FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
43 registered members (alphadog, BigGeo, BLND1, agpatel, 4 invisible), 1,104 guests, and 25 spiders.
Topics307,396
Posts5,310,310
Members71,843
overfilled my crankcase by 3/10 of a liter - problem? #5441587 05/29/20 08:49 AM
T
tom in boise Offline OP
T
Changed the oil for the first time on our 2019 VW GTI yesterday. Capacity is 5.7L. I had a senior moment and put in 6L. Any opinions on whether I should try to drain the extra 3/10L out of there or not worry about it.
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441588 05/29/20 08:51 AM
B
buster Offline
B
It's fine. If it bothers you, I'd drain it but it won't cause any harm.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441593 05/29/20 08:57 AM
CT8 Offline
That is not enough over fill to make a difference.
2015 F150 2.7
2018 F350 6.2
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441600 05/29/20 09:03 AM
G
Gebo Offline
G
I'd fill it that way on purpose.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441601 05/29/20 09:03 AM
Donald Offline
I do not see a problem. If engines were damaged by a little over or a little under the roads would be littered with broken down vehicles.
If I have a little left in a oil container I often just add it even if it will make it a little over. Don't want a cup of oil left in a 5 QT container.
In my Powerstroke which takes 14 QTs, I doubt an extra QT would matter.
2015 Ford F-250 w/Powerstroke
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441602 05/29/20 09:03 AM
R
ragtoplvr Offline
R
you are in the USA so you probably got quarts rather than liters. A quart is less than one liter. 6 quarts would actually be pretty close to 5.7 Liters. Drive and enjoy.
In any case. an extra .3 liter will not cause a problem, even on a picky German car.
Rod
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441609 05/29/20 09:05 AM
ABN_CBT_ENGR Offline
little risk, carry on
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: ragtoplvr] #5441625 05/29/20 09:14 AM
T
T
Rod
Yes, but in this case, since VW is so picky on the oils, the bottles are in liters. Anyway, at that point, my thoughts are to leave it alone as the 5% overfill probably falls in the tolerance range of the dipstick and oil pan any way.
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441630 05/29/20 09:18 AM
javacontour Offline
.3L over on 5.7L is about 5% so likely not an issue.
network down, IP packets delivered via UPS -BOFH
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441642 05/29/20 09:30 AM
T
T
Just ran out and checked the dipstick and it basically is at the full mark anyway. So I am going to leave it and resolve to do better next time.
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441643 05/29/20 09:32 AM
supton Offline
I normally round like this on my vehicles. I wouldn't worry about it.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441647 05/29/20 09:36 AM
T
T
I think I would cause more harm trying to resolve the non issue than if I just leave it alone.
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441650 05/29/20 09:40 AM
supton Offline
Depends--how would you resolve? Way back when, when I had my VW, I did topside oil changes. If you are doing likewise you could pull out 0.3L and make it whole. Unless if the tubing was dirty I don't see a problem with this.
But to reiterate, I don't see the need to do so... No harm, no foul, either way.
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: tom in boise] #5441653 05/29/20 09:40 AM
F
Farnsworth Offline
F
It's just a pot of oil with a pickup tube in it. As long as it doesn't come up where the crankshaft spinning starts to pull oil up from the pot of oil it has no brain to know the difference higher or lower. Not the best to overfill past the top mark, because it's just the rule. What happens when we bounce up and down on roads, corner, or go up and down steep hills? The oil doesn't stay level.
Re: overfilled my crankcase by 3/10 of a liter - problem? [Re: Farnsworth] #5441661 05/29/20 09:46 AM
M
mbres2000 Offline
M
The bozos at my local oil change shops typically add around 1/2 qt. too much, but that's better than not adding enough. Still, it pi$$es me off.
