Another Civic Down
by ctechbob - 07/06/20 01:25 AM
Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
35 registered members (Avery4, blufeb95, 400rwkw, bbhero, Bazza32, BlakeB, 2 invisible), 898 guests, and 30 spiders.
Topics307,469
Posts5,311,711
Members71,852
Page 1 of 3 1 2 3
Harley Davidson Lithium LiFe 6Ah Battery 66000174 #5440405 05/27/20 07:29 PM
DuckRyder Offline OP
[Linked Image from rangerxlt.com]
Needed a replacement and this one had good reviews.
Bike turns better than it did when new, reported 11 lbs lighter than AGM. It is incredibly light, the box feels empty, it was a little disconcerting to begin with.
Built in tester is IMO a little silly, easier to plug a meter into the battery tender leads than to take the seat off and push the button.
I don’t know if the dealer put the wrong battery bolts in, but they would not tighten all the way without bottoming and i needed the “retrofit kit” which is a couple of shorter battery terminal bolts. My bike wasn’t supposed to need them.
I’m going to guess Bosch makes it for Harley grin2.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: DuckRyder] #5440413 05/27/20 07:43 PM
E
eljefino Offline
E
Interesting! 6 amp-hours is nothing, but I'm sure that has plenty of oomph to crank the starter.
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: DuckRyder] #5440425 05/27/20 07:52 PM
Heres the relevant page:
https://www.harley-davidson.com/store/lithium-life-6ah-battery
It is supposed to have 420 cranking amps, which is more than the AGM equivalent, drawback is apparently they don’t like cold. While i have ridden in 20 degree weather, it is not something I plan to do extensively...
Robert
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: DuckRyder] #5440428 05/27/20 07:57 PM
gathermewool Offline
With that large of a top, I'm assuming the charging logic is located within the battery to prevent over-charging.
On the box, I noted something interesting: "Fits '07 - '17 VRSC (except '07 VRSCR)
What's different about the '07 VRSC*R*? Maybe you drive an '07 VRSCR and this is why you needed the shorter tie-downs?
Not to be a weaner, but stating it's "Lithium LiFe" is redundant since Li is the chemical symbol for lithium.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: gathermewool] #5440432 05/27/20 08:07 PM
I have a Softail. VRSC is V Rod. I am not sure what is different about a 07 VRSCR but in the Q&A they say that if they state it fits it is fully tested, so it could be they simply haven’t tested it, or that something is different.
Robert
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: DuckRyder] #5440438 05/27/20 08:20 PM
B
Bonz Offline
B
The lithium batteries are amazing, mine dropped almost 9 lb of weight from my bike. If you do need to start on a cold day, simply turn the key on to get some battery power flowing for a half minute and that gets the battery warmed up so to speak and will crank wonderfully.
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: gathermewool] #5440439 05/27/20 08:22 PM
E
eljefino Offline
E
I think the marketing guys got their needles in so they can print "life" and be all cheerful and optimistic.
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: eljefino] #5440445 05/27/20 08:29 PM
I thought the same thing. I re-read that part of my post and realized it sounds like a dig on the OP; it's not. I was definitely making fun of the nomenclature on the box!
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: DuckRyder] #5440463 05/27/20 08:48 PM
B
Blkstanger Offline
B
Nothing like putting a Chinese battery in your Harley. USA
99 Jeep WJ 4.7 205,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 81,000mi. Castrol Edge 5w30 Fram Ultra.
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: Blkstanger] #5440465 05/27/20 08:51 PM
Thank you for your comment Richard.
Robert
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: Blkstanger] #5440471 05/27/20 08:57 PM
Please list the things you own that are and are NOT built in the US, besides the vehicles in your sig...
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: Blkstanger] #5440491 05/27/20 09:19 PM
I
Imp4 Offline
I
Hey, that way it matches up with all the electronics already on the bike that H-D sources from China.
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: Imp4] #5440493 05/27/20 09:21 PM
Robert
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: DuckRyder] #5440497 05/27/20 09:27 PM
I
Imp4 Offline
I
Nice job with your insinuations but yeah facts is facts though.
Re: Harley Davidson Lithium LiFe 6Ah Battery 66000174 [Re: gathermewool] #5440534 05/27/20 10:09 PM
L
LvR Online Content
Online Content
L
Li is indeed chemistry symbol .............. and only ONE part of the battery technology used .
Common other battery using Li is Li-ion (older technology/chemistry).................. in this case its Li-FE (Lithium - Iron)
Being a bigger weaner possibly .............. just click on the "review" button and quickly scroll through the 2 pages here https://www.harley-davidson.com/store/lithium-life-6ah-battery
IMO if the usage/oprating conditions are right its quite possible to be impressed with the technology ..................... but if not? ............. stick with good old lead technology
Page 1 of 3 1 2 3
