Cam specs for '62 Corvette Fulie
Los Gatos, CA
I have been asked about the cam specs for a 1962 Corvette 327 FI, 360 HP.
My BIL is adjusting the lash on his restored '62. He bought the engine (period correct) from a builder.
I don't know that much about the early cars...
My understanding is the Duntov 097 cam was used in performance solid lifter 1962 Corvettes.
I think it was used from '57 until '63; after that the famous 30-30 radical cam was used.
The 097 lash specs should be .008 and .018 hot.
If you have knowledge regarding a different cam, please chime in.
I really think the timing cover should be removed and check for numbers.
I asked him to measure I/O valve lift and I can compare that to the specs I know of.
Thanks in advance.
Hmmm...checked my libreary...I had a book on the Chev fuellies...appears to have been borrowed over the last 20+ years...
The legendary Duntov SBC solid lifter cam was referred to as the 30-30 cam because that was the cold valve lash spec, .30" on both intake and exhaust valves. Now this is coming from the memory banks of a 72 year old former hot rodder, so take it with a grain of salt.
According to a book I have SBC performance the pre 64 vette had cam # 3736097 mechanical lash .012/.018.
Yes, that's the Duntov 097. I believe the intake lash is .008".
I also think this is what is in his car.
Yes, the nickname was from the I/O settings. People also Mickey Moused around with the settings.
Remember the rule better loose than too tight. especially the exhaust.
Better check double that .008" I number.
We could run Street strip cams a bit tighter on the intake for track days,
This is a Vintage, car I would err on the side of conservatism.
This is a very mild cam. You should be fine at 0.01: cold..
Also see where they are at.
I would check and record three first.
And Re- torque the head bolts while you are in there.
- Ken
- Ken
Good advice. The valves are already loose; too late.
I asked him to measure the lift at the valve with the clearance set to 097 specs.
If the lift matches the 097 valve lift specs, I think I can call it good. Otherwise...
He has a ton of $$ and years into this car. He found a period correct block and Mechanical FI Unit.
You are so right; he doesn't wanna get this wrong.
Personally, I would pull the timing cover and look for ID numbers.
While he believes it is the stock reproduction cam for that engine, it could be anything.
I agree .010 cold Intake is a safe setting. This is a show and fun car; no beating.
I asked my BIL Mark to measure the intake and exhaust lift at the valve as best as he could.
He came up with .468" intake and just a taste more on the exhaust valve.
I used .468" divided by 1.37 rocker ratio to come up with .342 lobe lift.
The 097 cam is generally thought to be .395" and .399" I/O.
I am calling this the 097 cam for now. I suggested .012" and .018" lash.
My Motor Manual lists .008" for the intake, but my research says this is more for the weekend warrior who wanted a little more duration...
I also pinged my friend Lars Grimsrud. Yes, I know I am name dropping... He also cautioned me on the tight valve numbers.
Thanks for all your help.
