Forums Migration
Please read this thread
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
B2300 frame repair.
by simple_gifts - 07/08/20 01:48 PM
O2 sensor adapter with "mini catalytic converter"
by keantoken - 07/08/20 01:48 PM
Peeled veneer paint on vintage Pioneer
by Alfred_B - 07/08/20 01:40 PM
Shift Solenoids Cleaner additive?
by Husam - 07/08/20 01:11 PM
D rings for towing
by cknight49090 - 07/08/20 01:06 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
115 registered members (5AcresAndAFool, 2009Edge, 4WD, 2015_PSD, 2010Civic, 55hambone, 9 invisible), 1,845 guests, and 31 spiders.
Topics307,620
Posts5,314,362
Members71,888
Page 1 of 3 1 2 3
Can a 2005 Volvo go 300K Miles easily? #5440582 05/27/20 11:17 PM
V
VolvoZ Offline OP
V
Answer: Yes. So my son’s 2005 Volvo V70R passed the 300K mark recently and figured it was time to celebrate, share some things about this car, and review these Rs in general (We have three in the family, the others are an 04 with 225K and an 06 with 259K). First and foremost, this car doesn’t look like it has 300K miles on it. Gorgeous inside and out. Very rare color combo: Magic Blue with Atacama (basically a shade of orange) interior. Absolutely gorgeous, just a handful imported in that combo. Atacama leather was $1500 option when new, roughly half what my son paid for the car!
History: my son is second owner...coming up on 5 years of ownership. Bought with 235K miles. Check engine light was on due to PCV system hose being cracked. Previous owner took reasonably good care of it. Regular Dino oil changes at probably 5K miles or so by prior owner. Not much in the way of service records.
Mech Specs: 2.5L I5 engine, high pressure turbo, 300 hp, all wheel drive.
Seats/Interior: Amazingly comfortable, supportive, and durable. The Rs have upgraded sport bolstered seats, leather door panels, dash, sport steering wheel, console compartment. Very modern and good looking interiors for a 15 y.o. car. Very good stereo system especially with the factory subwoofer.
Brakes: Brembo aluminum calipers, big discs from the factory
Suspension: it is lowered from factory vs. regular V70 and includes electronically adjustable Ohlin/Monroe dampers. Not a big fan of electronic shocks due to high cost and limited availability. Adjustable damping from Comfort, Sport, Advanced. The damping is controlled as part of the 4-C system, which supposedly dynamically adjusts to optimize handling and is integrated into dynamic stability traction control system.
Engine: Engine runs great, smooth, good power, quiet. No oil leaks externally other than the oil cooler needing new O-rings,but that was easy fix. It is using oil which we think are the turbo seals primarily. That’s the only thing that indicates it has high mileage. No smoke from the exhaust. Regular oil changes helped this engine for sure, but the conventional oil changes did not help the PCV system. PCV system was pretty sludgy but not blocked. I believe dino oil did not help the turbo seals. Typical oil changes under my son’s ownership have been Pennzoil Platinum and Mobil 1 at 5K OCIs using Mahle, Champ, and Carquest/Wix filters. Been using 0W-40 lately.
Exhaust: original exhaust. Very high quality. Guessing it will go another 5+ years easily. The muffler looked like it was rusting badly, outer layer was coming off, but turns out to be just the first layer (sacrificial?)revealing a nice shiny layer beneath (same thing with the other two family V70Rs, so this is not an outlier).
Body: Fantastic. Solid. Heavy. Extremely rust resistant. The rust resistance is why i love Volvos so much. Underside is very clean and well protected from the factory. There is some rust JUST starting at some of the seams underneath, partly attributed to spending much of its early life close to the coast and NE winters. But any rust that starts on these cars progresses in slow motion. Doors are bank-vault like.
Performance: Good acceleration and handling. It wants to be a sports wagon, which it is, but it’s heavy, so it is not really nimble. It’s got a bit of turbo lag but pulls strong after under way. These cars at at home on the highway. It has an Aisin 5 speed automatic, and due to transmission limitations, the first two gears are torque limited to 258 lb-ft vs. full engine capability of 295 lb-ft. Brakes are fantastic with the big Brembos.
Problems: Nothing really extraordinary. The usual PCV system replacement, spring seats for the front struts, front LCA bushings, sway bar links, caliper rebuilds, and finally needed new front axles recently to replace the originals due to the boots cracking. New throttle body couple years ago. An Ignition coil went bad around ~260K....all were replaced. Still has original ball joints.
Transmission shifts nicely, but does have a hard downshift on occasion when coming to a stop. Several trans fluid D&Fs with Mobil 3309, Toyota T-IV, and now Aisin fluid has cleaned it up, helped the downshift thing, and has improved the shifting in general. I don’t think the original owner ever changed the fluid. I recall the original fluid coming out of the transmission looking like brown water. Quite sure that a fluid change or two earlier in it’s life would have helped. Still waiting for the transmission to explode since the fluid was changed for the first time after 235K miles. LOL.
