Originally Posted by hatt
Originally Posted by HangFire
Originally Posted by Alfred_B
I don't think a lot of mowers get discarded due to rusted decks.
Alfred, I surmise you don't live in Hill, Rock, Gopher and Rust country.
When I called my local welding shop about my Kubota deck, he ran through all the options quickly and bored, like he was talking in his sleep. Did a superb job, too.
Your assumption would be correct in flat 1/4 acre suburban tracts.
Your Kubota deck rotted out or wore out? What time frame. Mowing over a bunch of sand will eventually damage a deck. If you use a mower a lot the deck becomes a wear item. The deck rotting out in 5 years is another issue.
Rotted out at about 13 years old. When I took it in to be welded, found out at had been welded before. Not the first owner, don't know the previous history. It good thick steel, and a new one cost more than what I paid for the whole mower.
"Wore out" would not be a problem. Parts were readily available, and while noy cheap, usually worth it.
