Forums Migration
Please read this thread
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
32 registered members (carlprop, ArrestMeRedZ, blufeb95, 07hemi, BLND1, 2 invisible), 976 guests, and 21 spiders.
Topics307,580
Posts5,313,555
Members71,876
Dewalt titanium drill bit set #5440681 05/28/20 07:29 AM
Donald Offline OP
I have a set of the gold colored titanium drill bits from Dewalt. Says good for wood or metal drilling.
I tried to use them to drill through a bunch of hard drives before throwing the hard drives out. But the drill bits dull very quickly.
What gives
2015 Ford F-250 w/Powerstroke
Re: Dewalt titanium drill bit set [Re: Donald] #5440688 05/28/20 07:37 AM
T
Trav Offline
T
Crap bits, get some cobalt bits.
Re: Dewalt titanium drill bit set [Re: Donald] #5440691 05/28/20 07:42 AM
Astro14 Offline
Titanium in this case is marketing. It’s a microscopically thin surface coating which is supposed to make the bits harder to clog but it doesn’t work.
Cobalt steel alloy is the best, but even those will eventually become dull.
Get a bit sharpener. They work wonderfully.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Dewalt titanium drill bit set [Re: Astro14] #5440702 05/28/20 07:52 AM
4WD Offline
Those gold bits don’t seem to rust as bad if left in a humid spot and are easier to see …
Think that completes the bonus list !
Re: Dewalt titanium drill bit set [Re: Donald] #5440726 05/28/20 08:28 AM
R
Rand Offline
R
just take the hdd apart and keep the super strong magnets.
Re: Dewalt titanium drill bit set [Re: Donald] #5440832 05/28/20 10:28 AM
I
irad Offline
I
Hammer is the tool. You could secure wipe the drive and give them away to people who need them. Free software is available, ultimateboot and hirens come to mind.
Re: Dewalt titanium drill bit set [Re: Astro14] #5440855 05/28/20 10:57 AM
spasm3 Offline
There are different cobalt bits. M35 is 5% cobalt , m42 is 8%.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Dewalt titanium drill bit set [Re: spasm3] #5440862 05/28/20 11:06 AM
Astro14 Offline
Thanks!
I didn’t know that...
32 Packard 15W40
05 MB S600 0W40 M1
Re: Dewalt titanium drill bit set [Re: spasm3] #5440865 05/28/20 11:08 AM
T
Trav Offline
T
M42 is better used in a drill press as they are a little too brittle especially in the smaller sizes for hand use. Solid carbide is the best for hardened steel but is way too brittle even for a standard chuck drill press, they don't tolerate even small amounts of run out and cost a small fortune.
Re: Dewalt titanium drill bit set [Re: Trav] #5440873 05/28/20 11:14 AM
spasm3 Offline
Thanks! I did not know that m42 was better for drill presses, makes sense. I have m35 they are much better than titanium. I really see no difference in hss coated with titanium and plain hss.
Re: Dewalt titanium drill bit set [Re: Donald] #5440898 05/28/20 11:45 AM
K
Kawiguy454 Offline
K
If you have external dock us "Darik's Boot and Nuke" to do an NSA grade erase. then sell or donate them. If you dont have time then drill the drives from the back circuit board side which is cast aluminum. Older drives have stainless cover which is whats killing your drills "bits" :-)
I have disassembled dozens of drives with just torx bit. the magnets inside are truly amazingly strong. And the older high perf drives have the biggest magnets.
Re: Dewalt titanium drill bit set [Re: Donald] #5441121 05/28/20 04:27 PM
double vanos Offline
I took my hard drive apart with an air chisel. A band saw took care of the rest. The box the drive is in is incredibly robust.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Dewalt titanium drill bit set [Re: spasm3] #5441473 05/29/20 06:35 AM
T
Trav Offline
T
M35 is ideal for cordless drills, you get the performance of cobalt and longer battery life than if using common or coated bits without the brittleness of M42.
Keeping them sharp is key to good performance with any bit, a small jig type tool is good to have.
This is a decent little grinding wheel jig, for those who don't have fab skills its worth it otherwise this is easily made up.
https://vsctools.com/shop/drill-bit-sharpening-jig/