Overall we truly enjoy the practicality, reliability, and comfort of these fast sport wagons. Really glad the Swedes let their hair down and built these unique higher performance cars. With continued proper care, we are expecting to get 400K miles out of each of the three V70Rs!
8C7BF801-906D-4D83-BF72-9BF549DA48D5.jpeg6B79C329-FD24-440B-8AAF-6DE27AD9AAAF.jpegB842067D-2E1F-4937-860A-8C804B246E3A.jpeg
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440587 05/27/20 11:57 PM
G
gregk24 Offline
G
Thats a beautiful car. Timeless.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440594 05/28/20 12:33 AM
csandste Offline
Wish we had more wagons.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440601 05/28/20 12:56 AM
daves87rs Offline
Makes me want one now/////
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier (project)
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440602 05/28/20 01:23 AM
B
Bjornviken Offline
B
My co worker have over 700k km on her Volvo v70, my father have almost 400k on his S80. Extremely rust resistant indeed.
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440605 05/28/20 01:37 AM
T
Tyson Offline
T
We just sold our 2002 V70 2.4 NA, with 244k miles to a friend that needed reliable transportation on the cheap.
Other than timing belt/water pumps and a front end rebuild at 200k, repairs have only been a few issues with door locks, latches, power lock motors. The engine and transmission was flawless.
Paint, leather seats, and overall built quality were excellent.
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440625 05/28/20 04:51 AM
J
joekingcorvette Offline
J
Always like that body style.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440630 05/28/20 05:01 AM
dlundblad Offline
Nice looking Volvo. I especially like the caramel interior.
The bodies hold do up exceptionally well. My wife’s car has zero rust. My service history almost mirrors yours as well.
Funny about the exhaust. 2 brackets rusted off on hers. Volvo made 2 clamp on replacements for her model, but only 1 is readily available here. The very end is being held up with some livestock electric fence wire. You can’t tell unless you’re under the car and it doesn’t rattle. Lol.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440641 05/28/20 05:40 AM
P
pbm Offline
P
My brother in law is a Volvo guy....he's had 2 of them and pines for another.
The only negative that I recall is the PCV system (flametrap) that is expensive to fix*.....everything
else (positive) that's been said...seems true.
*I have read that if synthetic oils are used and a sensible OCI is followed this issue is far less likely to occur.
'Journalism is Dead'
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440654 05/28/20 06:26 AM
R
Railrust Offline
R
Interesting, I really thought I’d come into this thread and not believe, but I leave a believer.
For a car to last like that, relatively rust free in New England, is quite a testament to a great vehicle. Few cars survive New England winters unscathed...BMW comes to mind, very rarely do I see them rust, but of course they have plenty of other issues. Sounds like Volvo is a winner.
Wonder how the newer Volvo’s are 2012 and up? I’m looking for a used SUV for the wife...would like something nice without the “nice” problems.
2018 Chevy Silverado 5.3 (sold, with 52,000 stumbling and bumbling miles)
2007 Lexus LS460 (deceased)
2008 Honda CRV
2016 Toyota Avalon XLE
(Whatever synthetic oil is on sale or rebate)
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440682 05/28/20 07:30 AM
M
madRiver Offline
M
A car buddy friend has 2005 R also along with GTI 20th anni and does all DIY. He loves/adores the car but said its very expensive car to own(relative to VW) even wrenching yourself I believe due to specific R bits(mentioned about $5k in parts).
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440684 05/28/20 07:30 AM
Astro14 Online Content
Online Content
I found myself nodding my head in assent as I read through your post.
Yep, the Volvo P2 chassis is a solid one. The I-5 engine is robust and durable. It's weak spot is that PCV system, but properly cleaned out, and with a better oil spec, that is easy to manage. I've done several UOA on various oils in the cars. They are all good, as long as you get an oil that's formulated for long drain interval. MB 229.5, for example, or ACEA A3/B4. I've used, with good UOA, Mobil 1 0W40, Pennzoil Ultra Euro in 5W30 and 5W40, and Castrol 0W40 and Amsoil Signature Series 0W30. When I did the PCV system replacement, I dropped the oil pan (sump, Volvo calls it) and cleaned out that block passage with a rifle brush.
I've done the timing belt on these cars several times. Finally bought the crank pulley hold tool. So much easier with that vs. my fabricated holder. The engine mounts are a 60-80K miles wear item, it seems, and I didn't like the polyurethane upper mount, too much vibration, so I went back to rubber. A poly lower transmission mount works great, though, and is far more durable than the OEM rubber.
