Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
25 registered members (bdcardinal, bmod305, Blkstanger, carlprop, Dave9, Alfred_B, 2 invisible), 747 guests, and 22 spiders.
Topics307,436
Posts5,311,041
Members71,848
2012 Mustang V6, 75w-140? #5440006 05/27/20 09:46 AM
RDY4WAR Offline OP
Looking up the specs for the rear end in my wife's 2012 Mustang V6, it says it takes 75w-140. Why? I could understand it in a 9" rear in a truck that'll see heavy duty use, but an 8.8" with 2.73 gear behind a V6 pony car? Any reason a high end 75w-110, such as HPL Diff Life 75w-110, wouldn't work in that rear end? I know there was some controversy over this, but haven't really dug into why.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440013 05/27/20 09:55 AM
F
FastLane Offline
F
Ford changed the spec a long time ago for 75W140. My 2002 is spec for it too. Ford was having issues with 90 weight gear oil and spec the 140. No issues with the 140.
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Lund SV16
2007 Yamaha Nytro
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440019 05/27/20 10:02 AM
RDY4WAR Offline OP
What were the issues though? I know about the change over, but never heard a reason why. Was it a broad issue across all many rear ends or just certain circumstances in which Ford changed to 75w-140 as just a CYA.
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440027 05/27/20 10:13 AM
CT8 Offline
I run 75W-140 syn gear lube in my Toyota Tacomas and Ford p/u rear ends. I couldn't tell any difference , but we used 85W-140 at work so I took enough for a rear end and 3 on the tree trans change decades ago in my ford F150 with a 300 ci 6 cyl ,I really could tell the difference because the 85W-140 is much thicker.
2015 F150 2.7
2018 F350 6.2
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440075 05/27/20 11:18 AM
MolaKule Offline
Global Moderator
Global Moderator
That spec was instituted before the new formulation 75W110 was developed.
Again, 75W110 is a good all around grade for any differential.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: 2012 Mustang V6, 75w-140? [Re: MolaKule] #5440180 05/27/20 02:06 PM
RDY4WAR Offline OP
This is what I was curious about. Thanks for confirming that.
Re: 2012 Mustang V6, 75w-140? [Re: FastLane] #5440196 05/27/20 02:39 PM
2015_PSD Offline
Until 2015 in most of the vehicles that have a 9.75 or 8.8 axle they reduced it to either 85W-90 (conventional) or 75W-85 (synthetic). All rationale points to CAFE since no changes that have been announced took place within the design of the axles.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440246 05/27/20 03:41 PM
O
oldhp Offline
O
Some things don't make sense. My Charger SXT 3.6/8 speed and Challenger R/T 5.7/6 speed takes 75W85, so does the all mighty HellCat. My 2018 RAM 1500 short bed 2wd 3.6/8speed takes 75W140. But yet a 3/4 ton or 1 ton RAM takes 75W90. ???????
When somebody can figure all this out let us know.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440281 05/27/20 04:30 PM
F
FastLane Offline
F
It was years ago but the Ford dealer printed out the change to 75W140. The switch solved the 8.8 issues. I’m curious what would have changed to go back to the thinner gear oil.
I have nearly 200,000 kms on my Mustang now. I just changed the limited slip clutches to the carbon fiber version. Other than that it’s been great. Still quiet. The car has seen “high” speeds too.
2007 Yamaha Nytro
Re: 2012 Mustang V6, 75w-140? [Re: RDY4WAR] #5440812 05/28/20 10:07 AM
dwcopple Offline
I just did my 98GT rear end this past weekend. Used UltraLub 75w90 full syn and 4oz of Lubeguard friction modifier.
2017 Acura MDX SH-AWD
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
