Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
34 registered members (Bazza32, BlakeB, blufeb95, BLND1, Bailes1992, ArrestMeRedZ, 2 invisible), 986 guests, and 24 spiders.
Topics307,468
Posts5,311,708
Members71,852
2000 Volvo S80 T6 Oil Recommendations #5440023 05/27/20 10:07 AM
M
MattV922 Offline OP
M
Hi all,
I have a new to me Volvo with about 144k and figured I should change the oil. I'm just wondering what oil you'd recommend for longevity with this turbo 6 cylinder. Thanks!
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440025 05/27/20 10:10 AM
K
kschachn Offline
K
As usual, what does your owner's manual say?
Start there, take recommendations from that point.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440026 05/27/20 10:11 AM
Astro14 Offline
Any A3/B4 Euro spec oil.
I’ve used, with good UOA and excellent results, MOBIL 1 0W40, Castrol 0W40, Pennzoil Euro 5W30 and 5W40.
The big thing with this engine is keeping the PCV system clean, or it’ll start drinking oil, and then blow out the cam seals. If you start using oil, replace all the PCV system components before it gets worse.
And... welcome
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: kschachn] #5440030 05/27/20 10:16 AM
M
MattV922 Offline OP
M
Good point. Volvo is all over the place on viscosity for these engines which is part of the reason I'm asking, however my manual recommends 5W40 or 10W30 for my climate and ACEA A3/B3 certified
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440036 05/27/20 10:21 AM
Astro14 Offline
The owners manual on this specifies a 5W30, but then, in very fine print, it suggests that a 0W30 or a 5W40 should be used for hard driving.
It mentions A1/B1, but it’s a 20 year old manual, and subsequent TNN recommend the A3/B4 after a ton of Volvos of that vintage had major sludge issues.
For example: https://www.volvoxc.com/0/resources/how-to/pdf/01-23-09/TNN,%20Lubrication%20System%20Contamination%20Cleaning.pdf
Volvo went to a 7,500 mile OCI that year, in partnership with Castrol, and specified a euro long-drain oil. But...
Volvo NA told its dealers, “use Castrol 5W30” and they promptly went out and bought bulk, conventional, 5w30 and used that on every new Volvo. A few years later the sludge parade started.
So, use a long drain specified oil, like the above mentioned, and avoid the ugliness that resulted in Volvo having to do a recall and issue the TNN.
32 Packard 15W40
05 MB S600 0W40 M1
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440037 05/27/20 10:23 AM
Astro14 Offline
Matt - you replied as I was typing....
So, you’re fine with any viscosity you choose, though I’ve found that the 0W40, or 5W40, does better for consumption in the XC-70 which is a bit of an oil user. Both of my T5 wagons burn less than 1/2 QT over a 7,500 mile interval.
32 Packard 15W40
05 MB S600 0W40 M1
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440040 05/27/20 10:27 AM
M
MattV922 Offline OP
M
Thanks for the advice Astro. I was actually leaning toward the Mobil 1 since it's the only one readily available in my area. From the looks of it this engine was subjected to some long OCIs on conventional based on the varnish in the head but it's nothing too bad. The examples in that TNN look crazy.
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440041 05/27/20 10:32 AM
K
kschachn Offline
K
Yeah grade (viscosity) is largely irrelevant with ACEA specifications, A3/B4 is more stringent than A3/B3. Astro has a good suggestion and any major name-brand oil that carries that certification would be a great choice.
1994 BMW 530i, 253K
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440042 05/27/20 10:34 AM
Astro14 Offline
The MOBIL 1 is a great choice because it’s very available at places like Walmart or Amazon for about $25/jug. It meets all the specs and will do well in your car.
At that mileage, please check the PCV. (Volvo calls it a flame trap).
Matthews Volvo Site or Swedespeed have details. It’s about $300 in parts if you need to replace everything and there no good shortcuts on that job. You gotta’ do it right, or you’ll be doing it again.
32 Packard 15W40
05 MB S600 0W40 M1
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440054 05/27/20 10:44 AM
M
MattV922 Offline OP
M
Definitely will check the PCV which thanks to it's wonderful placement means I'll need a new intake gasket right?
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440068 05/27/20 11:11 AM
L
Lolvoguy Offline
L
Yes, as well as several other seals and gaskets.
It basically like a mini-rebuild. After this repair you'll be much more familiar with the confines of your engine compartment.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440090 05/27/20 11:40 AM
M
MattV922 Offline OP
M
Ugh another engine compartment to get acquainted with haha. I was hoping I'd be done with that for a while after swapping 2 Subaru engines and transmissions and a Kia transmission for family in the last couple months...
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440219 05/27/20 02:57 PM
Astro14 Offline
Believe me, I understand...
32 Packard 15W40
05 MB S600 0W40 M1
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: MattV922] #5440221 05/27/20 02:58 PM
1
14Accent Offline
1
I'd be more worried about the transmission in that car. It uses a GM 4T65-EV (Gm trans with a custom bellhousing for Volvo). They weren't reliable behind 3100's, and they CERTAINLY aren't reliable behind the torque of that 2.8 T6. Add a big cooler and use good quality fluid!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 2000 Volvo S80 T6 Oil Recommendations [Re: 14Accent] #5440296 05/27/20 04:52 PM
M
MattV922 Offline OP
M
Currently it shifts great and the fluid looks perfect so I'm hoping I'll at least get close to the 200k mark before needing to yank it and rebuild it.
