Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
97 registered members (28oz, 2015_PSD, 1911CHAMPION, ARCOgraphite, AdamZ, afree, 13 invisible), 1,892 guests, and 43 spiders.
Topics307,632
Posts5,314,685
Members71,894
Cam specs for '62 Corvette Fulie #5440576 05/27/20 11:06 PM
J
JeffKeryk Offline OP
J
I have been asked about the cam specs for a 1962 Corvette 327 FI, 360 HP.
My BIL is adjusting the lash on his restored '62. He bought the engine (period correct) from a builder.
I don't know that much about the early cars...
My understanding is the Duntov 097 cam was used in performance solid lifter 1962 Corvettes.
I think it was used from '57 until '63; after that the famous 30-30 radical cam was used.
The 097 lash specs should be .008 and .018 hot.
If you have knowledge regarding a different cam, please chime in.
I really think the timing cover should be removed and check for numbers.
I asked him to measure I/O valve lift and I can compare that to the specs I know of.
Thanks in advance.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Cam specs for '62 Corvette Fulie [Re: JeffKeryk] #5440678 05/28/20 07:23 AM
Shannow Offline
Hmmm...checked my libreary...I had a book on the Chev fuellies...appears to have been borrowed over the last 20+ years...
If it's the truth....it can handle the pressure !!!
Re: Cam specs for '62 Corvette Fulie [Re: JeffKeryk] #5440686 05/28/20 07:35 AM
J
jhs914 Offline
J
The legendary Duntov SBC solid lifter cam was referred to as the 30-30 cam because that was the cold valve lash spec, .30" on both intake and exhaust valves. Now this is coming from the memory banks of a 72 year old former hot rodder, so take it with a grain of salt.
Re: Cam specs for '62 Corvette Fulie [Re: JeffKeryk] #5440704 05/28/20 07:54 AM
cknight49090 Offline
According to a book I have SBC performance the pre 64 vette had cam # 3736097 mechanical lash .012/.018.
Re: Cam specs for '62 Corvette Fulie [Re: cknight49090] #5440780 05/28/20 09:42 AM
J
J
Yes, that's the Duntov 097. I believe the intake lash is .008".
I also think this is what is in his car.
2018 Lexus RX450h
2006 Acura TSX
Re: Cam specs for '62 Corvette Fulie [Re: jhs914] #5440786 05/28/20 09:44 AM
J
J
Yes, the nickname was from the I/O settings. People also Mickey Moused around with the settings.
2018 Lexus RX450h
2006 Acura TSX
Re: Cam specs for '62 Corvette Fulie [Re: JeffKeryk] #5440813 05/28/20 10:07 AM
A
ARCOgraphite Online Content
Online Content
A
Remember the rule better loose than too tight. especially the exhaust.
Better check double that .008" I number.
We could run Street strip cams a bit tighter on the intake for track days,
This is a Vintage, car I would err on the side of conservatism.
This is a very mild cam. You should be fine at 0.01: cold..
Also see where they are at.
I would check and record three first.
And Re- torque the head bolts while you are in there.
- Ken
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Cam specs for '62 Corvette Fulie [Re: ARCOgraphite] #5440940 05/28/20 12:23 PM
J
J
- Ken
Good advice. The valves are already loose; too late.
I asked him to measure the lift at the valve with the clearance set to 097 specs.
If the lift matches the 097 valve lift specs, I think I can call it good. Otherwise...
He has a ton of $$ and years into this car. He found a period correct block and Mechanical FI Unit.
You are so right; he doesn't wanna get this wrong.
Personally, I would pull the timing cover and look for ID numbers.
While he believes it is the stock reproduction cam for that engine, it could be anything.
I agree .010 cold Intake is a safe setting. This is a show and fun car; no beating.
2018 Lexus RX450h
2006 Acura TSX
Re: Cam specs for '62 Corvette Fulie [Re: JeffKeryk] #5440966 05/28/20 12:48 PM
R
Randy_R Offline
R
I found this. Looks like .012 and .018 are correct for this cam.
https://www.enginelabs.com/engine-tech/cam-valvetrain/duntov-small-block-camshaft/
2018 Mazda CX-5 10000 miles Zepro moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 70,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 Wix 51061
Re: Cam specs for '62 Corvette Fulie [Re: JeffKeryk] #5441268 05/28/20 07:43 PM
J
J
I asked my BIL Mark to measure the intake and exhaust lift at the valve as best as he could.
He came up with .468" intake and just a taste more on the exhaust valve.
I used .468" divided by 1.37 rocker ratio to come up with .342 lobe lift.
The 097 cam is generally thought to be .395" and .399" I/O.
I am calling this the 097 cam for now. I suggested .012" and .018" lash.
My Motor Manual lists .008" for the intake, but my research says this is more for the weekend warrior who wanted a little more duration...
I also pinged my friend Lars Grimsrud. Yes, I know I am name dropping... He also cautioned me on the tight valve numbers.
Thanks for all your help.
2018 Lexus RX450h
2006 Acura TSX