Your car has the better AW-55-50 Transmission. The vintage in all three of my cars required valve body surgery. With that flaw addressed, the transmissions are holding up well in all three. I replaced or rebuilt the valve body in all three and added an external cooler, thermostat and filter. They get regular fluid changes (complete changes) every 30,000 miles. The fluid is still red/clear but given the weakness of the 2001-2002 AW-55, I want the fluid in good shape. I have used, with success, Mobil 3309, Toyota T-IV, Valvoline Import Multi-vehicle and Amsoil Signature series multi-vehicle.
I used the Amsoil for the car that's in Vermont now, reckoning that it would benefit the most from the lower pour point. As long as JWS-3309 (Toyota T-IV) is met, the fluid will work. If you're interested in my transmission set up - I posted a few pictures in this forum: https://www.volvoxc.com/forums/showthread.php?27334-02-XC70-Transmission-Flush-From-Bottom If your cars have made it to 300K without additional filtration and cooling, then clearly, my system is overkill...but this wouldn't be BITOG without a bit of OCD overkill...
Front suspensions get tired about every 80-100K miles. Those lower control arm bushings are a PITA - I've taken to just replacing the whole arm, rather than align and press the bushing. IPD makes an upgraded arm, and they've held up well. Better than the factory ones, which have become crazy expensive. You're stuck with that Monroe/electric set up. Those are pricey...
You've also got the same angle gear as my wife's XC. I've pulled the angle gear, replaced the collar sleeve, re-sealed the gear and added a drain plug. A couple of photos here: https://www.volvoxc.com/forums/showthread.php?29700-Angle-Gear-sealing-and-modification That's worked very well. The gear is tight and dry now. No leaks. Allows me to change the oil easily (as you know, it's a pain otherwise) and the magnetic plug picks up any particles. You might consider that. The angle gear lives in a tough place - lots of heat from the turbo.
The 2001 V70T5 in my sig is actually my son's car. A graduation present. I bought it with 75,000 miles on it in 2018. I had the CEM rebuilt by XEMODEX in Canada as I was getting some odd anomalies in VIDA. That fixed them. Rebuilt the suspension, including Bilsteins, balljoints, tie rods, LCAs, strut mounts and spring seats. New brakes with drilled rotors, stainless hoses, ceramic pads. Transmission got a new GM valve body, which required a bit of harness modification and a solenoid swap. I fitted an oil cooler, thermostat and big external filter mount to the transmission. I used new cooling line hoses. The engine got a new timing set, radiator and heater core hoses, vacuum hoses, water pump, coils, plugs, injectors and PCV. I dropped the pan, but found, to my surprise, that the PCV passage in the block was quite clean. IPD cat back exhaust and downpipe. I found a set of redone 17” Volvo wheels ( Propus style, made by BBS) and out a set of 235/45R17 Michelin Pilot AS 3+. I kept the original 16” wheels on which he mounted winter tires. I fitted an R-model exhaust manifold. The turbo got a new CBV and seals, and I adjusted the waste gate back to factory spec (they get lazy with age). With those updates, and the lighter weight, I am willing to bet that it will hang with your heavier R-model.
His car is quick, quiet, comfortable, economical, with great brakes and good handling.
I really like the P2 chassis. The other two cars have over 200K and run perfectly. The paint and interior look great on both. Volvo built a durable, practical car in the P2. All the room of an SUV, but with the driving dynamics and fuel economy of a car. They don't rust. They hold up.
I'm a fan. A big fan.
So, congrats on three great cars.
P.S. my sons car:
[Linked Image]
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440705 05/28/20 07:55 AM
Donald Offline
But now that its got 300K on the clock, what to do? Is it a car that is reliable enough to take the family on vacation?
2015 Ford F-250 w/Powerstroke
Re: Can a 2005 Volvo go 300K Miles easily? [Re: VolvoZ] #5440708 05/28/20 07:59 AM
M
MCompact Offline
M
I call BS; everyone knows that only Toyotas, Crown Vics, and Grand Marquis can go 300k miles.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Can a 2005 Volvo go 300K Miles easily? [Re: MCompact] #5440721 05/28/20 08:18 AM
P
pandus13 Offline
P
I heard the wagon version is called a hearse...
Or Pontiac Vibe...
Not everybody likes wagons or hatchbacks. Especially in performance package :-P
OP, congrats and please don't be a stranger. Proper care for a vehicle without even being OCD.
P.S: didn't we had some older posts about the 3 custom V8 performance brick wagon Volvos which one was in (RIP) Paul Newman's possession?
Crazy P.S.: i left many "sport" cars in my rearview mirror with my stock AT Toyota Yaris (1.5L engine). I was just driving the posted speed. Riddle me this: why can't you drive at least posted speed if you have a more than capable car???
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Page 1 of 3 1 2 3
