How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
99 registered members (ARCOgraphite, aba4430, 555, Arrechera, 2K2AcuraTL, 2015_PSD, 10 invisible), 1,519 guests, and 36 spiders.
Topics307,317
Posts5,308,878
Members71,828
Bent Jack Stand Ratchet Bar #5440606 05/28/20 01:44 AM
The Critic Offline OP
I have a pair of Craftsman jack stands (black stand with yellow ratchet bar). They are used very infrequently
- they have probably seen fewer than 50 uses. During inspection today I found one of the ratcheting bars to be visibly bent, see below. The ratcheting bar on the other stand is fine.
How does this happen? I have never exceeded the weight capacity.
2020 Ram 1500 5.7L eTorque - <1K - Factory Fill
2011 Toyota Prius 1.8L - 209K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440633 05/28/20 05:11 AM
dlundblad Offline
Can you post a photo of the fully assembled good stand? I’m having a hard time visualizing this and google showed nothing.
Are you the only one who uses these? If not, I’m guessing that’s how it was damaged.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440653 05/28/20 06:26 AM
T
Trav Offline
T
N Idea why it happened but it would be in the bin yesterday.
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440672 05/28/20 07:13 AM
M
mk378 Online Content
Online Content
M
That results from sideways force, should the car roll or tip while it is up on the stand. The weight rating is based on the load force being straight down. Yes the integrity is seriously compromised, do not use again.
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440673 05/28/20 07:14 AM
W
WyrTwister Offline
W
Guess in someone managed to set the stand up on un-level ground / surface / ground or otherwise got the load off center to the ground / surface ?
Have you used it on a very heavy vehicle ( truck ) . I would think it would take a lot to bend that metal ? Good news is , it bent , in stead of breaking .
I agree , get rid of it . In a way that no one will find it and try to use it .
I have a pair of jack stands made from " sheet steel " that I gave my late Dad . They are still fine .
Also have a pair of cast metal jack stands I purchased used , several years ago . They maybe HF ? Wonder if they are part of the recall ? Are the recalled HF units breaking or bending ?
Wyr
God bless
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440676 05/28/20 07:18 AM
M
Online Content
M
The recalled HF units have a different failure mode, the holding pawl will unlatch and allow the car to drop.
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440732 05/28/20 08:38 AM
supton Online Content
Online Content
How often do you inspect for this? I'm wondering if it's always been there.
Could it be from lowering the vehicle onto one jack, then raising the other side, causing shift in load?
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440797 05/28/20 09:54 AM
I
IndyIan Offline
I
Yikes! I'll have to have a look at mine, as they get side loaded probably more than they should. I'm surprised that would bend even if you ran the stand over laying on its side
06 Focus ZXW, 5spd manual, 220km
18 Outback 2.5 CVT 35km 0W20
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440911 05/28/20 11:59 AM
B
Barkleymut Online Content
Online Content
B
Is it possible that they looked like this when you bought them, and you are just now noticing the curve?
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5440956 05/28/20 12:40 PM
E
E365 Offline
E
I’m also putting up my vote for them being bent before you ever bought them.
I can’t imagine the lateral force required to bend that wouldn’t have broken the base about 10 times over. Or in the real world it would probably tip over before it could ever come close to bending.
Whatever's on sale...
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5441035 05/28/20 02:13 PM
T
twouvakind Offline
T
I see scrap metal.
Just put the friggin' Maxlife in and be done with it!
Re: Bent Jack Stand Ratchet Bar [Re: E365] #5441045 05/28/20 02:24 PM
spasm3 Offline
If you never really raised them up, you may never have noticed. To bend that, you had serious lateral load, you would know how you did it. I vote bad when you bought them, and lowered you didn't see it.
But i would not use it.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Bent Jack Stand Ratchet Bar [Re: The Critic] #5441050 05/28/20 02:35 PM
doitmyself Offline
Aren't those made of cast iron that will crack/break, but not bend? My vote: already bent when purchased new. For fun, put it in a press and see if you can bend it back.
Re: Bent Jack Stand Ratchet Bar [Re: doitmyself] #5441449 05/29/20 04:44 AM
A
ajchien Offline
A
Yeah, I’ve been confused by that as well for many years now.
I see US Jack and Pro-Lift advertise their ratchet bars as “cast ductile iron”. From what I understand, “cast ductile iron” is a subset of “cast iron”. It was apparently first made around 1943. Since it’s been around for such a long time, does that mean that all ratchet bars in jack stands are cast ductile iron? And those other manufacturers that list their ratchet bases as “cast iron” - is that just a failure of their marketing guys, just omitting the term “ductile”? I have no idea.
Anyway, I just checked out my 4 ton craftsman black and yellow stands. They’re straight.
2003 Honda CRV EX 290,000+ miles
2003 Honda Element EX 330,000+ miles
2018 Ford Transit XLT 27,000+ miles
Re: Bent Jack Stand Ratchet Bar [Re: supton] #5441942 05/29/20 04:31 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
+1. I’m surprised they would lower or raise with a bend like that. I know they’re not tight tolerance items, but still...
