Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
110 registered members (72te27, 2010Civic, 18LateModelFan, 14Accent, 4WD, 9 invisible), 1,814 guests, and 24 spiders.
Topics307,463
Posts5,311,619
Members71,852
Page 1 of 3 1 2 3
Espresso #5441567 05/29/20 08:34 AM
B
buster Offline OP
B
I've always loved espresso. I was buying lattes a lot pre-pandemic so I decided to start making my own. Not only am I saving a lot of money, I can make it how I want it. Any tips on making lattes or espresso?
[Linked Image]
[Linked Image]
[Linked Image]
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Espresso [Re: buster] #5441576 05/29/20 08:39 AM
Quattro Pete Offline
To make espresso, for best results you will need:
- freshly roasted beans
- grind them just before pulling an espresso shot
- a decent espresso machine that can produce 9 bars of extraction pressure.
[Linked Image from i.imgur.com]
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Espresso [Re: buster] #5441585 05/29/20 08:48 AM
B
buster Offline OP
B
^yes that is the expensive way. Ultimately the best way.
Re: Espresso [Re: buster] #5441619 05/29/20 09:12 AM
A
Alfred_B Offline
A
Mine is a cheapo setup, too. But the coffee is always illy
[Linked Image]
Re: Espresso [Re: buster] #5441627 05/29/20 09:17 AM
B
buster Offline OP
B
^I almost bought that one. While it may not produce espresso as good as the machines, it's still good.
Re: Espresso [Re: buster] #5441657 05/29/20 09:44 AM
5
555 Offline
5
Have friend who says a burr grinder makes a big difference in balance of acidity, oils.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Espresso [Re: buster] #5441658 05/29/20 09:44 AM
J
John_Conrad Offline
J
good morning:
i can't "expresso" my opinion as i have never tried one!
hopefully i can learn from this thread. good day Coffee2
Safety doesn't happen by accident.--author unknown
Re: Espresso [Re: buster] #5441672 05/29/20 10:01 AM
G
GSCJR Offline
G
Use tap water and don't fill past the valve located on the side of your moka pot then, fill the coffee filter right to the top but avoid packing it firmly. Use a low source of heat and allow the water heat up gently keeping the lid closed but keeping an eye on it. Once the espresso begins to brew, open the lid and monitor the level; remove from the heat as it approaches the top as it will still continue to brew off the heat (this avoids scorching the espresso). Use a long spoon to stir the espresso inside the moka before serving. I won't comment about which espresso to buy because you're already on the right track.
I need to get one of those mugs!
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Espresso [Re: Quattro Pete] #5441678 05/29/20 10:05 AM
G
GSCJR Offline
G
Beautiful!
Re: Espresso [Re: John_Conrad] #5441679 05/29/20 10:05 AM
5
555 Offline
5
Originally Posted by John_Conrad
good morning:
Haven't you "bean" to a coffee house? Does it "grind" you the wrong way? Waiting in those long lines gets me "steamed" .
84 XJ6 M1
04 Subaru STi Motul
Re: Espresso [Re: buster] #5441680 05/29/20 10:07 AM
sloinker Offline
Buy a pump machine like the Breville above. Buy beans and grind at use. The filter basket and pull pressure will dictate the grind. You want plenty of crema and a steady zlow pull and a firm moist puck. zThere is a learning curve.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Espresso [Re: buster] #5441686 05/29/20 10:12 AM
B
BMWTurboDzl Offline
B
Burr grinder is a must for home brewing but a decent one can cost about $200. shocked2
435i
Re: Espresso [Re: buster] #5441726 05/29/20 10:57 AM
9
97prizm Offline
9
Burr grinder is a must. My dad had a spice grinder and a cheaper espresso machine and it made acrid espresso. The burr grinder helped. Also a high end water filter. I use a Zero water 5 stage filter. I get them at Target.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Espresso [Re: 97prizm] #5441737 05/29/20 11:09 AM
Zero Water is great. That's what I use as well.
Re: Espresso [Re: sloinker] #5441743 05/29/20 11:14 AM
E
ET16 Offline
E
I have a similar Breville. They're great, but pricey. A used Gaggia is a good way to start, too.
Page 1 of 3 1 2 3
