for aging engines"
Somewhere this could meet the legal requirement of some form of age discrimination.
This article isn't really written good enough to be badly written
Re: Conventional Oil Benefits [Re: Bogdon] #5442327 05/30/20 08:30 AM
A
alarmguy Offline
A
The bottom line is, it doesnt matter if the oil is conventional or synthetic. Its just oil with the same API ratings.
We sometimes over complicate things. Oil is oil is oil all the same as the API ratings say.
Of course, their are other ratings/approvals, again, just go by the rating/approval recommended by your engine maker and whether it is synthetic or conventional doesnt matter.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Conventional Oil Benefits [Re: bullwinkle] #5442329 05/30/20 08:33 AM
4WD Online Confused
Online Confused
What a coincidence … that dealer had some ZR2's I looked at online just 10 minutes ago. Are they bad news ?
Re: Conventional Oil Benefits [Re: ABN_CBT_ENGR] #5442330 05/30/20 08:35 AM
I
Inspecktor Offline
I
Reads just like the letters I used to get from the Nigerian prince who tried to send me millions of dollars.
2004 Mini Cooper 45,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 75,000 mi
2001 Buick LeSabre Limited 303,000 mi
2001 Subaru Outback 170,000 mi
Re: Conventional Oil Benefits [Re: Bogdon] #5442337 05/30/20 08:48 AM
K
ka9mnx Offline
K
"This being said, however, it is still not recommended to use synthetic oil in engines that have experienced significant actions – specifically, those that have reached around 75,000 miles on the odometer. This is usually a signal that the engine is getting older and is more susceptible to wear on its inner gears and moving parts."
WOW! When I bought my F150 at 182k miles and B2500 Van at 162k miles I switched them to synthetic. Oh my, what have I done to those poor engines, transmissions and rear diffs?
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Conventional Oil Benefits [Re: Bogdon] #5442338 05/30/20 08:49 AM
sloinker Offline
"Given grade III qualifications and SCOTUS rulings, he doesn't clearly define where a "conventional" oil ends and a "synthetic" begins so his comparisons are invalid on that point alone."
I would like to see these supreme court rulings.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Conventional Oil Benefits [Re: Bogdon] #5442339 05/30/20 08:51 AM
O
Oildudeny Offline
O
Doesn't wet my whistle.. 0w20 regularly available and always pay a reasonable price, napa or super tech full synthetic.
Re: Conventional Oil Benefits [Re: Bogdon] #5442340 05/30/20 08:52 AM
K
Kira Offline
K
We all have "prisms" through which we see things.
I see a "sales pitch" article which is appealing to the poor, overwhelmed American car owner who's victimized at every turn.
"THEY'VE been confusing you and taking your money. We'll protect you".
Synthetic oil = mask. And that's as far into politicizing it as I'll go.
Re: Conventional Oil Benefits [Re: sloinker] #5442345 05/30/20 09:00 AM
It was NAD, my oversight. Typed first- looked last
I stand corrected.
Re: Conventional Oil Benefits [Re: Bogdon] #5442374 05/30/20 09:30 AM
csandste Offline
Thought DEXOS is largely Group 3 and up. What are they using in their dealership?
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Page 1 of 3 1 2 3
