Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
52 registered members (A_Spruce, Alex38, Ag76, Arob, AlienBug, ae101, 6 invisible), 1,236 guests, and 19 spiders.
Topics307,468
Posts5,311,698
Members71,852
TPMS problem #5442209 05/30/20 02:17 AM
R
rrretiree7 Offline OP
R
I checked my tire pressure with two different top of the line tire gauges. All the tires were at 33 psi. While scrolling through the data center they post
all four tires showed mid twenties. Any info is appreciated. P.S. For several days after, I had the low pressure tire symbol and stay on
Re: TPMS problem [Re: rrretiree7] #5442215 05/30/20 03:07 AM
ctechbob Offline
Helpful to know make model and year of car. There's many different kinds of TPMS systems out there.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: TPMS problem [Re: rrretiree7] #5442216 05/30/20 03:08 AM
W
WyrTwister Offline
W
What year and what make of car ? What pressure does your owner's manual indicate ?
Wyr
God bless
Re: TPMS problem [Re: rrretiree7] #5442362 05/30/20 09:15 AM
G
Gebo Offline
G
I know I risk being criticized with the following comment. But here goes.
Most of the time when I have an issue with any of my cars, I first check my battery. I have one of those
battery checkers that read the CCA and such. If my battery is ok, I will disconnect the
battery for 30 minutes and let it sit. Then I reconnect and turn key on and leave it on
for about 1 minuted. Then I start the engine and drive around in an old man mode
(which I am) for about 15 minutes and go back home.
This may not help you but it's worth a try. Sorta like turning off and rebooting your computer.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: TPMS problem [Re: rrretiree7] #5442534 05/30/20 01:21 PM
funflyer Offline
TPMS needs to be reset so it has a baseline tire pressure to go by. First inflate the tire pressure where you want, then perform a reset. Look in the owner's manual for the instructions.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: TPMS problem [Re: funflyer] #5442621 05/30/20 04:15 PM
J
JTK Offline
J
What vehicle is this procedure for?
I've had TPMS equipped vehicles for the past 15yrs or so and none of them required that.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: TPMS problem [Re: JTK] #5442625 05/30/20 04:21 PM
E
eljefino Offline
E
Toyota requires this. Of course we don't know what OP has.
My toyota sensors on the scantool read quite a bit off from my reference gauge. But toyota is set to alarm at 80% of proper PSI, so, perhaps, the actual reported number isn't that accurate. I cannot pull up any particular tire or its PSI on the dashboard of my prii, only through the scan tool.
Toyota procedure is to double-check correct pressure then hit a button under the dash to set/reset.
Re: TPMS problem [Re: rrretiree7] #5442782 05/30/20 08:55 PM
funflyer Offline
Yes it's for my Toyota and just guessing that other makes might require the same. Might also be something that the dealer might have to do.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
