Forums Migration
Please read this thread
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
gas cans, nato style
by BeerCan - 07/09/20 06:24 PM
07 Mustang Fuel Pressure Sensor error
by Barkleymut - 07/09/20 06:21 PM
2007 Hyundai veracruz 0w40?
by Envoyguy - 07/09/20 06:19 PM
How bad is it?
by Averroes - 07/09/20 05:29 PM
various vintage oil filters cut apart
by dogememe - 07/09/20 05:26 PM
LCD burn in? Seriously?
by Klutch9 - 07/09/20 04:12 PM
WTB - 1050 video card
by stockrex - 07/09/20 02:28 PM
how good is royal purple gear oil and syncromax?
by apollo18 - 07/09/20 02:22 PM
Wire Brushes
by Gebo - 07/09/20 01:59 PM
MOBIL 1 0w20 vs AMAZON BASICS 5w20
by IBelieveinlube - 07/09/20 01:51 PM
907Lynette, mckaskie, mkid, kuldeep, BillDros
71900 Registered Users
97 registered members (4WD, 19elantragt, 77Se7en, 2015_PSD, Astro14, AlienBug, 9 invisible), 1,752 guests, and 52 spiders.
Topics307,665
Posts5,315,289
Members71,900
Alignment good then bad #5440908 05/28/20 11:56 AM
B
Barkleymut Offline OP
B
I purchased the 2007 Mustang GT last September from a private seller. He disclosed (and it was obvious) that his aunt who was the owner drove the car into a ditch. The alignment was way off but still driveable. I took the car to Firestone and they aligned it and gave me a fancy printout. Ever since the car has pulled just a little to the left, but then for no reason it will track straight as an arrow at 70 mph. Then again for no reason it will start pulling lightly to the left. Any ideas what is going on?
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Alignment good then bad [Re: Barkleymut] #5440912 05/28/20 12:01 PM
B
bbhero Online Content
Online Content
B
Is the car in the right lane of a 4 lane divided highway ??
And is the road crowned ??
Is the car pulling left across that crown in the center of the road??
If yes to all three above... I'd take it back to them.
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Alignment good then bad [Re: Barkleymut] #5440928 05/28/20 12:15 PM
V
vivaUkraine Offline
V
Something's worn in your suspension. Time to replace tie rods, center link, etc
Re: Alignment good then bad [Re: Barkleymut] #5440931 05/28/20 12:17 PM
R
ripcord Offline
R
Does hitting the brakes hard change anything for a while?
Re: Alignment good then bad [Re: Barkleymut] #5440932 05/28/20 12:18 PM
J
JeffKeryk Offline
J
Yes, the alignment should have a warranty, probably 1 year.
As others have said, even a perfect alignment with good rubber will be affected by the road you are on.
Get your tires inflated properly, if necessary. Retest on a few roads.
Take it back to shop for a double check.
Ya never know. Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Alignment good then bad [Re: Barkleymut] #5440936 05/28/20 12:20 PM
B
B
From what I can tell, the road is not crowned ( I drive 60 miles a day - mostly on I-95 and Interstate 288 )
Re: Alignment good then bad [Re: Barkleymut] #5440937 05/28/20 12:22 PM
B
B
I check the tire pressure weekly, all 4 tires are at 35 psi. I had a few suspension components replaced during the inspection last year, guess it is time to take it back.
Re: Alignment good then bad [Re: Barkleymut] #5440941 05/28/20 12:23 PM
SeaJay Offline
Getting a car's steering aligned does not mean that there isn't any play in the suspension and steering from worn bushings or other parts.
Re: Alignment good then bad [Re: Barkleymut] #5440943 05/28/20 12:26 PM
Dave1027 Offline
If the car went out of alignment after running into a ditch then something is likely bent or broken. Trying to align it without replacing the bad component usually does not work out well. Sounds like Firestone did not identify the bad component that is causing your issue
Re: Alignment good then bad [Re: Barkleymut] #5440944 05/28/20 12:26 PM
supton Offline
I'm going to go with something broke or wornout. I'd start with an inspection of the suspension. If it wasn't something you could do, I would think a shop should be able to diagnose for small money (put on lift, push things around, should be what, an hour labor?).
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Alignment good then bad [Re: ripcord] #5440946 05/28/20 12:30 PM
B
B
No, I am guessing that you are suggesting it may be a brake that is dragging....I have not seen evidence of that (although that was my first thought)
Re: Alignment good then bad [Re: Barkleymut] #5440959 05/28/20 12:42 PM
K
Kira Offline
K
Tie rod ends are what stress my head 24-7. They're so small and do so much.
Front to rear the tires. Inspect them when you do it.
Lead tire into ditch OK? Are they old?
Re: Alignment good then bad [Re: Barkleymut] #5440970 05/28/20 12:53 PM
ABN_CBT_ENGR Offline
Just to be clear here
This has been continuous for 8 months?
If so, why is the concern now? ( lots of things can happen in that time)
If it hasn't been continuous, who not go have the problem investigated?
Just curious
Re: Alignment good then bad [Re: Barkleymut] #5441018 05/28/20 01:53 PM
B
B
Yes it has been continuous for 8 months, just thought about it today while driving to work.
I have not rotated the tires since I purchased the car, probably around 13k miles ago. The tire that went into the ditch was trashed, along with the rim. All 4 tires were fairly new when I purchased the car.
Re: Alignment good then bad [Re: Barkleymut] #5441022 05/28/20 01:58 PM
R
ripcord Offline
R
I was thinking play in suspension components. My brother's Jeep Liberty had something loose in the front end that would affect the tracking. He noticed that if he hit the brakes hard in reverse it would pull worse and it improved for a while if he braked hard going forward. I think he ended up having some control arm bushings or something replaced.
