Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
34 registered members (bbhero, bob22, Bazza32, BlakeB, blufeb95, BLND1, 2 invisible), 933 guests, and 25 spiders.
Topics307,468
Posts5,311,708
Members71,852
Flare wrenches #5440053 05/27/20 10:43 AM
H
hallstevenson Offline OP
H
I'd like to buy a set of 'good' flare wrenches (related thread on brake lines to this) and am looking for some comments.... I know for certain I need 8mm and 10mm and need to confirm, but I want to say the bleeder screws on the Fusion are 7mm. I can get combinations with 7 x 8 mm, 9 x 11 mm, and 10 x 12 mm so right off the bat, I at least want/need the first and third ones. Not a lot of companies seem to offer them in 8 mm let alone 7 mm but I have found them from Snap On or Proto. I've found the Proto wrenchs from Zoro and they range from $17-20 each while Snap On (list price) is $45, $23, and $48. That's ridiculously expensive for me and something I can't, or won't, justify. My hope is to maybe buy them from a Snap On dealer/truck through a "friend". If I were able to do that, does anyone have any ballpark amounts these would sell for ? I presume they don't sell for list price !
I've tried SK, Williams, Wright, Gearwrench, and I think some others but they don't have all of these, typically the smallest one.
Re: Flare wrenches [Re: hallstevenson] #5440055 05/27/20 10:48 AM
M
mk378 Offline
M
Don't use a flare wrench on bleeder screws-- break them loose with a 6 point socket then use ordinary end wrench to open/close.
Flare wrenches really are for a single purpose, flare nuts.
Re: Flare wrenches [Re: hallstevenson] #5440065 05/27/20 11:07 AM
Dave9 Offline
^ Agreed, a thinner, normal wrench allows having tubing better seated on the bleeder, while a thicker flare wrench has more purchase on difficult line nuts.
Re: Flare wrenches [Re: hallstevenson] #5440067 05/27/20 11:11 AM
spasm3 Offline
I bought a set of snap-on flare wrenches used on eBay for about $100. They had hardly been used.
Worth looking!
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Flare wrenches [Re: mk378] #5440069 05/27/20 11:12 AM
spasm3 Offline
This. A socket, or box end wrench, heat if you need it.
Re: Flare wrenches [Re: hallstevenson] #5440078 05/27/20 11:25 AM
drtyler Offline
The Proto flare wrenches are good quality. Metric set J3700M has 7x8, 9x11, 10x12, 13x14, 15x17. The set price on Ebay or elsewhere may save you $$ compared to buying the individuals.
The SK wrenches are good as well, but their prices have been creeping up lately.
I agree with the others, no reason to use a flare wrench on a bleeder. Use a deep socket or ratcheting combo wrench.
Re: Flare wrenches [Re: hallstevenson] #5440088 05/27/20 11:36 AM
R
RyanY Offline
R
As others said, it is easiest to just use a 6 pt socket to break them loose and then to torque them after the bleed. However if you prefer a wrench, I recommend these:
7/9mm
https://www.amazon.com/gp/aw/d/B06XB2KZST/ref=psdcmw_15707321_t2_B00122BRW0
8/10mm
https://www.amazon.com/gp/aw/d/B06XB2LF4D/ref=psdcmw_15707321_t1_B06XB2KZST
2007 Cadillac CTS 3.6L >131k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >109k miles; QSUD 0W20 + STP S6607XL
Re: Flare wrenches [Re: hallstevenson] #5440100 05/27/20 11:54 AM
K
KenshinHimura Online Content
Online Content
K
What i usually do for wrench or sockets sets is look at buying a large set from either SK or Wright that have the largest amount of sizes i need and piecemeal any other ones i need that are not included in the set. Proto is great brand for Price point and most of it being made in the USA. I do mostly try to buy Wright and SK since they do use 100% USA steel as well. There are also places like KB Tools that sell used name brand tools as well
1997 Mitsubishi Eclipse Spyder Valvoline Max Life HM Full Synthetic 10w30 Napa Platiunum
2019 Hyundai Veloster Turbo QS 5W-30 OEM filter
Re: Flare wrenches [Re: hallstevenson] #5440103 05/27/20 11:56 AM
U
user52165 Online Content
Online Content
U
FWIW - typical bleeder spec is about 10 ft/lbs. Avoid the amateurish overtightening. crzy
Re: Flare wrenches [Re: mk378] #5440108 05/27/20 12:12 PM
Chris142 Offline
x2
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Flare wrenches [Re: hallstevenson] #5440126 05/27/20 12:34 PM
Donald Offline
I bought a used SnapOn brake bleeder screw wrench. One wrench, 6 point. Works great.
https://shop.snapon.com/product/Bleeder-Wrenches/Bleeder-Wrench/S6112
Its the only SnapOn wrench I have bought. I did find one on the side of the road. So I have 2 SnapOn wrenches now.
2015 Ford F-250 w/Powerstroke
Re: Flare wrenches [Re: hallstevenson] #5440135 05/27/20 12:50 PM
H
H
I should clarify, but I do use a 6-pt socket for the bleeders on 2 of our cars to break them loose. It's the Fusion, rear brakes, where the bleeder isn't accessible for a socket (as I recall). I may have been over-cautious by telling myself, "don't use an open-end wrench on there or you'll risk stripping it" so I just called it a night at that point.... I thought a flare wrench would be better suited, hence the quest I'm on. grin
Re: Flare wrenches [Re: hallstevenson] #5440157 05/27/20 01:29 PM
Z
Zaedock Offline
Z
I have a Matco set, which I think was around a hundred bucks and an 80's set of Craftsman (Danaher, I believe), which are very good quality.
I'm not sure how the current Craftsman line is, but my Matco's are very nice and may be in your price range.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Flare wrenches [Re: hallstevenson] #5440163 05/27/20 01:39 PM
demarpaint Offline
Generally speaking I use flare nut wrenches for flare nuts. For a brake bleeder, I use a 6 point socket, or 6 point box wrench. Having said that if you want a good set of flare nut wrenches I bought Stahlwille from Amazon.de as per Trav's recommendation. They're on par with Snap On, but were less money.
God Bless Our Troops
Re: Flare wrenches [Re: hallstevenson] #5440176 05/27/20 01:57 PM
Donald Offline
If you look at SnapOn for brake bleeder wrenches you see all kinds of odd shapes. The one I mentioned above is "L" shaped with a different size on each end. They have many other shapes. My Dad had a supply of cheap wrenches he would weld/bend when he needed a wrench to get around an obstruction.
