Hello everyone, I am wondering if it is better on an automatic transmission to manually downshift it to a lower gear before flooring it so it isn't downshifting under heavy load. For example, of I am going 50 and I decide to floor it, is it best to floor it and let the ECU downshift it to 2nd gear automatically or is it it best to manually downshift it to 2nd gear and then floor it? I would think it would be best to downshift to the appropriate gear before flooring it, it would seem that downshifting under full throttle would cause significantly more wear on the clutches than downshifting it under a light load before flooring it. Thanks in advance!
